Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
RESET DEFROST TIME
MY FRIDGE IS GOING INTO DEFROST CYCLE DURING THE DAY POSSIBLY BECAUSE OF A POWER OUTAGE A FEW WEEKS AGO.
ON MY OLDER UNIT THERE WAS A DIAL BEHIND THE COOLING GRATE THAT I WOULD HAVE TO CYCLE THROUGH THE RANGE
AND BACK TO ZERO TO RESET IT, BUT I CAN'T SEEM TO FIND IT
ON THIS ONE.
THANKS, RICH SPIVEY
  • 958 Answers
Please check you model. if it is a new model. most likely it is now using the adaptive defrost which is controlled by the pcb. no more mechanical timer.
if you will find the diagram and it would say you have a timer. you can look at the front, if you take the front grill off. sometimes they are located at the center wall between the drain pan and the condenser.
tnx 4 using fixya,
drcool
Posted on Nov 05, 2008
I am wondering if that is just going to continue and need to replace entire washer?
Unless the machine is over 25 years old or is being used more frequently than once a day I would maintain the machine doing as many repairs as possible myself or if available have a reasonable repair service I would still consider maintaining the machine. I'm amazed at the reliability of the older units.
Many of the repair parts have had the corrections made to prevent them from failing for the same reason. This will increase the reliability of the older machines. Also in general the older units are less complex (less things to fail) and easier to repair. You should expect that a newer machine, using significantly more complexity, uses less water and electricity to achieve the same cleaning performance as an older machine.
The control electronics have an indefinite life meaning they fail for components on the board not because they wear out or get old. The likelihood of a new/replacement board failing is consistent with the likely hood of a brand new machine failing. As the control boards age they are less likely to fail.
Using u-tube and fixya and other sources of repair knowledge the older machines have a wealth of experience to bring to solving the problem The newest technology machines will have to go through the learning curve.
The question is will a new machine perform the job significantly better than the unit you have.
Dec 30, 2015 | Washing Machines
How do I reset the control panel? Other ideas?
Hello. If your unit is running continuously, the timer/control board is defective and needs to be replaced. I need the make/model number to help you accurately. If you have the mechanical timer(round knob that turns), it's not advancing(no repair possible). If the unit has an electronic control, the program quite possibly is corrupted--or a relay is stuck causing the problem. Have you had a power outage recently--3-4 weeks ago? These are notorious for damaging the control boards from the current surge when power is restored. I hope I helped you--definitely give me the model number, thanks!
Oct 17, 2015 | Dishwashers
Why aren't refrig and ice maker working?
You need to allow the fridge to fully defrost now. (Even if it is a ''frost free'' unit that doesn't require ''defrosting''). If the fridge was closed during most of the power outage, it partially ''melted'' and then _froze_ solid when the power came back on. Let it totally defrost, unplugged _with doors open_ for 24 hours and it will be ok. (I realize that is a problem with food, but it must be done).
Aug 16, 2015 | Maytag Refrigerators
Frigidaire GLHS269ZCB4 after power outage Freezer not cooling fridge warmer hear the fan click and short cycle
Hello Wayne, thank you for allowing me to assist you. Was the freezer unplugged during the power outage? If it was, here are some simple troubleshooting steps you need to take:
It is best to unplug the unit and wait for the power to come back on.
Next, turn the control to off (or digital display), plug the unit in and reset control to factory-suggested setting.
Do not open freezer door unnecessarily if freezer is off for several hours. Make sure the refrigerator plug is tightly pushed into electrical outlet and not plugged into a GFI.
If your unit has no power and it is not due to a power outage, check the following:
Verify that the temperature control is set to the OFF position.
Set temperature controls to proper setting suggested by your owner's guide; or set to the halfway point and adjust it up or down as needed.
If these basic troubleshooting tips prove ineffective, the power loss may have possibly caused a communication problem with the control board, temperature control or wiring harness. At this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
Aug 23, 2013 | Frigidaire FRS26KR4A Side by Side...
Mini Fridge crackling noises in freezer compartment
If this is a new unit there should be no "crackling" noise. I would suggest calling for a repair since the unit should be under warranty.
Mar 31, 2012 | Magic Chef Refrigerators
Why does my fridge trip the power on defrost cycle?
have a technician come in and do an insulation test on the unit
the very smallest insulation leak will trip the RCD unit in the breaker
Sep 13, 2017 | Refrigerators
Drain in freezer plugs up
sometimes can be solved by loosely coiling a piece of solid copper wire around the defrost heating element and down into the drain a little. the radiant heat on the wire during defrost cycle may help keep the drain open
Mar 13, 2009 | GE Refrigerators
Refrigerator and freezer not getting cold enough
If the problem just gradually started happening, it's possibly the defrost cycle that's not working right. Fridge doesn't defrost, the cooling system ices up, and the cold air can no longer travel through the fridge.
You can tell that's the problem if you fully defrost the fridge (turn it off for a day), then start it up again. If it works OK for a while, then does the same thing after a few weeks that's what it is. Either way, you need a repair person to fix it, or you need to defrost it regularly, but then what do you do with your food while you do that???
Nov 17, 2008 | Magic Chef CTF2125 Top Freezer...
My Zanussi fridge/freezer is making a funny little noise
What you may be noticing is the system going through a defrost cycle. Check the time of the day that you notice this event. If it happens at the same times it could be a normal situation if at all other times normal temperatures are being maintained. A popping sound can be caused by thermal expansion during the defrost.
Sep 13, 2008 | Freezers
I have an older fridge freezer which has 3 lights in fridge ,1 for if ive left the door open, 1 for i think tempreture and 1 with an s on also a on/off switch.I just purchased this 2nd hand and its great...
What make and model is this unit. It sounds like it could be an error code. Possibly a thermal fuse or something in the defrost cycle. Try unpluging the unit for 15 mins and plug it in again. It will at least reset it and it may run until it hits the defrost cycle again. You are most likely going to require service.
Sgt 48
Jun 02, 2008 | Zanussi Refrigerators
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
123 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
