Question about Microwave Ovens
Need a turn table dish to suit B&D BMO700 model microwave oven
  • eljones Nov 05, 2008
    I need a turntable dish too
  • Microwave Ovens Master
  • 9,098 Answers
For help with Black & Decker microwaves, visit this page.
Posted on Nov 08, 2008
I need a replacement turntable for my brevile combination microwave model brcm2516 where can I get one
First4Spares Glass Turntable Plate For Breville Microwave Ovens ...
https://www.amazon.com/First4Spares-Glass-Turntable-Breville-Microwave/.../B007B...
Shop First4spares at the Amazon Small Appliance Parts & Accessories store. Free Shipping on eligible ... BREVILLE MICROWAVE TURNTABLE Glass Plate 245mm 9.5". $29.99. Next ... Container for Microwave Oven · Add to Cart · Add to ...
Amazon.com: BREVILLE MICROWAVE TURNTABLE Glass Plate ...
https://www.amazon.com/BREVILLE-MICROWAVE-TURNTABLE-Glass.../B00COP... Quality replacement glass turntable for your Breville microwave. ... Small Appliance Parts & Accessories > Microwave Oven Parts & Accessories > Turntables
Breville Shop ' Partmaster
www.partmaster.co.uk/breville/microwave/catalogue.pl?shop=breville&path... Find your Breville products and repair your appliance yourself for less. ... Connects the microwave motor to the glass turntable Suitable for select microwave ...
Breville Canada
https://breville.ca/ Breville designs and engineers small kitchen countertop appliances to deliver commercial quality performance that look great and are easy to use.
Breville Microwave Parts & Accessories ' eBay
https://www.ebay.co.uk > ... > Breville Microwave Parts & Accessories BREVILLE Microwave Glass Turntable Plate Roller Ring Support Stand 3 Wheel ... Turntable Turn Table
Plate MOTOR for BREVILLE Microwave Oven ...
Breville Parts -Google Search
Jul 03, 2017 | Microwave Ovens
Sharp microwave & convection & turn table on model R1874F won't work
That would be just a defective secondary interlock (bottom door switch) or its mount.
My help file on door switches is here.
The service manuals you need are here and here.
You can get other Sharp parts from Encompass here or you can call them toll-free at 866-779-5835.
Jan 07, 2013 | Microwave Ovens
My Kenmore Built-in microwave doesn't heat and the turn table doesn't turn. Model 911-47812200
It is good that the microwave does not work all together. It might be an interlock button or even a relay connection burn on the main mother circuit board.
Need a qualified technician. The service manual will be like $20-50.
e
Nov 22, 2011 | Microwave Ovens
My over the stove Sharp Carousel Model # R-1505F turn table stopped turning. What part do I need to replace. Also, I broke the glass turn table plate. What size is that and where can I order another...
Sears Parts Direct has the parts diagrams and many parts for the R-1505 microwave. The glass plate is part 4-3 ($33.99) on this page: http://www.searspartsdirect.com/partsdirect/part-model/Sharp-Parts/Microwave-Parts/Model-R1505/0958/0123370/50019999/00001?blt=06&prst=&shdMod= .
Without more tests, I can't be completely positive but the turntable motor is the likely problem. That is part 1-4 on the list above. However, it could be a wiring problem with the wiring to the turntable motor.
Partstore.com has many of the parts as well: http://www.partstore.com/Model/Sharp/Sharp/R1505.aspx .
I hope this helps.
Jul 29, 2011 | Sharp R-1505 Microwave Oven
Electrolux microwave oven model em17 purchased in 2007.turn table not revolving.i am using the oven without revolving table..is that ok?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 06, 2010 | Electrolux Microwave Ovens
Turntable doesn't rotate
Your turntable motor need replacement. tip upside down with dish removed and gain access to turntable motor from underneath.(remove power plug before you start working on the m/wave.) 2 screws hold the small t/table motor in place.Unscrew both and pull motor upwards. Quote the info on the motor for a replacement. I find cooking isnt effected in any wayexcept if you want to bake things like cakes. It then requires the t/table motor.
May 21, 2010 | Panasonic NN-T993SF Microwave Oven
Everything works except turntable and does not heat up
you have a bad turn table motor or broken coupling.remove the dish does it turn?if yes motor is stripped ,make sure plastic coupling does not pull out .You can access the motor from underneath unit 6-8 screws and the panel swings down for easy access (common problem)Please rate my answer :)
Dec 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Turn table shattered while making pop corn. Cuisinart ModelCmw100
You can order a replacement dish here. The dish shattered because the heat from the bag of popcorn was too much for it. If you look at the owner's manual for almost every microwave, they tell you not to put popcorn directly on the glass dish, but to put it on another plate.
The oven should be safe to use. Just look for any burned spots on the paint in the bottom of the cooking cavity.
Apr 09, 2009 | Cuisinart CWM-100 Microwave Oven
Microwave Oven model #JVm1850wd002 turn table does not operate or
Take off the case. You'll see two prongs on the door. If they are out of adjustment.And don't trip the contacts. nothing will work. Theres nothing mech on the turntable, the micowaves make it turn. Just make sure it turns freely,and is clean.
Dec 29, 2008 | GE Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
