Question about Refrigerators
I have a Kenmore Coldspot refrigerator model 59202992, with 2 problems, no water dispenses, and bigger problem. Water leaks at icemaker before filling the trays. Is there a diagram to show if the water line in the freezer should be movable or if it is broken )It is open on top side of line
  • jandrmillsap Mar 18, 2009
    I have the same fridge. Same model number and cannot find a manual.
    Any help would be appreciated. All I get is----invalid model #. Well
    the number on the fridge is 59202992.
  • 83 Answers
Http://fixitnow.com/wp/2008/08/11/how-to-repair-a-leaking-evaporator-in-your-refrigerator/
go to that link and solv your problem
Posted on Nov 05, 2008
  • 507 Answers
Try this diagrams as well
or try this:
Product questions
Call 1-888-KENMORE (1-888-536-6673).
    President:
  • Refrigerators Master
  • 2,651 Answers
Could be a few different things.not a valid model number unable to look diagram up on sears. com .there is a fill tube leading to the ice maker assy that can be removed from behind the machine, but from your description its leaking out into the freezer before hitting the ice maker?? id check the fill cup(white plastic cup at fill tube end) on the ice maker itself perhaps its frozen preventing water from entering the ice mold. as far as water not dispensing its possible that the tube itself is frozen with in the fresh food sect. you can have a bad water inlet valve as well. you can access the valve behind your refrig, and by removing the plastic fittings ( one feeds the ice maker and one feeds the water supply) you can depress the actuator and see if your are at least getting water to behind the refrig ,if not you have a bead water valve, if you are getting water you'll know your line is frozen within the refrig somewhere
    Genius:
  • 1,011 Answers
Sir,
The first thing you want to do is to remove the water line going from the water valve at the rear bottom of the refrigerator up the back wall into the top of the freezer section and then into your ice maker. Blow through this line an tell me if it is clear.
click this link for list of all problems....check out
http://fixitnow.com/wp/2005/04/22/kenmore-refrigerator-bottom-of-door-collapsed/
thanks
good luck
  • 3,037 Answers
The hose or tube that is in the freezer is probably broken or came disconnected. you should be able to take apart the ice maker to find it and determine the actual cause of your problem
Let me know if you need further help with this, especially taking it apart, it should be fairly basic with only screws needing to be removed
  • 958 Answers
Check the tube that comes to the ice maker..sometimes there is ice formed in there that would prevent it from falling to the tray.
tnx 4 using fixya,
drcool
  • francis rivero Nov 05, 2008
    no water dispense....
    please check the solenoid at the back if it is engaging for the water to come in to dispense. other wise, the micro switch at the dispenser could be faulty.
    tnx again 4 using fixya,
    drcool
Kenmore coldspot model 5155 2101 we just replaced the ice maker. I can fill it with water, it freezes and dumps but does not refill. the water dispenser on the door works fine
From what you are stating this is a dispenser refrigerator with 1ce/water through the door. This type refrigerator has a dual sided water inlet valve. It looks like the half that fills the icemaker may be bad or may have the power connector that came loose. This is the part on the back that the house water line connects to. It should 2 wires going to each of the 2 coils (total 4 wires). If wires are connected, I would say 1 coil is bad and the valve needs replaced. Since you already replaced the icemaker that rules that problem out.
Apr 12, 2015 | Kenmore Refrigerators
Kenmore coldspot model 105-56532400 ice maker leaking water. How to fix?
The water supply solenoid valve may be malfunctioning or the fill tube to the icemaker may be mis-positioned.
Mar 01, 2015 | Kenmore Refrigerators
Kenmore Coldspot Model 51572200 is leaking water all over the floor
On the bottom rear of the refrigerator as you are looking at it from behind the left side where the water is feeding into there should be a double valve. 1 is for the water and the other to the icemaker. Many times that valve won't shut off, however the switch that dispenses the water is evidentially bad and needs to be checked if it is stuck open.
Jun 03, 2017 | Kenmore Side by Side Refrigerator
I have a kenmore coldspot side by side water comes out dispenser but there is no water flow up to ice maker,also just replaced dual water celanoid
Hello, so you just replaced the water inlet valve correct? Here is a video on how to test the icemaker by removing the cover of the icemaker and connecting the L to the V water should immediatley come from the water inlet valve to the ice tray. If it did not and you heard the water valve actuate then there would be an issue with the icemaker in the unit. click this link http://www.youtube.com/watch?v=AlYCJr9dc3E if you have any further questions message me back Thanks
Rick
Sep 11, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My icemaker quit working. Water does not come in to fill the tray. Water source is turned on. In door water dispenser works fine. What should I do to troubleshoot? I don't hear the solenoid click in...
have you checked the inflow tube to see if it's iced up? if your icemaker isn't filling with water and your getting water in the dispenser your feeder tube is probably frozen
Apr 11, 2011 | Kenmore Side by Side Refrigerator
I have a Kenmore Coldspot Model #78187891, with a leaky icemaker problem. The icemaker seems to leak near the front of the icemaker (closes to freezer door) and makes these stalactite structures. This...
Most likely ice maker is the problem and would need replacing. Water valve is letting to much water in but the amount of time solenoid stays open is controlled by the ice maker
Sep 28, 2017 | Kenmore Refrigerators
I have a leak inside my Kenmore Coldspot Model # 106 72104100. It is not coming from the icemaker.
If the water filter is old the seals will leak into the evaporative tray overflowing it. Replace the filter or give it a turn to bypass.
Jan 26, 2011 | Kenmore Refrigerators
Kenmore Coldspot 10650522100 - water not getting to icemaker
look and inspect closely why the water is not going down the ice tray. maybe the soft hose to lead the water down to the tray is kinked or broke.
check also if there are still ice in the tray, they could have not dropped yet that is why water is just overflowing on the tray.
tnx 4 using fixya,
drcool
Sep 19, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
978 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
