Question about Philips Televison & Video
Channel search for my Phillips PL9125
I don't have the original remote for this TV and the only menu I can find is when I push both "up" and "down" volume buttons at the same time. Unfortunately, the menu doesn't include any type of channel search and I can't get the tv to go above channel 32. I need it on channel 73 or above to work as a second tv on my dish. I have programmed a remote for the tv, but when I manually push in a higher channel than 32 it says "channel unavailable" and goes back to the channel it was on previously.
You should contact to get original remote for that TV.
Posted on Nov 05, 2008
Proggram t.v. channel for-phillips t,v-model-pl9125-c-221
resert the code and download your instru. manual and proceed according with the connection diagram appearing use the common sense, logically, and clearly.
God bless you
Jul 30, 2012 | Philips RC2573 Remote Control
Unwanted channel display in middle of screen
TO REMOVE CHANNELSscreen13.gif 1. Press the MENU button on the remote control to open the OSD.
2. Press the Navigation (UP/DOWN) buttons to select the Setup menu.
3. Press OK to open the menu.
4. Press the Navigation (UP/DOWN) buttons to select MANUAL SEARCH.
5. Press OK to select.
6. Select the channel you want to delete from the channel list.
7. Press the Navigation (LEFT) toErase Channel.
8. Press EXIT to close the OSD.
Feb 29, 2008 | Televison & Video
Lost remote. Must do manually on t.v. Two problems:\r\n1) I cannot get channel back on channel 3. It skips from 2 to 4. 2) TV has large black box on screen covering most of screen. I can push buttons...
Try website like to buy the tv original remote to used.U will used the tv original remote to turn to channel 3 with ease.After u have the tv original remote push the menu button go into Closed Captioning functions turn off like TEXT 1,2,3...The big black box will not appear on the screen again.Tv used it manually control buttons up and down channels trying to get to channel 3.U will never get it to tv channel 3 because tv channel 3 was not save on it memory list of on the tv turn manually channels buttons programming memory.Tv have a manual button said MEMU button on it tv front bazel frame?Yes.Might could used the Menu button on the tv frame to get in to turn off TEXT 1,2, stop the big black box to show up on the tv screen again.
Aug 17, 2011 | Toshiba 36A50 36" TV
I need my television to do a channel search. I added cable and can no find the original remote. the universal remote will not pull up the menu
You'll have to use the buttons located on the Tv. Should have a menu button and then you can use buttons like channel and volume up and down to interact with the menu. Input/video/source button typically acts as the enter key in a menu.
Jun 15, 2011 | Sanyo DP26649 26 in. TV
MY TV only goes to channel 3 and dvd mode and i dont have the remote that came with it can someone help me.
walmart, universal remotes from $7.00 and up, the problem should be that channels up to 3 were blocked and you need to re program channel search on menu, cable or antenna option and then, locate channels with signal, if you watch tv from cable, the channels search only detected the channel 3 as a channel with signal, if the tv is not hdefinition, you wont need more channels, if it is hd, there is an option for dvd, antena (hd signal of course) and hdm or whatever signals capability, I hope I helped you, othewise, contact me and I will be more than happy to help, God bless
Jan 26, 2011 | Philips 25PS40S 25" TV
I have a phillips CL034 universal remote need code for sharp tv
this should work:
Oct 19, 2009 | Philips Magnavox Learning Universal Remote
Spanish closed caption, can't get to menu mode w/o original remote.
probably there is not menu button on the front panel i gess1.
  • get the original remote control at if available
  • or try to get phillips universal remote control available in any retail store.
  • finally turn off those lines
Apr 15, 2009 | Philips 25PT533S 25" TV
Need code for phillips remote
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 09, 2008 | Philips Televison & Video
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
42" Plasma TV - Closed Caption will not turn off
push down the channel up and down together and the tv menu will pop up use the volume up and down to change what you want good luck.
Apr 06, 2007 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
Televison & Video Logo
198 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
