Question about Dishwashers
Hotpoint LFT114 Fully intergrated dishwasher. Hi I've just installed this machine and I find it very noisy compared to our old one. Everything seems to be working OK and dishes come out clean but can't explain the noise
    Scholar:
  • 62 Answers
Hi! noises can be very elusive, but some more info might give me enough to narrow down your search or figure out if what you are hearing is normal. First, what dishwasher did you have before? The noise that you are hearing, is it during the fill cycle, the wash cycle , drain cycle or just overall noisier than your old one
Posted on Nov 05, 2008
Hi we have a Hotpoint Aquarius FDAL28 dishwasher. Machine turns on, drains and fills but then 3 lights keep flashing and washer stops programme. Any ideas what problem could be?
Depending on which lights are flashing, there is either a problem with the electronic control module, or the pump is stuck or has a motor failure. You can see which by comparing which lights are flashing with the pattern on this page of error codes:
http://www.ukwhitegoods.co.uk/help/fault-codes/dishwasher-fault-codes/3293-hotpoint-fdl-series-dishwasher-fault-codes
Jul 15, 2017 | Hotpoint Washing Machines
When my dishwasher finishes it no longer lets out 3 beeps and when you open the door there is no power even though the dishes are clean.
Hello J Arnott,
Sorry to say I'm here in the USA.. and I could not easily get a similarly designed model to reveal itself (for me) to gain a better understanding of your Hotpoint LFT114... (nor could I pull a FREE copy of your user manual (without registering or otherwise exposing myself to cyber-freaks (sorry)).
Regardless of the specifics.. suffice it to day your machine is NEW enough to be quite visible and relevant...
I looked over the LFT114 HA... Display board... £42.93
(there are many LFT114
And your trouble description was quite excellent in detailing
as SEQUENCE failure of your control modules...
Although it is possible to repair these things ... it seems you have several PCBs (printed circuit boards)... replacement is usually the first best GUESS (looking at the back () side would not hurt anything)...
I have rescued many a circuit board by simply "de-soldering"...
then re-soldering a connection...
(special care, skill & tools required... not tough nor expensive).
You description and troubles indicated the beeps & lights missing: is a clear indictment of your "DISPLAY board"...
A reminder... don't touch any PCB you value without first grounding your hands (professionals use STATIC WRIST STRAPS... CHEAP (unlike circuit boards) & available EVERYWHERE).
Also... Take lots of pictures of EXACTLY WHERE every wire comes from... (look them over BEFORE you get in trouble).
Be patient & FORCE nothing.
and of course... be safe (REMOVE POWER).
Comment me back BEFORE you guess wrong... (I'll try to help) .
Spares:
Hotpoint LFT114 HA PCBs Modules
Jul 15, 2016 | Hotpoint Dishwashers
Lft114 dishwasher does not get hot and start and wash button flash
3rd and 4th light flashing. Problem with control board. how to replace control board?
Dec 30, 2013 | Hotpoint Dishwasher Lft114uk Led On/off...
Fitting details for Hotpoint LFT114 dishasher
Hi when adjusting the legs just get it squair with the counter top keeing also level , it is ok if it tips towards the rear a little ,,once you get it set then install the two screws to keep it from moving ,
Dec 10, 2011 | Hotpoint Dishwashers
My hotpoint LFT114 switches on, has all four wash cycles, has water but will not work even when the door is fully engaged. What could the problem be
G.E. motors (G.E. and Hotpoint) have an issue with the impeller seizing. Turn the electricity to the appliance off. Remove the lower front panel(s) to gain access to the motor and its impeller. Take a flat head screw driver and carefully insert it within the motor impeller area and try to turn the impeller clockwise. If stuck or hard to turn, keep trying until it loosens (turns freely). If it turns freely, activate the dishwasher and see if it works for you. If the motor impeller does not turn, contact an appliance service company.
Feb 20, 2010 | Dishwashers
Very noisy when spinning
hi
it may be the belt making noise,,,check it,,,
thank u,,,//////please rate it
Jul 12, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint Dishwasher not working - FDW60
unplug it for an hour this normally fixes this problem on my machine
Jul 28, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
543 people viewed this question
Top Dishwashers Experts
