Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Keypad code will close the door but not open it.
Our keypad entry and remotes have been working fine for about 5 years. Now when we enter the code into the keypad it will only close the door. The door will not open by using the keypad. We have already replaced the batteries. Any suggestions?
    Problem Solver:
  • 10 Answers
Check that both codes (in the remote & garage door opener) are the same. Press reset on the opener and reset enter the code.
Posted on Nov 05, 2008
Tried to reprogram security code for outdoor key pad on 1/2hp craftsman garage door opener according to instructions online, pressed learn button- put in new 4 digit code-held enter. Lights did not flash...
Seems you've done everything right. Press and immediately release the smart/learn button and then walk over and key in a 4 digit code and press enter. If you are sure the battery in the keypad is good then I think your keypad is on the fritz or the wrong one for that opener.
Apr 19, 2011 | Sears Craftsman LiftMaster Chamberlain...
Model 940CB/67LMTrouble free for 10-12 years. Now with a new battery after code + enter it will flash about 60 times very fast will not open the door. The door opener works fine with the button on the wall...
You can try programming it but I have a feeling it is bad.
Locate the smart/learn button on the rear of the motor unit. Press and immediately release this and then walk over to your keypad and key in your 4 digit code and press enter.
If this doesn't work you will need a new keypad.
Jun 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Model 139.53684 Keyless entry doesn't work
The remotes and keypad use the receiver which is part of the logic board.'t The button on the wall is hardwired and doesn't use the receiver. You might pull the logic board and check for bad connections on the printed circuit.
Nov 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keypad door lock does not work..?
it's in owner manual. But, first you have to enter your original code and it must work. then you press the 1 button and then enter a new 5 digit code, then press the 1 button again.
Keyless Entry Keypad To unlock the driver front door (20124) , and disarm the anti-theft alarm control (19A366) , (if equipped):
  • Enter the permanent factory code.
  • Enter the owner's alternate code.
To unlock the passenger door(s), press the 3/4 button within five seconds of unlocking the driver door or luggage compartment. To unlock the luggage compartment door (40110), press the 5/6 button within five seconds of unlocking driver or passenger door(s). To turn on the courtesy lamps and light all illuminated components, lift either front door handle (22404) or press any button on the keyless entry keypad (14A626) . To lock all doors, press the 7/8 and 9/0 buttons at the same time with all doors closed. (It is not necessary to enter the key code first.) This will turn off courtesy lamps and arm anti-theft alarm control (if equipped). To program an alternate code:
  1. Enter the five digit permanent entry code into keyless entry keypad .
  1. Within five seconds of pressing last button of permanent code, press the 1/2 button within five seconds of pressing the last button of the permanent code.
  1. Enter any alternate five digit code within five seconds of pressing 1/2 button.
    • Enter a sixth digit as follows to indicate operator's memory seat setting to be set by alternate code:
      • 9/0 — no memory recall
      • 1/2 — memory seat position 1
      • 3/4 — memory seat position 2
      • 5/6 — memory seat position 3
    • After successful programming, the doors will signal by locking and then unlocking.
  • Keyless Entry Keypad Does Not Work Properly
  • Circuit.
  • Keyless entry keypad.
  • Electronic door lock control processor.
  • Open Fuses:
    • Town Car and Crown Victoria/Grand Marquis
    • Power Distribution Box (under hood)- K, 40A (Maxi)
    • Instrument Panel Fuse Panel - 17 (10A), 10 (20A), 8 (15A), 5 (15A) and 4 (10A)
  • Loose Connectors
  • Corroded Connectors
  • Oct 04, 2009 | 1995 Lincoln Town Car
    Need to reprogram key less entry. 2002 Ford explorer sport.
    Keyless Entry Keypad FAQ Ford Explorer
    The keypad can be operated with the factory set 5-digit entry code
    You can use the keyless entry keypad to
    • Lock or unlock the doors without using a key.
    • Open the liftgate window.
    • Activate or deactivate the autolock feature.
    Where the code can be found
    • This code is located on the owner's wallet card in the glove box
    • Is available from your authorized dealer via scan code
    • Is marked on the computer module
    Computer Module location
    • 1995 thru 2001 is located in the jack storage compartment in the rear of your Explorer. First remove the panel to the jack storage compartment. Towards the front of this area you should see a metal box this is your auto-lock module(way up front next to your rear left passenger seat). On the back side of this is your 5 digit code factory preset code. It is hard to get to. To see it you will have to loosen, pull, use a flashlight or a mirror but it can be done.
    • 2002 thru 2007 is in the right panel behind the middle row window. It is below the seat belt mechanism. You have to pull out the top plastic panel off, then loosen the lower panel to be able to see the face of the computer module. The code is on a sticker on the face of the module.
    Programming a personal entry code The factory set code cannot be reprogrammed but you can create your own 5�digit personal entry code. When pressing the controls on the keypad, press the middle of the controls to ensure a good activation.
    Up to three personal entry codes may be programmed to the vehicle. To create your own personal entry code:
    • 1. Enter the factory set code.
    • 2. Within five seconds press the 1 � 2 on the keypad.
    • 3. Enter your personal 5-digit code. Each number must be entered within five seconds of each other.
    • 4. Press 1 � 2, 3 � 4 or 5 � 6 to indicate which of the three personal entry code positions you wish to use.
    • 5. The doors will again lock then unlock to confirm that your personal key code has been programmed to the module.
