Question about Honeywell Programmable Thermostat Heater
Thermostat displays 79 deg but really 68 in room
For some reason the room tempature shows 79 deg but the room is 68... Therefore, when I have my settings at 72 it won't turn on since it thinks the room is 79.
  • gamblejustin Nov 05, 2008
    Honeywell T8001C model by the way
  • 1,420 Answers
If the thermostat does not have a reset, replace it.
Posted on Nov 07, 2008
What does it mean when the aux is flashing on my thermostat?
I assume that you have a heat pump system. If this is the case, the outside temperature is probably lower than the heat pump is sized for and it is using the auxiliary heating system to keep up. The auxiliary heating system usually is an electric coil in the heat pump unit which supplements the heat being produced by the heat pump. This is normal operations and does not indicate a problem with the heat pump, it is just really cold outside. If it is not colder than usual outside, there may be a problem with the heat pump and you should call a heating contractor to check it out.
Jan 10, 2015 | Emerson 1F89EZ-0251 Blue 2" Thermostat,...
WATER COMING THROUG FRONT OF FUJITSU fan coil unit
vent pipes are not sealed properly and condensation is building up and leaking out .
Jun 10, 2017 | Fujitsu 12RLS Halycon Wall Mounted Air...
Buzzing and f2 showing on display panel
The F2 error code means that the over overheated by at least 100 degrees above the tempature that was set at the time. The usual reason the oven would over heat by so much is a defective oven tempature sensor and the sensor would need to be tested to see if is the problem to test the sensor it would need to disconnected from the wiring to it and measure the amount of ohms of resistiance AT ROOM TEMPATURE when the oven is off and cool. At room temp. the the meter used to check the sensor should display between 1060-1100 ohms,if the number is vastly different that 1060-1100 at room tempature the sensor is defiently bad and should be replaced. This is what the sensor looks like oldtech2332_129.jpg
it will be inside of the oven chamber and again to properly check it the wiring should be unplugged and the meter leads should be placed into the plug at the end of the sensor to measure the ohms
GENE
Oct 10, 2011 | Amana AOCS3040 Electric Single Oven
GR448LXPS ERROR CODE E2F3
The F3-E2 error code means that the heated well above the setting the tempature was set at. The usual reason the oven would over heat by so much is a defective oven tempature sensor and the sensor would need to be tested to see if is the problem to test the sensor it would need to disconnected from the wiring to it and measure the amount of ohms of resistiance AT ROOM TEMPATURE when the oven is off and cool. At room temp. the the meter used to check the sensor should display between 1060-1100 ohms,if the number is vastly different that 1060-1100 at room tempature the sensor is defiently bad and should be replaced. This is what the sensor looks like oldtech2332_129.jpg
it will be inside of the oven chamber and again to properly check it the wiring should be unplugged and the meter leads should be placed into the plug at the end of the sensor to measure the ohms.
If after checking the sensor if its within the range of 1060-1100 ohms at room tempature the problem is going to be the control board.
I hope i have been able to help ya fix your oven,
Oct 08, 2011 | Whirlpool Ovens
Keeps making ice and fills up bin. I checked the bin thermostat and it is plugged in and does show some resistance. House is not too cold but is about 65-68 deg.
Usually the system continues It's operation when the thermostat is defective,Replace thermostat and check the operation of the system.
Nov 30, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Honeywell CT500 Electronic Thermostat showing 73 deg room temp when room temp is actually 77 degs. Can thermostat be calibrated?
Yes,
Most all the Honeywell t-stats can be calibrated...
check out this tip to find the manual for your t-stat and then how to get into the installer setup program...
Manual Honeywell How to Find Honeywell Manuals
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
heatman101
Aug 13, 2010 | Honeywell CT500 Digital Heat / Cool Manual...
Temp setting way off kenmore 580
Remove the window unit and dissasemble,and clean it out,careful not to bend the fins on the condense and evaporator,but clean them out,and the inside of the unit also,then see what happens,if the problem persist,then find the probe on the evaporator and move it away from the evaporator until the compressor stays on longer.
May 27, 2010 | Kenmore Single Room Air Conditioner
Chronotherm III displays 32 deg for room temp, which is really around 70 deg. No action called for by the instrument. Batteries had died and replaced. My first guess was the actual temp sensor was...
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Apr 28, 2010 | Honeywell Electronic Programmable...
I can not change the thermostat setting on the unit. Whenever I try to change it, it reverts back to the previous setting.
The thermostat will display the current tempature in the room. When you press the buttons to change the tempature and you see it change back it is probably going back to the room tempature display but still keeping the temp you set it at. Also make sure the "hold" feature is set or the temp you choose can change at different times during the day due to the programmable features built into the thermostat.
Sep 08, 2009 | Honeywell Heating & Cooling
Thermostat issue with comfort zone II.
Is this an electric or gass furnace - Eather of these can can have this problem its most recomendable that you call a seviceman .
in the case of electric furnace you may requier a new heat sequencer. And in the case of gass you may requier a new relay.
Feb 18, 2009 | Carrier 38CKC060 Air Conditioner
Heating & Cooling Logo
295 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
