Question about OEM Systems Motorola Bluetooth Headset , HS820 [OEM] 98627H Headset
What is the pairing passcode for a HC-820 Motorla Bluetooth?
I lost the manual n forgot the code. i got a new phone but cant pair my old school bluetooth.HELP!!!
  • Anonymous Nov 21, 2008
    i am tryting to pair with my black berry bold it is not working how do i do that?
0000
Posted on Nov 05, 2008
HOW TO CONNECT N70 TO NOKIA HF-33W ? I HAVE FORGOT THE PASSCODE TO CONNECT THROUGH BLUETOOTH. PLEASE ASSIST
switch on your bluetooth headset . then go to settings on your phone.then click connectivity ->bluetooth-> pair device-> pair new device -> it search and ask passcode enter 0000 as pass code now it will connected still having trouble reply me
Jul 22, 2011 | Nokia N70 Cellular Phone
Forgot passcode and cant find manual so i cannot pair it with my new phone
iIf you know how to put ur device into pairing mode then most pass codes or pins\pairing codes are as follows 0000,9999,1111,or 1234 most blue toth manufactures from north america use 0000 i hope this helps but you need to know how to put ur blue tooth device into pairing mode ,usually you hold the power button on for 6 to 10 second untik u have a solid light or tone depending on the device u have..once again i hope this helps
Feb 21, 2011 | Anycom HCC-250 Bluetooth Headset
Bluetooth passcode
To find a bluetooth passcode click tis link bp
to change passcode click tis cp
to reset rp
  • Step 1 Look on the back of your headset or speakerphone for the Bluetooth passcode for the device. Typically the pairing code for headsets is printed on a sticker that is then placed on the underside of the accessory.
  • Step 2 Go into the Bluetooth menu on your cell phone to find the passcode for your cellphone. The Bluetooth menu for your phone is typically located under the "Settings" menu. In the Settings menu there should be an option to "Get code" or something comparable, which would allow you to find the code for your phone.
  • Step 3 Go into the Settings menu for your computer to find its Bluetooth passcode. Some laptops will randomly generate a new Bluetooth passcode for you each time you want to pair them with a new device. In that case the menu setting you're looking for is something like "Generate new pairing code."
  • Step 4 Look in the instruction book for your Bluetooth accessory if you cannot find the passcode attached to the device or in its menu. Many manufacturers will print the passcode for devices in their instruction book. If you still can't find the passcode, try using all zeros.
  • Read more: How to Find a Bluetooth Passcode | eHow.com http://www.ehow.com/how_5169210_bluetooth-passcode.html#ixzz0vcmCZd00
    Aug 04, 2010 | Apple iPhone Smartphone
    Ive lost my instructions for my headset device i need to know how to turn my phone to headset pairing mode
    Hello my friend,do these steps
    Pairing with another Bluetooth device
    By pairing your KU990 and another device,
    you can set up a passcode protected
    connection. This means your pairing is
    more secure.
    1 Check your Bluetooth is On and Visible.
    You can change your visibility in the
    Settings menu.
    2 Touch Paired Devices then New.
    3 Your KU990 will search for devices.
    When the search is completed Refresh
    and Add will appear on screen.
    4 Choose the device you want to pair with
    and enter the passcode then touch OK.
    5 Your phone will then connect to the other
    device, on which you should enter the
    same passcode.
    6 You passcode protected Bluetooth
    connection is now ready.
    Using a Bluetooth headset
    2 Follow the instructions that came with your
    headset to place your headset in pairing
    mode and pair your devices.
    3 Touch Yes to Connect now. Your KU990
    will automatically switch to Headset profile.
    If you have any questions you can try reading the manual here
    http://www.in.lge.com/Product/Manual/KU990.pdf
    Jan 11, 2010 | LG KU990 Viewty
    Bh 101 bluetooth headset lost manual and forgot pairing code
    Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
    Apr 14, 2009 | Cell Phones
    How do I pair plantronics explorer 233 to a new phone after its been paired to another phone
    to pair your bluetooth first, turn the bluetooth feature on your phone to on.
    Next, hold the call button on your bluetooth until the light begins flashing blue and red, this means it it in paring mode.
    Third, find the 2XXplantronics device in your bluetooth options. Select this divice and enter the passcode (0000).
    You are now finished and the bluetooth is paired.
    Mar 05, 2009 | Plantronics Explorer 220 Bluetooth Headset...
    Forgot pairing passcode for BK 600 bluetooth headset
    the passcode should be 0000 I've looked into two manuals for it I think I may have to look in to a 3rd? let me know if that didn't work and I'll triple check it.
    Thanks,
    Ekse
    Feb 20, 2009 | Cell Phones
    LG Bluetooth HBM -500 Passcode for pairing
    I HAVE LOST MY Bluetooth H500 Manual, can you assist with passcode.
    Dec 11, 2007 | Motorola Mobility HS850 Consumer Headset
    OEM Systems Motorola Bluetooth Headset , HS820 [OEM] 98627H Headset Logo
    460 people viewed this question
    Top OEM Systems Radio Communications Experts
    eradiostore
    eradiostore
    Are you an OEM Systems Radio Communication Expert? Answer questions, earn points and help others
