Question about Sanyo AVM-3659S 36" TV
Sanyo Model AVM 3659G won't recognize DVD player
No matter how I connect the TV to the combo DVD/VCR player, it wont' play. I have a universal remote programmed to turn on and change channels on TV. It works fine. Original remote didn't come with the TV when we bought the condo. After putting in new carpet and reconnecting, it stopped recognizing DVD player. Does it need to be reprogrammed/reset or do we need to get an OEM remote?
    Brigadier General:
  • 6,966 Answers
Let's try the easy one first:
  • verify the connections, normally yellow for video, white & red for audio. TV has to be set to Video 1, A/V or Channel 0;
  • in some instances, it could be a single coaxial cable. If it were so, the TV has to be set to Ch 3.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 05, 2008
Need codes and instructions to program Sanyo universal remote B21309 to a Philips Vcr/Dvd player.
Sanyo universal remote b21309 manual - logo - Tuars.com
ititoso.tuars.com/sanyo-universal-remote-b21309-manual/
Sanyo Universal Remote B21309 Please help find the manual for Question AboutSanyo Universal ... RMT-D153a RM-AX4000 Manual PDF instruction manual.
Sanyo Universal Remote RMT-U100 User's Guide ...
tv.manualsonline.com > ... > Sanyo Universal Remote
Sanyo RMT-U100 Universal Remote User Manual. Page 1. Page 2. Page 1 ... TheSanyo Universal Remote Control features large glow-in-. the-dark basic .
Nov 01, 2015 | Philips Televison & Video
Need coeds for sanyo
Hello
Setup code for Sanyo with One for all URC-3021 is
0154
The One For All 3 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola
cable box.To control devices other than the default brands,perform the following
steps; otherwise skip this section:
Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
2. On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
a DVD Combo device, you will be able to control channel
selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
Use the Manufacturer's Codes to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
5. Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY.
6. Repeat steps 1 through 5 for each device you want to control.
Mar 07, 2011 | One For All URC-3021 Remote Control
I have lost the remote for the DVW-6100 DVD/VCR player. Can I buy a replacement remote?
You may not be able to buy a replacement original remote for it, but a universal remote may work - it is then a matter of code (if needed) to operate most of the basic functions of your combo. You could always look on eBay amazon, or ask your local store about the universal remote. Logitech are the best universal remotes on the market - these range from basic types to all-in-one, with the price of each varying. You should be able to buy something like that locally (similar brand to Logitech which will serve the same purpose) - if Sanyo won't put an order for the original remote in for you.
Feb 22, 2011 | Sanyo DVW-6100 DVD Player/VCR
I have a SANYO model # AVM 3659G, Wont come back on
Hi, that probly a power supply plroblem, or a high voltage regulator and the horizontal transistor that drive the high voltage transformer at a high frequency (15.000 hz )if you think you can trouble shoot that ok; if not ask a friend who you no he nows about trouble shooting in tv. or you can go to a repai r shop should not cost to high half hour + parts
Beware high voltage in there(30 thousand volts
hope that help you
Mar 13, 2010 | Sanyo AVM-3659S 36" TV
Sanyo dvd/vcr combo
Your universal remote would have seperate selection buttons for VCR and DVD. If you don't have a VCR button, use AUX. Try programming each function seperately - DVD code for your manufactirer on the DVD button and VCR code for your manufacturer on the VCR button.
Sep 12, 2009 | Sanyo DVW-7100A DVD Player/VCR
Ssd803 dvd won't recognize universal remote
Sorry to say that most universal remotes do not work well with combo devices ie. vcr/dvd, tv/vcr, and so on. One thing you can try doing is to program the vcr portion of the remote to controll the vcr side, and the dvd protion to control the dvd side. More than likeley there will be a lack of functionality since combination units have buttons that would not be needed on individual devices.
I have found that the Logitech Harmany universal remotes work very well with anything but they tend to cost quite a bit more. You might be able to find a basic model on ebay or amazon for around $50.
Apr 26, 2009 | Sylvania SSD803 DVD Player/VCR
DVD/VCR does not work on my LCD
Use a co-ax cable. put your tv on ch03
Mar 02, 2009 | Emerson EWD2203 DVD Player/VCR
SANYO MODEL#3659G TV 36"
Thomas,
How did you check the fuse? Just by looking at it or do you have a multimeter?
If you have a meter check the secondary diodes on the power supply and the horizontal output transistor. Perhaps one of them is shorted.
Feb 02, 2009 | Sanyo AVM-3659S 36" TV
SANYO DWM-3000U combo dvd & vcr home theater system
I have a DWM 3000u that won't play some new DVDs. The movie is pixlated. Is there a firmware fix or do I need to buy a machine?
Lynda
Jan 11, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
Sanyo AVM-3659S 36" TV Logo
164 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
