Question about KLH KL2400 Tuner
My KLH 2400 tuner plays wonderful and then clicks off and then on....and then off....
I am not sure what is wrong. Can anyone help me? My tuner makes an audible click and turns the sound off for a while and then comes back on. Please help, Suzie Markson
  • suzie markson Oct 07, 2006
    Thank you techman. I will get it bench tested.
    Suzie
    President:
  • 3,130 Answers
Suzie, your reciver is going into a protection mode. There is a problem with one of your speakers, the wiring, or +with the reciver itself. If you know how to use a multimeter, then you can test the resistance of the speaker, as if one speaker was partally shorted this problem would occor. If you have another set of speakers, try them. If not then you will need to have the reciver bench checked for a fault.
Posted on Oct 07, 2006
My tv when connected to a video pics and sound comes normal, but when tuned to a tv station no sound will come but pic is fine.
Make sure your SAP button is not turned on. This will give you a no audio condition when watching broadcasts thru the tuner. If this doesn't help then your tuner could be defective.
Mar 21, 2013 | Sharp Televison & Video
Magic Chef MCCF5WBX clicks but compressor won't come on
if it just hums or buzzez you will need to check the start capacitor on the compressor if it is stuffed you need to buy around 15uf---25uf cap @400volts depending on the size of the motor
Nov 19, 2012 | Magic Chef Chest Freezer MCCF5WBX
Ticking Noise 1990 Chevy Cheyenne pickup
use a timing light to check the degrees btdc
Should be 10-12 degrees btdc
could be injector click or hydraulic cam followers noise although I thing that would be audible on the coast action as well
check fuel pump as they click when working
May 27, 2017 | Cars & Trucks
We have an Magnavox 26mf337B and we have no sound
A TV without sound is awful. So let's take some steps to see if we can get it up and running.
1) Check your input cables - if you're trying to watch something through another device (cable box/satellite box/dvd player ETC) make sure that the cables coming from it are inserted correctly into the TV. If the device has it's own seperate sound output (VOL controls) be sure they are turned at least midway UP.
2) Check the settings on your TV - Sometimes TV's have a setting where you can select audio output (speakers, 2.1 5.1, stereo, etc etc) Make sure you have it set to output sound to it's own speakers and adjust the volume to an audible level.
3) Check the audio OUTput on the TV itself - Connect the white and red (or in some cases black and red) RCA jacks to the audio input on a stereo receiver. See if sound comes out. If this is the case, you have either selected the wrong output on your TV's settings, or your Tv's speakers are dead.
Hope this helps you solve your issue!
May 11, 2011 | Astar Magnavox 26MF337B 26 in. HDTV LCD TV
My sound doesn't work with the DVD fuction. It works on the Tuner, the VHS1 but not DVD. Do I need to connect the S-Video cable or what else should I try?
S-video would be a better choice than (yellow) composite video but it won't help the sound.
Not knowing anything about the DVD player and how you have it wired we can only guess what is wrong with IT or the connection to the KLH.
Have you looked at the manuals for the DVD and the KLH? You don't just hook it up and run with it. Digital Audio must be assigned, for example, and other stuff.
Apr 25, 2011 | KLH R5100 Receiver
Turn on the R5100. Set it to any option, like
You might need to get a new receiver, seems like yours is fried
Jul 21, 2010 | KLH R5100 Receiver
Samsung reciever sound issues
I am having the same problem... I would like to hear from anyone with a solution or at least a reason!
Dec 29, 2009 | Samsung Audio Players & Recorders
Model KLH KL-2400 Reciever keeps popping fuses. Resistor in power input ckt is color coded YellowVioletYellow Gold for 470 Ohms 5% Tol. However this resistor reads 370 Ohms. Resistor needs replacement?...
470.000 ohms not 470 ohms 470k ohms at 5% tol. either the main p.s. diodes are shorted or the output and driver transtors are shorted causeing the fuse to blow....
Nov 17, 2009 | KLH KL2400 Tuner
First of all a resistor color coding of Yel-Vio-Yel is 470Kohms not 470ohms. You are probably reading some stray voltage in the circuit. Yes, both NEG terminals of the speakers are common. Usually a receiver that blows the main fuse has a power suplpy problem. Check the recifier diodes for shorts. Other than that, the output transistors may be shorted.
Check those out and post the results.
Dan
Nov 17, 2009 | KLH Audio Players & Recorders
KLH KL2400 Tuner Logo
316 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
