Question about Electrolux Refrigerators
Hi i need a condensor fan for and electrolux model GLRT217TDSN refrigerator.
    President:
  • Electrolux Master
  • 2,651 Answers
241712101--- heres the part number call your local suppplier or go sears .com to order it
Posted on Nov 05, 2008
SY EF electrolux
Hi daneilb101 - Typically error code SY EF indicates that the refrigerator has detected an evaporator fan circuit failure. Contact a professional to move forward accurately. The wiring between the main control board and evaporator fan will need to be check and diagnose. Depending on the diagnoses the main control board may need replacing.
Feb 22, 2013 | Electrolux 25.9 Cu. Ft. Side-by-Side...
SAMSUNG RS2534WW CONDENSOR FAN NOT WORKING
Was the motherboard replaced because the temp was too high? May be the condenser fan was at fault all the time. Check you have power at the fan. If you have, replace the fan. If you have not, take a live from the compressor to the fan. This will bypass any hp or fan speed control switch and run the condenser fan with the compressor.
Apr 20, 2012 | Samsung RS2630SH Side by Side Refrigerator
My GE GSL 25JFPABS Refrigerator failed yesterday. No Comressor no evap or condensor fan
Fan motor starts with the compressor. Sounds like you need a main board and condenser fan motor. Call GE. It might be covered under warranty. A known issue with certain models. You will also need serial # if you call.
Mar 23, 2017 | GE Refrigerators
Condensor Fan blade is broken, a new one has been ordered. Can I disconnect the motor until new one arrives?
Yes you can BUT.... you will need to use an external fan directed at the rear of refrigerator with the fiberboard cover removed. If you do not use an external fan the chassis of the refrigerator will get hot to the touch and the freezer will warm up. Ice-maker will probably stop working and ice-vream will get soft due to the rise in freezer temp. Just use a small external fan directed at the condensor coils and it will work fine until you get a new fan. There is the possibility that you might get an error code saying the condensor fan is open. You made no mention of a model number and the more advanced units will error. If you experience this error problem... just remove the fan blade and let the motor run BUT you will STILL have to use an external fan until you get a new fan blade.
Thanks for choosing FixYa,
Kelly
Apr 27, 2011 | GE Refrigerators
Frig stopped cooling. Bad condensor Fan Motor.
sounds like a bad thermostat,that tells unit when to kick on and off.
May 15, 2009 | Maytag Refrigerator Light Switch -...
Subzero 630 hot door jamb
If the door jambs are hot, that is either a dirty condensor or a dead condensor fan motor. Make sure the condensor is vacuumed and check to see if the condensor fan is spinning. It should be running anytime either compressor is on. You can clear the service light by holdint the "alarm: button for 15 seconds or turning the unit off and then on again.
Jun 21, 2008 | Sub-Zero 650 / O Bottom Freezer...
Hot to the touch
Kathy, you probably have a condensor fan that failed. Remove the lower back panel behind the refrigerator. You will see the condensor, condensor fan and compressor. The condensor fan should be running any time the compressor is running. You might have something stopping the fan blades or the motor might be going bad itself. What you are describing is a classic example of a failed condensor fan motor. Catriver.
Apr 19, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Electrolux side by side fridge feezer model number:enl62981ks3
The condensor fan motor has failed. For now remove the back panel of the refrig and make sure that the blade hasnt fallen off the motor. If the motor is bad put  a fan back there so the compressor wont fail next.
Oct 15, 2007 | Refrigerators
Refrigerators Logo
52 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
