Question about Motorola Mobility MING A1200
There is G where my bars were phone not dialing out
Phone not dialing out there is a g where my bars were located
  • mcqueensgurl Dec 10, 2008
    The G is still there
    Problem Solver:
  • 3 Answers
Make sure that the antenna is set to on. then turn your phone off & back on. when it turns back on it should say search and then the bars telling you have service will pop up.
Posted on Dec 08, 2008
Call barring code spice m4580
if your phone doesn't have incoming call barring and outgoing call barring, You can try this.
For outgoing call barring dial *33*barcode*# and pres OK.
To deactivate it dial #33#barcode*#.
Oct 11, 2016 | Cell Phones
Kyocera cell phone is dropping calls
You could be in a location with bad coverage/reception (few or no bars). Try moving to a location with better coverage.
You might also need to reboot your phone. Try turning it off by holding down your power button (depending on your model you might need to select "turn off" from a menu after that). Remove your battery and wait 30 seconds to a minute. Replace your battery and turn your phone back on. Wait for it to finish booting and try your call again. Hope this helps!
Mar 21, 2014 | Kyocera Cell Phones
I need instruction manual to program speed dial
I was unable to locate a user manual for that particular device, however the basic instructions for programming speed dial functions are normally very similar between most phones.
Generally there are ONE TOUCH Speed Dial buttons labelled something like M1, M2, and M3 on the dial pad somewhere.
There should also be another button labelled PROG or STORE on the keypad as well.
Normally to program a number into a ONE TOUCH speed dial memory location you carry out the following procedure:
Lift the handset.
Then press the PROG (or STORE) button.
Now just use the number keypad to dial the full telephone number that you want to store in a Speed Dial location.
Once the full telephone number is dialed, then push the M1 button to store that phone number in the M1 One Touch Speed Dial location.
The phone may or may not show some kind of confirmation that the M1 location was just programmed, then just hang up the handset.
Now when you lift the handset and press the M1 button, the phone should automatically dial the phone number you programmed into it.
Now just repeat the same process for the M2 and M3 One Touch Speed Dial buttons with other phone numbers if necessary.
To change one of the Speed Dial numbers, just carry out the normal programming procedure for that location using the new phone number and the old number will simply be overwritten.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Dec 02, 2011 | Southwestern Bell FM-480 Corded Phone
I have sony ericsson xperia x10. I can call local numbers but if I dial an international number, its rejected with a message: "call barring is on, cannot make outgoing calls". I tried...
International call barring service key is 331. Try and check for barring status by entering *#331#
It shall respond something like "Call barring / international outgoing / all calls on" (or off)
If status is "on" you may want to deactivate barring by #331*code#
where code is your key to supplementary service activation deactivation.
If it is still unsuccessful ask yourself: did anyone activate international call barring on your phone?
Barring services can be activated by subscriber as well as the telco. In the latter case you will not be able to deactivate the barring.
BR
Laszlo
Sep 04, 2011 | Sony Ericsson XPERIA X10 Cell Phone
I have a mobile of spice model no m4330 .from todaymy incoming calls are barred .if anyone dial my number it answeres that the number is busy . my outgoing calls are running smoothely.pls help me to break...
To cancel bared incoming calls on your phone, enter one of the code given below.
##67#, ##21#,##62# or ##61# then okay/send/yes. the phone will be unbarred.
Regards
Jun 25, 2011 | Cell Phones
Message barred sony ericsson k320i
Hi, i will give you the code to know how to know when to unbarr or barr calls.
For barred calls : Dial *33*0000#
To Remove barred calls: Dial #33#0000#
Your done.
Hope it helped...
Feb 11, 2011 | Sony Ericsson K320i Cellular Phone
I got error message on 2 Avaya 5610SW IP phone: one is showing: incompatible Disc and another shows:Call Barred Disc. I have no clue to issue. is there anyone can help me out?
Incompatible means that what you dialed is not recognized by the system.
Call barred means your phons is restricted from dialing whatever you are trying to dial (900 numbers etc)
Aug 11, 2010 | Avaya 5610 IP Phone
Nokia 2630 call barring password
How do I bar just one number from my phone (text msgs & phone calls)?
Sep 01, 2009 | Nokia 2630 Cell Phone (Unlocked) - Black
I9 phone won't recognize sim card and dial out or receive
In any other phone the shiny gold bars go face-down, but with the i9, the gold bars face up-wards.
Jul 07, 2009 | Dual Electronics CECT P168 Cellular Phone
I can dial out calls but not receive them what do i do?
That has something to do with the CALL BARRING feature of the phone. Your going to have to deactivate the "Bar incoming calls". Find the option to do that somewhere in the phone settings. The exact location of the option depends entirely on the model of the phone, but it shouldn't be that hard to find.
Jul 24, 2008 | Lands Phones
Motorola Mobility MING A1200 Logo
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Unlockingcom
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
