Question about RCA P52771AT 52" Rear Projection Television
Rca p52771at - dark picture
I have a rca model # p52771at. chassis# ptk178lsb. the picture is turning dark.. I the show i am watching is dark then i can almost not see anything but black.
  • Anonymous May 09, 2008
    I HAVE A RCA P 52 IN P52771AT TV , MY TV IS ALSO TURNING DARK,AND MY COLORS OF BLUE ARE TURNING GREEN. AND MY PICTURE SCREEN HAS STARTED TO WARP INWARD TOWARD THE CENTER OF THE SCREEN . PLEASE HELP , BECAUSE I LOVE MY TV . ROBERT ROSE , MORGANFIELD
  • ttboi366 May 09, 2008
    my tv is getting to dark,must watch it with the curtains closed,or at night for best picture. no matter how i adjust the tint, my blue color shows in green. And lastly,my picture quality is poor,the picture is beginning to warp in toward the center of the screen.i love my tv, please help.
  • 61 Answers
Sounds like a bad screen asy,part number 204809,must use the generic,or you could have weak tubes,if so you may just need to turn up the screen drives,this part is located in the right top of the set with the back removed,if no cracks are present adj. the three marked screen's,turn the color all the way down in your menu and adj. for a black and white picture.
Posted on Mar 04, 2008
TV turns on and off while watching.
re solder the Electronic semiconductor , IC Specialy in power supply side. cold solder might the cause.
Jun 07, 2009 | RCA 27V520T 27" TV
Blue Halo and too much blue...
if its a halo such as a glo you need coolant change in the CRT, if its like a 3D effect then you need new Convergence ICs. Can you post a picyure of your screen and I will properly diagnose it for you then be better equiped to help you properly.
Apr 04, 2008 | RCA P52771AT 52" Rear Projection...
Rca model p52721lv
whats the chassis number Rca has to be cross referenced by chassis number
Mar 19, 2008 | RCA P46924 46" Rear Projection Television
Bought it off someone and now doesnt work
Whats the model number? IF its a phillips or RCA please include the chassis number
Mar 03, 2008 | Televison & Video
Rca p52771at
Sounds like you have a bad screen asy,check around the pots to see if cracks are present,part number for this item is 204809,must use the generic,the part is no longer available from Thomson.
Feb 05, 2008 | RCA P52771AT 52" Rear Projection...
RED LINES
Your red CRT socket may be loose or have cracked solder if not, try turning down the red gun screen control inside the set just a little. Youre experienceing what is known as retrace lines
Jan 21, 2008 | RCA P52771AT 52" Rear Projection...
Model; P52750WK serial; 340486076
Hit remote power button. Brief " crackling " sound, no picture. No problem with TV since new. There is a brief spark like light with sound.
Nov 21, 2006 | RCA P52771AT 52" Rear Projection...
Rca tv p52771at problems
Mine did the same thing it ended up being the splitter. About 200 bucks. And then a year later it did it again. Another 200 bucks.
Nov 04, 2006 | RCA P52771AT 52" Rear Projection...
Blue shadow RCA p52771at
hi yeh it does sound right sorry do know anybody arround there... good luck
Feb 22, 2006 | RCA P52771AT 52" Rear Projection...
Open Questions:
I own a Samsung LN40C630K1FXZA TV with no picture but has audio and backlights. I need help determining what boards to replace. I tried to watch some tutorials posted on YouTube and have the following information. The TV was starting to have an issue that while watching it the picture was seeming to get a little jerky like it wasn't refreshing fast enough. It wasn't always noticeable and I initially though it may have been a signal issue with our cable. Eventually we turned on the TV one morning, the picture came on and then disappeared after 2 or 3 seconds but we still had audio. I tried to pull up the menu screen and that was not visible. I performed the flashlight test and there are images visible with the light. I removed the back cover and took pictures of the attached boards and also saw that the backlights seemed to be working but did seem like they were not quite a constant consistantly light. They never completely extinguish but do seem to fluctuate in brightness slightly. I did not see any visible issues with any if the capacitors being swollen or blown and did not see any apparent burnt components or boards. Below are the readings I got from one board but I was not sure where to get the readings on the TCON board. Main PBA readings CN201 1. 18v. Actual 13.1v 2. Sw. Power Actual 13.1v 3. 18v. Actual 13.1v 4. 5v. Actual. Falling to -1.6mv 5. 5v actual. Falling to -1.7mv 6. 5v actual 5.15v 7. 5v. Actual 5.15v 8. ground actual 13.1v 9. Ground actual 13.1v Any help would be greatly appreciated so I can buy the right parts from you. Thanks, Chris
Jan 19, 2019 | Samsung Televison & Video
See all RCA P52771AT 52" Rear Projection Television Questions
Televison & Video Logo
213 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
