Question about Brother ML-100 Typewriter
Trying to get the margin move to the left or right beyond where it is set.
When I try to move the margin to the left beyond where it is set, it seems to be stuck where it is and won't move. I hit the "code" key and then hit
the # 7 key where the L mar label is above it, but nothing happens. There is no manuel, so can you help me? Is there something broken?
Try touching the margin release key, back space to the new location then hold down the code key while pressing the 7 key.
Posted on Nov 06, 2008
How do I set or change the margins on my Royal Safari typewriter?
If you are following user's manual instructions to reset the margin and can't, maybe your Royal Safari is defective? Insist trying and if still no luck try to ge a typwriter repairman, a species in near extintion by now.
Jul 02, 2015 | Royal Office Equipment & Supplies
How do I increase the margins on the typewriter
To set a margin beyond the left or right margin, move the carrier (or cursor) to that margin, press the Margin Release key, then proceed to move the carrier (or cursor) to the desired position. Then, press the Left or Right margin key to set the new margin. A beep will sound indicating the new margin has been set. When you set a new left or right margin, the previous margin is automatically cleared.
Alternatively, you can type beyond the right margin by pressing the Margin Release key and then continue typing when the carrier (or cursor) stops at the right margin. To type beyond the left margin, press the Margin Release key and then the Backspace key to move the carrier (or cursor) to the position where you want to start typing.
Remember to always use genuine Swintec ribbons and lift-off tapes for your Swintec 7040, which can be found at Swintec Typewriter Supplies .
Aug 19, 2014 | Swintec 7040 Typewriter
How to reset the margins on Brother EM-530
On most electronic typewriters you change the margins by pressing the code button and holding down the press r margin or l margin on the key board. You want the carrier to be where you want the margin set. To set margins beyond the right or left margin move the carrier to the margin and press margin release to go past the margin. Then press code left or right margin.
Jun 30, 2014 | Brother EM-530 Typewriter
How to use the margin release for Brother EM-530
Is Margin Release on it's own separate button on the EM-530? If so, then to move beyond a margin:
  • Use Return or Tab to go to the left or right existing margin.
  • Touch Margin Release.
  • Use the Backspace or Space bar to go beyond the margin in question.
  • If you want to set a new margin, then go to the location you want to have it and touch the Left margin or Right Margin button.
Some models may require the CODE key to access one or more of these functions. If the function name is not printed on the top of the key, but on its front or on the surrounding plastic above the button, press and hold the CODE key while touching that button (just as you hold the Shift key to type capitals). The CODE key might possibly have a different name; chances are it's color will match the functions it works with.
Jan 05, 2010 | Brother EM-530 Typewriter
How to set margins on Olympia compact s - is there a manual available?
use the "margin left" key to set left margin, and the "Margin Right" key to set the right margin. Move to where you want the margin to be and press the right or left margin keys. to go beyond a margin (to set margins "outside" the current settings, press the MAR REL (Margin Release) button while at the current margin
Oct 02, 2009 | Olympia Office Equipment & Supplies
I bought a --brother AX-400 electronic typewriter at yard sale... please help me set left and right margins...
Move the carrier to the desired position for the new left or right margin using "backspace" or "space"
To move beyond the position of a current margin, first position the carrier on the margin and press "alt +m rel"
When the carrier is on the desired position, press "alt + l mar" (if you are setting the left margin), or "alt + r mar" (if you are setting the right margin.)
The minimim distance between the left and right margins is two inches
Jul 18, 2009 | Brother ML-300 Typewriter
How to change the pitch?
Here ya go...
Margins and Tabs
Margins and tabs for both Type Mode and Mem Mode are set in Type
Mode, but can be changed in Mem Mode when text is recalled for
editing. Margins and tabs are set using the typing scale which appears
on the display in Type Mode. A blinking cursor indicates the typing
position. The letter “L” indicates your left margin setting. The letter “R”
indicates your right margin setting.
NOTE: In Mem Mode, the margins and tabs used when the text
is created will be saved with the text and recalled with it,
even if they have been changed.
In Type Mode, to signal that you are near the right margin, the
typewriter will beep 5 spaces before the margin. In Mem Mode, the text
will wrap automatically when you print.
Margins are preset depending on the pitch setting, which is the number
of characters per inch. They are:
10 Pitch 12 Pitch 15 Pitch
(Pica) (Elite) (Micro)
Left Margin 12 14 18
Right Margin 72 86 108
New margin settings remain until changed again.
1. Move the Mode Selector to Type. A typing scale appears on
the display.
2. Move the cursor using the Spacebar or Back Space to the desired left
margin setting on the scale.
3. Press Margin.
4. Move the cursor using the Spacebar to the desired right margin
setting on the typing scale.
5. Press Code + Margin. A beep confirms each new margin setting.
6. You can change to Mem Mode, if desired.
Take care,
Duane ONeil
Jun 02, 2009 | Office Equipment & Supplies
Resetting the margins on a manual typewriter.
I can't be for sure if these are auto set margins, but it sounds like they might be. If they are, first move the carriage as far to the right as you can. Hold the Left Margin Set (not Margin Release) lever as you move the carriage all the way to the left. Release the Margin Set Button or Lever. Now hold the Right Margin Set Button or Lever (not the Margin Release), and move the carriage all the way to the right while holding the Margin Set. Once the carriage is all the way to the right, release the Margin Set. Move the carriage to the place you want to set your left margin. Hit the Left Margin Set and then release. Move the carriage to where you want to set the right margin. Hit the Right Margin Set and release it. It gets confusing, but Margin Release does not set margins. Its sole purpose is only to bypass the margins. Hope this helps.
Feb 19, 2009 | Royal MS 25 Typewriter
Setting Margins
move the carrier to where you want the mar.set then hit the R MAR or L MAR key.
to move the carrier beyond the margins hit the MAR REL key
Nov 06, 2008 | Brother EM-430 Typewriter
What keys do I use the change the left and right margins?
You set the margins by putting the printhead where you want the margin set, and holding down the CODE key, push the key under where L MAR or R MAR is printed, (above the top keys on the keyboard) depending on whether you want to set the right or left margin.
If you want to set the left margin to the left of where it's set, hold down the CODE key and push the key under MAR REL. Then using the Backspace (or spacebar, if you backspace too far) position the printhead where you want the mar. set and holding down the CODE key, hit the key under L MAR.
Setting the right margin works the same way.
Oct 27, 2008 | Brother GX-6750 Typewriter
Brother ML-100 Typewriter Logo
James Cagle
James Cagle
Jim Keysor
