Question about Dell E173FPf 17" TFT LCD Flat Panel Monitor
NO POWER ON INDICATOR LIGHT AND NO Screen Raster on Monitor
Dell E173FPf 17" TFT LCD Flat Panel Monitor NO POWER ON INDICATOR LIGHT AND NO Screen Raster on Monitor.
Visual inspection of board yields no evidence of any bad or burnt parts, connections or cables.
  • chefdave136 Nov 05, 2008
    Hi, Just read your suggestion. I will check it out and get back to you. I am former tv repairman, so I am comfortable with board level repairs, soldering etc..
    Thanks for the quick response.
    chefdave136@yahoo.com
  • Anonymous Mar 14, 2014
    no sound are there built in speakers in monitor
    Brigadier General:
  • 6,966 Answers
Initially, pls check D854 on the Power Supply/Logic board. It is a dual diode. If you would prefer board replacement rather than component level repair, this might be of help. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
This is of course in addition to checking the usual, power cord, fuse, outlet etc.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 05, 2008
    New Friend:
What is the name of transistor q850 i have missed the transistor please kindly tell me the name of the Q850 transistor of 790271200800 E173FPf Thanks
Posted on Aug 04, 2013
    Problem Solver:
  • 9 Answers
Very easy replace ic cu3842 in power supply section...
Posted on Jan 05, 2012
Everything on my Dell Monitor E173FPf is tiny, what gives?
You need to re-set your screen resolution, RMB on your desktop and select properties - settings.
Jan 21, 2011 | Dell E173FPf 17" TFT LCD Flat Panel...
I have a dell monitor model e172fpt i have power when it turn on has white on the screen and turn on blue and black screen
not a expert just trying to help,,, try a different monitor and see if it works or not,, if you have same problem it is in the computer,, hope this help you
Feb 25, 2010 | Dell E173FPf 17" TFT LCD Flat Panel...
Dell E173FPf 17 vertical line problem
Yes, but the cost is not worth it. If you get it apart you will no doubt find a couple of bulging capacitors. Dell site has the disassembly instructions.
Oct 10, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
DELL MONOTOR TURN ON POWER SCREEN COMES ON AND GOES OFF IN TWO SECOND AND POWER LIGHT IS STILL ON
may be your power screen time is 2 seconds through properties u can change the time
Oct 01, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
Delll flat screen moniter goes black.
Assuming you are running XP.  Right click on the desktop, select Properties, select the Screen saver tap.
Click on "Power"
See adjust the time out so that it is  "Never"
May 18, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
Dell 17'' flat panel monitor power light is blinking
some transistors on the board have shorted they supply power to the inverter to run the lamps, they power is not cut off intermittently and the protection circuit has stopped the monitor. the fix is here
http://josepino.com/other_projects/?howto-repair-dell
goo dluck if you want it fixed for you let me know
Mar 22, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
Flat Cable (P-Two AWM 20969 E221612)
you need to be patient because if you cant get it from the dell stores and still you can get it online you will need to visit a computer hardware vendor/ repairer who have thesame monitor but the monitor is completely damaged so that he can repalce it for you. but it is going to be expensive.
Dec 16, 2008 | Dell E173FPf 17" TFT LCD Flat Panel...
Dell E173FPf lcd- no picture,steady green light
E173FPf Mfg December 2004
This E173FPF has changed much inside from the November 2003 E172fpb which had the famous 4 identical transistors 5707 that would tend to fail in pairs. If your newer E173FPF displays a green power light and fails to display a picture try replacing the 220uf25v capacitors at C6 and C26. Test them with a volt ohm meter and they will test Ok, replace them anyway. Radio Shack did not have the 25v so I used the 35v, display works fine now. There is an E173FPF repair kit with directions available on Ebay if you don't have a parts store in your area and would prefer delivery.
i'm not an expert at anything...x'cept maybe dumpster diving. God Bless
Jan 14, 2008 | Dell E173FPf 17" TFT LCD Flat Panel...
Dell e173fpf lcd monitor is grey
Sounds like the AD section of the board may be junk. I did the same thing - bought the board from lcdrepair.com.
I submitted an RMA request to get a replacement. The process was difficult due to the pdf form they make you fill out. Lots of errors and no good way to submit it, since it wants to use outlook, but the pdf isn't configured properly to do so. Seems fishy, but I'm giving them the benefit of the doubt for now. We'll see.
Nov 10, 2007 | Dell E173FPf 17" TFT LCD Flat Panel...
Dell E173FPf 17" TFT LCD Flat Panel Monitor Logo
351 people viewed this question
Alun Cox
