I bought this house almost 2 years ago and had the dishwasher upgraded to this model. We really haven't used it much in 18 months. Now I am ready to use it again, but when I start it, there is a horrible knocking sound under the sink. It only happens when it's trying to fill. Any help would be appreciated! Thanks! Cathy
-   My GE Triton gets clogged up easy. I pre wash dishes - this time happend after 3 years. Technician came out cleaned unscrewed filter parts. Seemed to drain the water out ok - but the problem has come back. Now they want to come out again and give it a new pump. to the tune of 150. I already paid 127 for this machine to be fixed right the first time.
-   Guest
That knocking noise is probably coming from your water line, and that happens when there is some kind of a ripple/wave effect when the water goes into your dishwasher (DW) thru the inlet/fill water valve. First turn your hot water valve off, underneath the sink coming from the wall and it usually is also going to your kitchen faucet. Then turn the electricity off by locating the breaker to the DW line and turning it off, or if it is plugged in an outlet under your sink, just unplug it. Then take the kick toe panel (panel with 2 or 4, 1/4" or philips screws) from the bottom of the dishwasher. You will then see the water hose, or could be a copper pipe, going into the valve (will have a selenoide, cylinder shape on top and have 2 wires plugged in to it). Unscrew the hose/pipe from the water valve and get a small wide bucket or pot and aim the hose/pipe to it. Slowly have someone open the water valve from under the sink while you hold it in the bucket/pot. If you hear the knocking again, you will need a plumber to check the pipes, hoses and water valve at your wall. If you don't here the knocking noise, just replace the dishwasher inlet/fill water valve part # 785330. http://www.repairclinic.com/0080.asp. Please post back.
stops during the first cycle of washing and makes a clunking sound trying to get to the rinse and...
(More)
stops during the first cycle of washing and makes a clunking sound trying to get to the rinse and drain part of the wash cycle. It just hangs up until I play with it thru the cycles. Sometimes getting a double fill and then after the rinse and hold I can get it to splash thru it and drain it dry.
dishwasher runs but there is no water coming in. The dishwasher is three years old and has been fine...
(More)
dishwasher runs but there is no water coming in. The dishwasher is three years old and has been fine till now.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
