Question about Canon Office Equipment & Supplies
Communication failure error between computer and printer
  • keefc12 Nov 05, 2008
    Hi, I can scan ok but not print..got a new cable and same problem still occurs. thanks for assistance.
    Master:
    Sergeant:
  • 461 Answers
Try to check your cable. Not sure if what canon model you are using, but below link might be useful for you to get more information
http://etech.maiila.com
all the best....
Posted on Nov 05, 2008
Error Code: E197 0000 in cannon 2900 printer
Printer engine communication error
Erroneous communication between the DC controller PCB and image processor PCB was detected.
- Check the connectors of the DC controller PCB and image processor PCB.
Replace the DC controller PCB for normal connection. - Replace the image processor PCB.
E197 0000 Laser Driver PCB communication error
Description :
Description Error in communication with the Laser Driver PCB (communication data failure)
Causes :
Solutions :
Remedy
1. Check the Laser Scanner Unit connector.
2. Replace the Laser Scanner Unit.
3. Replace the DC Controller PCB (PCB1).
Nov 16, 2017 | Cannon Office Equipment & Supplies
Tip
CANON iR2016/2020 ERROR CODES
E000 0000 Fixing temperature abnormal rise
E001 0000 Fixing unit temperature rise detection (by main thermistor)
0001 Fixing unit temperature rise detection (by sub thermistor)
E002 0000 Fixing unit temperature insufficient rise
E003 0000 Low fixing temperature detection after standby (by main thermistor)
0001 Low fixing temperature detection after standby (by sub thermistor)
E007 0000 Fixing film rotation error
E010 0000 Main motor rotation error
E019 0001 Waste toner full detection
0002 Waster toner full detection sensor failure
E052 0000 Duplex unit connection error
E100 0000 BD cycle out of range
E197 0000 Erroneous communication with printer engine
E500 0001 Finisher communication error
E520 0000 Offset error
E531 0000 Stapling error
E540
0001 Paper surface not detected (standard tray)
0002 Not moved within the specified time (standard tray)
0003 Sensor not reached within 3 seconds (standard tray)
0005 Encoder clock failure (standard tray)
E542
0001 Paper surface not detected (optional tray)
0002 Not moved within the specified time (optional tray)
0003 Sensor not reached within 3 seconds (optional tray)
0005 Encoder clock failure (optional tray)
E575 0000 Stack delivery error
E584 0000 Shutter failure
E716 0000 Erroneous communication with optional cassette
E719 0000 Erroneous communication with card reader (serial communication)
0002 Erroneous communication with coin vender (serial communication)
E733 0000 Erroneous communication between controller and printer
E736 0000 CCU communication error
E739 0000 Erroneous communication between controller and network board
E744
0001 Language file/boot ROM/USB memory error
0002
0003
0004
E805 0000 Fan failure
E808 0000 Fixing drive circuit failure
on Aug 03, 2010 | Office Equipment & Supplies
My printer wont print at all
Are you able to make a copy using the copy button on the printer operator panel? If not, try to reseat your cartridges into the cartridge carrier. If yes, then the problem could be due to a communication failure between the printer and your computer.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Disconnect the printer from your computer. Reboot your computer. Unplug and re-plug your printer into the power source to reset it. When the printer turns on, reconnect it your computer. Try to print again.
You can also try to re-install the printer driver on your computer to repair any possible corrupted files necessary for printer communication and processes.
Jun 15, 2011 | Lexmark X1270 All-In-One InkJet Printer
Printer will not communicate with computer. tried unplugging it also unplugged computer and tried restarting. Green light blinking and alternating betwee 1,C,E. Amber light blinking at bottom left
The error indicates a communication failure between one of the cartridges and the printer. Try to check which cartridge is causing the error by inserting one cartridge at a time. Replace the cartridge(s) causing the error. If error continues, you can also contact Lexmark technical support to further investigate the problem. Thanks.
Sep 17, 2010 | Lexmark X2600 InkJet Printer
Where can i get the codes canon ir 2016 series.
Hi, here you go:
E540
E542
E744
0002
0003
0004
Jul 16, 2010 | Canon Office Equipment & Supplies
Error U2-40 Call for Service
Clear the trouble with SIM 16.
Content CRUM chip communication error
Details Error in MCU-CRUM chip communication
Cause CRUM chip failure
Developing unit contact trouble
MCU PWB failure
Check
and
remedy
Replace the CRUM chip.
Check installation of the developing unit.
Replace the MCU PWB.
Remarks CRUM communication error
Jul 06, 2010 | Sharp AR-M237 Digital Copier
I want to find out what a report suspended error 0008 is and how i can get rid of it. Canon photocopier 2018i
ARE YOU SURE THAT IS E008?
hERE ARE THE ERROR CODES FOR 2018
E196 0001 Error on writing and readout ROM of image processor PCB (main ROM).
0002 Error on writing and readout ROM of image processor PCB (option ROM).
E261 0000 Zero-cross signal error
E540
E542
E730 0000 Inside error of the image processor PCB (PDL system error)
E744
0002
0003
0004
Sep 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Download standby error
Canon iR2016 / iR2016J / iR2016i / iR2020 / iR2020i Код ошибки Субкод Описание E000 0000 Fixing temperature abnormal rise E001 0000 Fixing unit temperature rise detection (by main thermistor) 0001 Fixing unit temperature rise detection (by sub thermistor) E002 0000 Fixing unit temperature insufficient rise E003 0000 Low fixing temperature detection after standby (by main thermistor) 0001 Low fixing temperature detection after standby (by sub thermistor) E007 0000 Fixing film rotation error E010 0000 Main motor rotation error E019 0001 Waste toner full detection 0002 Waster toner full detection sensor failure E052 0000 Duplex unit connection error E100 0000 BD cycle out of range E197 0000 Erroneous communication with printer engine E500 0001 Finisher communication error E520 0000 Offset error E531 0000 Stapling error E540 0001 Paper surface not detected (standard tray) 0002 Not moved within the specified time (standard tray) 0003 Sensor not reached within 3 seconds (standard tray) 0005 Encoder clock failure (standard tray) E542 0001 Paper surface not detected (optional tray) 0002 Not moved within the specified time (optional tray) 0003 Sensor not reached within 3 seconds (optional tray) 0005 Encoder clock failure (optional tray) E575 0000 Stack delivery error E584 0000 Shutter failure E716 0000 Erroneous communication with optional cassette E719 0000 Erroneous communication with card reader (serial communication) 0002 Erroneous communication with coin vender (serial communication) E733 0000 Erroneous communication between controller and printer E736 0000 CCU communication error E739 0000 Erroneous communication between controller and network board E744 0001 Language file/boot ROM/USB memory error 0002 0003 0004 E805 0000 Fan failure E808 0000 Fixing drive circuit failure
Apr 10, 2009 | Office Equipment & Supplies
Canon IR2018 E007
E007 Fixing film sensor failure
The fixing film sensor is faulty. - Check the connector of the fixing film
sensor.
- Replace the fixing film sensor.
- Replace the DC controller PCB.
you need to call a canon technician to sort it out
Mar 22, 2009 | Toshiba e-Studio162D Copier
System error E808
0002
0003
0004
Mar 22, 2009 | Canon CLC 1140 Copier
old marine
old marine
