Question about Mitsubishi CS-31305 TV
TV WON'T COME ON MITSUBISHI - Mitsubishi CS-31305 TV
  • John Snow
    John Snow May 11, 2010
    Does the green light come on then go off after it clicks? I am working on one at the moment that will not turn on, but, the green light comes on for a moment.
  • 767 Answers
Hard to say , but as a repair tech we
check the Hoz TRAN and 80% of the time thats the problem . its not hard to find
but you will need a volt meter ,to check it
its a black kind of square part screwed to
a big heatsink next to the big black transformer ( Flyback) if all 3 of the legs show short on the HOT TRAN , a 6.00 part fixes
your TV.
Posted on Jul 17, 2009
Won't power on
Check the Mitsubishi TV error codes using the instructions on www.TvRepairKits.com . Look on the tips page. If its a steady blink its likely the blinking light of death issue. If its a 2-2 pattern its likely a convergenec failure. Both are failry easy DIY tv fixes.
Apr 19, 2013 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi tv 32 inch model number cs40505 won't turn on
Check its power regulator board. Check fuse. replace it as card basis, if found irrepairable.
Jun 14, 2012 | Mitsubishi CS-40505 TV
Mitsubishi tv won't turn on
did you try new batteries in the remote? if the tv has buttons on the side and one of them being power di you try to push that? did you push tv power or cable power holding the buttons longer? those things might work.
Jun 05, 2012 | Mitsubishi WS-55909 55" Rear Projection...
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
WD-65734 Mitsubishi TV won't turn on. System reset
Are there any lights lit on the front of the TV? Have you checked for a bad lamp? When you reset the TV the timer/power light should flash on and off rapidly for 60-70 sseconds. Does that happen?
Aug 26, 2011 | Mitsubishi WD-62526 Projection TV
Mitusbishi WD73833 won't power on. Replaced the power board with one from Mitsubishi and it still won't power on. Help!!!
These tvs are known to have sensor issues. EX: door lamp sensor failure. Thermal fuse failure (above bulb)....Check all sensors on the tv and replace with new and you will be up and running again.
Lastly, always double check all connections and check the bulb ballast as well.
Thank you and best of luck!
Jul 11, 2011 | Mitsubishi WD-73833 73" HDTV
Timer light flashes tv won`t turn on. mitsubishi model #55859
You have a bad DM board - the capacitors are bad and need to be replaced. I was able to replace them myself. There are no replacement parts available and many repairmen will charge hundreds of dollars and there is no guarantee they will fix it.
Jul 06, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Televison & Video Logo
75 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