    Tips:
    • Do not set a code that uses five of the same number.
    • Do not use five numbers in sequential order.
    • The factory set code will work even if you have set your own personal code.
    • If you program a code to a position that already contains a set code, the previously-set code will be erased.
    Erasing personal code
    • 1. Enter the factory set 5�digit code.
    • 2. Within five seconds, press the 1 � 2 on the keypad and release.
    • 3. Press and hold the 1 � 2 for two seconds. This must be done within five seconds of completing Step 2.
    All personal codes are now erased and only the factory set 5�digit code will work.
    Anti-scan feature If the wrong code has been entered 7 times (35 consecutive button presses), the keypad will go into an anti-scan mode. This mode disables the keypad for one minute and the keypad lamp will flash.
    The anti-scan feature will turn off after
    • One minute of keypad inactivity.
    • Pressing the UNLOCK control on the remote entry transmitter.
    • The ignition is turned to the 3 (ON) position.
    Unlocking and locking the doors, liftgate and liftgate window using keyless entry
    • To unlock the driver�s door, enter the factory set 5-digit code or one of the vehicle�s personal codes.
    • Each number must be pressed within five seconds of each other. The interior lamps will illuminate.
    • To unlock all doors and liftgate, press the 3 � 4 control within five seconds.
    • To open the liftgate window, press the 5 � 6 control within five seconds.
    • To lock all doors, liftgate and liftgate window, press the 7 � 8 and the 9 � 0 at the same time.
    • Note: The driver�s door must be closed. You do not need to enter the keypad code first.
    Deactivating/activating autolock
    • Your vehicle comes with the autolock feature enabled.
    Note: The autolock feature can be activated/deactivated independently of the autounlock feature.
    Before following the activation or deactivation procedures, make sure that the anti-theft system is not armed, ignition is in the 1 (OFF/LOCK)position, and all vehicle doors, liftgate and liftgate window are closed.
    *Keyless entry key pad procedure
    • 1. Turn the ignition to the 1 (OFF/LOCK) position.
    • 2. Close all doors, the liftgate and liftgate window.
    • 3. Enter 5�digit entry code
    • 4. Press and hold the 3 � 4. While holding the 3 � 4 press the 7 � 8.
    • 5. Release the 7 � 8.
    • 6. Release the 3 � 4.
    The user should receive a horn chirp to indicate the system has been disabled or a chirp followed by a honk to indicate the system has been enabled.
    Autounlock The autounlock feature will unlock all the doors when: � the ignition is in the 3 (ON) position, all the doors are closed, and the vehicle has been in motion at a speed greater than 12 mph (20 km/h); � the vehicle has then come to a stop and the ignition is turned to the 1 (OFF/LOCK) or 2 (ACC) position; and � the driver door is opened within 10 minutes of the ignition being transitioned to the 1 (OFF/LOCK) or 2 (ACC) position.
    Note: The doors will not autounlock if the vehicle has been electronically locked before the driver door is opened.
    Deactivating/activating autounlock - Keyless entry key pad procedure Your vehicle comes with the autounlock feature activated.
    • 4. Press and hold the 3 � 4. While holding the 3 � 4 press the 7 � 8 twice.
    The keyless entry touch pad can use two codes. The factory code and one
    personal code .
    To program your own personal code, select a 5 digit code that doesn't use 5 digits in
    sequence or the same button 5 times.
    Enter your factory code
    Within 5 seconds press the 1/2 button
    Within 5 seconds of pressing the 1/2 button, enter your 5 digit personal code,
    pressing each digit within 5 seconds of the previous digit.
    You can now use either code to operate the keypad
    Setting FOB to work with your vehicle
    1. Sit in car, doors closed. Electronically unlock all doors using the power door unlock switch on the driver's door.
    2. Insert key into ignition switch and turn from OFF to ON 8 times within 10 seconds with the 8th time ending in the ON position. (5 times on some models)
    3. The doors should lock and unlock by themselves to signal programming mode.
    4. Using your remote: lock the doors.
    Sep 16, 2009 | 2002 Ford Explorer Sport Trac
    Garage door will only close with keypad code it will not open
    UNPLUG THE UNIT AND WAIT 5 MIN.
    WHEN YOU PLUG IT BACK IN CLAER ALL CODES BY HOLDING DOWN THE PROGRAM BUTTON FOR 20 SECONDS.
    NOW TRY TO PROGRAM EACH REMOTE AND KEYPAD - IF THERE IS STILL A PROBLEM CHANGE THE BATTERIES AND REPEAT THIS PROCEDURE.
    I HOPE THIS HELPS
    Mar 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
    Wireless Keypad wont allow use of other door openers
    hit learn button for 10 seconds. now nothing will work except wired buttons. Hit learn for 1 second and put in yur 4 digit keypad code and hit enter, light on motor will blink twice. hit learn again for 1 second and push button on remote. again bulb will blink. continue pushing learn for 1 second and adding another remote.
    Dec 26, 2008 | Sears Craftsman LiftMaster Chamberlain...
    Door close with wireless remote entry but will not open
    It sounds like this remote has lost its program! you will have to reprogram it!I hope this helps ya!
    Dec 15, 2008 | Sears Craftsman LiftMaster Chamberlain...
    Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
    306 people viewed this question
    Top Sears Building Materials Experts
    Glenn Mayer
    Glenn Mayer
    Mike
    Are you a Sears Building Material Expert? Answer questions, earn points and help others
