Question about Kenmore Elite 45986 Front Load Washer
HE3 Washer just keeps beeping at me when I push the start button
This has happened a few times, but then ends up working after a little while. When I push the start button on my washing machine it beeps and make clicking sounds. I tried to take the front panel off to see if I could reset it or if something was loose but couldn't get it all the way off. Any ideas before I call for a repair man?
    Problem Solver:
  • 4 Answers
Bad motor pump and it's a common problem kenmore elite front load washer so we need to left the washer from the front and get under the washer to get the motor pump replaced
Posted on Nov 05, 2008
HE3 doesn't respond to any button. Time light keeps flashing time. Pause cancel button does nothing, Cycle doesn't start. The only thing that will change is if you push a different mode ie, heavy,...
Unplug the machine for at least half an hour to eliminate the possibility of an electronic glitch. Then upon plugging in back, close the door then push CONTROL/ON (if present on this model). Select the DRAIN/SPIN cycle then select NO SPIN by pressing the SPIN SPEED button. Push PREWASH OPTION four times within five seconds. If PREWASH OPTION is not present on this model, press EXTRA RINSE four times within five seconds. C:00 will light up on the display. If the Starting procedure fails, push the PAUSE/CANCEL button then repeat the starting procedure.
In order to advance to the next step of the test procedure, push PREWASH OPTION button two times. If PREWASH OPTION is not present on this model, press EXTRA RINSE two times. The test program goes from C:00 to C:08 and should flash an error code when a problem is present. Post the code back for further troubleshooting, including the exact model number of the machine.
Sep 20, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
He3 washer will not start. The lights on the
you probably broke the door switch and the machine thinks the door is open. little piece on top of the lock catch. need to change the door switch
Feb 05, 2010 | Kenmore Elite 45986 Front Load Washer
Door won't latch and dL and F come up
your dl (door latch) is broken replace it you can order it from searsparts.com
Apr 26, 2009 | Kenmore Washing Machines
Kenmore Elite HE3 Dryer (3 yrs. old)
when u push the buttons do all lights light up if so ,, machine is in lock mode ,, press and hold the little icon that read lock for about 3 seconds unitll lights are off then run ,, let see
Nov 19, 2008 | Kenmore Elite HE4 Electric Dryer
Kemore HE3 front load washer won't start
Check you door latch. When you open the door, there should be a black square hole on the frame and a black round hole above it with a pin sticking out. The pin is probably broken off and the door latch assembly needs to be replaced.
Jun 03, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
HE3 Front loader Controls Locked
Try 'end of cycle' pushed down till the light goes off. Or locate the button with diagram of 'lock', & push down till the light goes off.
Dec 24, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Beeping
Thanks for posting this solution! I'll try it with mine.
Oct 24, 2007 | Bosch WFK 2401
HE3 lock
Have you tried pushing the door lock/unlock button? I think it may be called the "rinse & spin", and under that it says door lock/unlock.
Sep 20, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
301 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
