Question about HP OfficeJet 7310 All-In-One InkJet Printer
Won't print when you turn it on it says "carriage jam" - open door and clear jam I OPENED THE DOOR BUT CAN SEE NO JAM AND INK CARTRIDGES WON'T MOVE - WHAT AM I LOOKING FOR IN THE WAY OF A "JAM"???? THANKS FOR YOUR HELP
  • 679 Answers
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Posted on Feb 03, 2009
Print head jam
Check the LCD on your printer control panel or the status monitor on your computer for an error message. If there is an error message, follow the instructions to clear it.
If there is no error message, or if the problem continues:
  1. Open the access door.
  2. Disconnect the power adapter from the back of the printer.
  3. CAUTION: Do not use force on the printhead carriage to move it. Gently move the printhead carriage from side to side to see that it moves freely and there are no obstructions.
  4. Remove any obstructions that may prevent the printhead carriage and ink cartridges from moving to the center position.
  5. Close the access door.
  6. Connect the power adapter to the printer.
  7. Remove the ink cartridges from the printhead.
  8. Verify that the labels on the ink cartridges are intact, and that the cartridges are not damaged.
  9. firmly until you hear it click into position.
  10. Insert the color ink cartridge into the printhead, then press down firmly until you hear it click into position.
  11. Close the printer access door.
  12. Press OK to clear the error.
  13. Make a print.
May 06, 2014 | Kodak Office Hero 6.1
Copier makes a noise when first turned on and then it tells me to open the door clear carriage jam and press enter. But that does not work. The printer has been sitting for a little...
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
Nov 29, 2010 | HP PSC 1600 InkJet Printer
I have paper jammed in my HP DESKJET PRINTER D2260. Tried to pull it out but paper ripped off and can still see other end still in there. Been advised to open back door and clear it but cant see how back...
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Nov 18, 2010 | Office Equipment & Supplies
How do I clear a paper jam from the hp laserjet 1020
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Nov 16, 2010 | Office Equipment & Supplies
False paper jam reading.keeps say to clear paperjam. called HP and they said its a common problem,too expensive to fix,buya new one from us for 300 bucks
Check the following Steps for fix HP printer carriage Jam :
  • Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
  • Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
  • Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
  • Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Sep 14, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Clear carriage jam
The carriage assembly is what the ink cartridges moves on. The silver bar that runs through the cartridge holder must be oiled. Put two or three drops of thin oil oun iether sides of the cartridge holder. This should clear the "carriage error"
Good Luck
Apr 15, 2010 | HP PSC 2210 All-In-One InkJet Printer
Won't print. Message says "carriage jam. Open door and clear carriage jam." There is no jammed paper or anything visible. Put door back on, still won't print. have turned on and off, and reinserted paper....
It is giving carriage jam not a paper jam the carriage is the part which carries cartridges on it. It seems your carriage is jam and can't move left and right so open the door and try to move your carriage with the help of rubber roller which moves your printer. Also clean the steel road on which the carriage moves just check at the corner of cartridge carriage if any paper bit is stuck or excessive paper dust has jammed it. If this does not solves your problem kindly comment back.
Jul 28, 2009 | HP Photosmart C5180 All-In-One InkJet...
My printer made a weird noise and now says "Open door Clear carriage jam and then press Enter". How do I clear a carriage jam? I have opened the top cover and usually the print cartridges move to the...
Issue The error ' Open Door, Clear Carriage Jam, and then Press Enter ' displays on the product. The following symptoms might also accompany this error:
* The product will not print. * Printing stops unexpectedly. * The carriage does not move.
Try the following solutions in the order presented to resolve the issue. When one of the solutions resolves the issue, there is no need to continue troubleshooting. Solution one: Turn the All-in-One off and on again
1. Press the Power button ( ) to turn off the product. 2. Press the Power button ( ) to turn the product on again.
* If these steps resolved the issue , you do not need to continue troubleshooting. * If the issue persists , continue to the next solution.
Solution two: Clear any paper jam A carriage jam might follow a paper jam. Follow these steps to check for and remove any jammed paper. Step one: Check for and remove any loose paper from the input tray Remove any loose paper from the input tray, the output tray, and the automatic document feeder (ADF). CAUTION: Do not remove jammed paper at this stage. Step two: Clear a paper jam from the rear access door WARNING: Always clear paper jams through the back door if possible. To avoid tearing the paper and damaging the print mechanism, pull paper from the printer slowly and gently. Avoid touching the internal components of the printer.
1. Disconnect the power cord from the back of the printer. 2. Remove the back door and remove as much jammed paper as possible.
3.Replace the back door and open the carriage access door. If there is paper visible that cannot be removed through the back door, gently pull it out from the front.
4. Reconnect the power cord and close the printer.
Solution three: Make sure that the carriage moves freely
1. With the product turned on, open the cartridge access door. The carriage might try to move into the access area. If so, allow it to move to that position. 2. Without turning off the product, unplug the power cord from the back of the product. WARNING: You must disconnect the power cord to move parts by hand without the risk of an electrical shock. 3. Look in through either the cartridge access door or the output paper tray to make sure that the cartridges are secure in the carriage and not loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving. 4. Make sure the carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found. You might have to reach through the output paper tray to access the carriage. 5. Close the cartridge access door and reconnect the power cord to the product. 6. Press the Power button ( ) to turn on the product.
Solution four: Remove and reinsert the print cartridges Incorrect installation of the print cartridges can cause the product to show a false carriage jam. Follow these steps to remove, and then reinstall the print cartridges. Step one: Remove the print cartridges
1. Press the Power button ( ) to turn off the product. 2. Open the front of the product to access the carriage. The carriage moves to the center of the product.
3. Unlatch the two print cartridge latches, and then raise the latches. 4. Remove the print cartridges.
Step two: Reinsert the print cartridges
1. One at a time, hold a print cartridge with the printed label up, and then slide the print cartridge into its slot. Repeat this step for the other print cartridge.
# NOTE: Insert the black print cartridge into the slot with the gray latch, and insert the color cartridge into the slot with the blue latch. # Grasp the end of the latch on the cartridge slot with your thumb, and then pull the end of the latch toward you. While holding the latch, press down on the top of the latch until it stops, and then release the end of the latch so that it catches under the tabs. CAUTION: To avoid damaging the product, do not force the latches into place.
3. Close the product cover. A message displays on the control panel to align the print cartridges. 4. Press the Enter button to begin the cartridge alignment. Two pages print. Follow the instructions printed on the second page to complete the alignment. 5. Try the print job again.
Jul 08, 2009 | HP PSC 2175 All-In-One InkJet Printer
Epson 1280 ink carriage making noise and not printing
hello there. try re-seating the cartridge. Take it out, then put it back in.
Nov 28, 2008 | Epson Stylus Photo 1280 InkJet Printer
HP OfficeJet 7310 All-In-One InkJet Printer Logo
55 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
