Mitsubishi WS-65611 65" Rear Projection Television Logo
Mark Henry Posted on Mar 18, 2012
I have a Mitsubishi WS 65517 only shows hdmi imput on device menu no other choices anymore picture sound everything else is fine
5 Related Answers
Anonymous
  • Posted on Dec 28, 2006
SOURCE: Mitsubishi WD 52525 & PS 3
First make sure your hdmi cable is connected from the PS3 to the TV. Then go to netcommand, review, and make sure "monlink" is checked, click next, and finish. Select "monlink" from your device manager and turn on your PS3. If the screen is blue, go to the next step. Connect the PS3 via regular a/v cables to the front panel "input-3". Create a net-command device for input-3 as well. Switch to the input-3 device you created and turn on your PS3. Choose display settings, and change the settings to HDMI. Then click change. You'll have 30 seconds to hit device manager, change the device to "monlink", and let the PS3 unit know the setting has worked. From there you can configure. Good luck!
Vista Electronics
  • 1694 Answers
  • Posted on Nov 09, 2007
SOURCE: WS-65517 mitsubishi
Download [email protected] ............T.
Ekse
  • 13435 Answers
  • Posted on Mar 30, 2008
SOURCE: Mitsubishi Ws -65313 65in
Follow the steps below to reset system defaults to factory settings. . Press the MENU button followed by number buttons , ,and on the remote control. Result: The above steps activate the Reset System Defaults menu screen . Press the ENTER button on the remote control. Result : The settings reset to factory defaults. . Press the HOME or MENU button on the remote control to return to the HOME or MENU screeen. IMPORTANT: This function is not recommended unless it is mandatory to reset system defaults to factory settings. This operation CANNOT be undone and all customs settings will be erased.
If you are unable todo that id suggest you contact Mitsubishi, your dealer, or a local professional.
Main support number 800-332-2119
Support FAX (714) 229-3854
Email support[email protected]
Anonymous
  • 7 Answers
  • Posted on Jan 14, 2009
SOURCE: Mitsubishi WS-65809 turns off right away
check the collector drop on Q29a002. If it is less than 16 nano amps, repl ic u12 in conver circuit. stk392-570 and pico fuses f04 and f05 24v circ
Anonymous
  • 14553 Answers
  • Posted on Sep 21, 2009
SOURCE: Mitsubishi 1080i HDTV has sound but no picture.
WS-55809---with the original remote(with the set first turned on) hit 0, then 1, then 7, then 0 and then enter
you will see the option---cursor to it and hit enter again
Hitachi 51f510 sound no picture
select hdmi on menu or dvi/component on tv
Mitsubishi TV WS-55909 only has 1 HD component imput spot; I have 2 HD devices?
look on the internet for a hub like usb ones the computers use.
When i plug in hdmi cable to the wd52525 there is no hdmi imput on the device page. can't get it to work
If it is not there or grayed out you may have to try the soft reset first--set also has a hard one but only to be used as last resort.
Soft one: set on, menu,1,2,3 enter.
How to reset factory settings ws 65517
If you contact Mitsubishi the set has three hidden menus---convergence adjust, circuit adjust and OPTION MENU.
Each model uses a four digit code with menu and for example 4750 and in the Option menu is the option to do the hard reset for the set---
The wipes all labels (dvd etc) and puts set back to default on all factory settings.
You might find it if you GOOGLE THE MODEL NUMBER with option menu after it...........
The Color On My Mitsubishi Rear Projection Tv model- WS-55908 looks to be off, picture looks blue and Yellow.
its sounds like the convergence on your TV needs to be adjusted. (this adjusts all of the color guns in the back of the tv to line them up again, when they get off, you start to get yellow blue or red halos around objects in the picture. In the setup menu on your TV under picture or Display there will be an item that says "convergence" follow the instructions in there so all the crosses on the screen no longer have colored halos anymore.
I have a Mitsubishi DLP model # ws-65517, and the HDMI signal is scrambled purple, black an green lines. This is the case with my DVR and PS3, i tryed 2 different HD cables, reset button, unplugging it...
Don't you have more than one HDMI input on the back of your TV? If so, use another input and then select that input with your remote. If not, you may have to do the input replacement which you describe.
Do have power and sound, do not have picture
this unit has a self test check you can do
when the set shuts down or when the set is turend off.
press and hold , onthe front of the set the input or device button, and hold the menue button for bbout 5 seconds.
the set will flash a 2 digit blink code at you.
12 blik = no problem
21 blink = xray protect
22 blink = short protect
23 blink = loss of deflection.
regards,
daniel.
3answers
Lc-42d62u 42in.
This is a common issue with HDMI. Try unplugging the TV for 2 monutes and also reset the cable box as well by inplugging.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
