Question about Sony XM-2200GTX Car Audio Amplifier
Sony XM-2200GTX no sound but light will go on sometimes
Ok i have a Sony XM-2200GTX and everything is hooked up right i made sure the ground is right i had sound b4 everything was fine then one day turned the car on and everythin shut off is there anything i should check or buy?
  • 631 Answers
I'll assume that you've checked the amplifier's on-board fuses.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Posted on Nov 05, 2008
Can you bridge the XM 2200GTX
Yes you can but you have to read the instructions and make sure you install the correct type of speakers.
Here is the link address for the manual.
Nov 08, 2010 | Sony XM-2200GTX Car Audio Amplifier
Can you bridge a sony xm-2200gtx amp, if so what polarity on which channel. Currently pushing two speakers. trying to see if i can bridge it and use a singe speaker?
left positive and right negative-make sure the speaker that you intend to run in bridged mode is 4 ohms or you will kill your amp
Nov 30, 2009 | Sony XM-2200GTX Car Audio Amplifier
Amp makes a constant loud bump
try grounding the rca shield to see if it stops, if it does you have an rca ground problem in either your head unit or your amp
May 30, 2009 | Sony XM-2200GTX Car Audio Amplifier
Bridging problems
Normally bridging an amp is using the left + and the right -
Here is a link to your amp specs
Jan 30, 2009 | Sony XM-2200GTX Car Audio Amplifier
How do i bridge a xm-2200gtx.
Usually the Left + and the right - is bridged. Here is a link to the specs on your amp:
Amp LED light turns on then off
You need to use a multimeter to confirm that you have both B+ and remote voltage at the amp.
Oct 28, 2007 | Sony XM-2200GTX Car Audio Amplifier
Sony XM-2200GTX...Power, Green Light, All OK, No Sound!
Sony generally drives their power light from a source that does not rely on the amplifier's switching power supply. This means that it's not a good indicator as to the health of the amplifier.
As long as you have B+ and remote voltage, it will light up. Since you've tested the speaker and the signal source, I think the amplifier is likely defective.
Oct 17, 2007 | Sony XM-2200GTX Car Audio Amplifier
No power
Your ampllyfier is dead moust look one specialist and schenge
Apr 14, 2007 | Sony XM-2200GTX Car Audio Amplifier
Amp turns on and stays on but no sound
are you shure you not connect the amplifier in a wrong connection ...B+,GND,ACC.....ok...then checkif the speakers wires stay in good condicions, some times when we intalled the spk wires for the border of the doors a few times skrewered too.check if it hapen. another ....check if the terminal spk is not going at ground whit the chasis another to....4 ohms per channel ,anny voice coil spk short. good look.
Mar 10, 2007 | Sony XM-2200GTX Car Audio Amplifier
Power comes through ground
Check to c if any power wire shorting to ground
Aug 20, 2006 | Sony XM-2200GTX Car Audio Amplifier
Sony XM-2200GTX Car Audio Amplifier Logo
137 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
