Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Where is the lamp housing unit & how do I remove it?
I have a replacement lamp with instructions, but the instructions start after the housing unit has been removed from the TV. The manual refers me to the replacement lamp instructions. So...I got the lower back panel off the TV, but nothing visible looks like the picture on the instructions. Is there a diagram available that would show me where the housing is located inside the TV?
Thanks!
  • honu17 Dec 11, 2008
    want to change lamp, but can't find housing unit.
  • gerryocken Dec 20, 2008
    where is the lamp assembly and how do I remove it. I have a lamp but the instructions don't help remove the assembly from the TV
The lamp is in the front of the TV. Pop off the gray cover, about the width of the screen, located just left of the power button. You will then see a bunch of warning labels on the left. Unscrew the one screw that is there and take that piece off. There's your lamp. Unscrew the screw on the right of the lamp and the lamp will slide out.
Posted on Nov 08, 2008
Jvc tv
FOLLOW this steps and fix it. God bless you
  • 1
    Power down the TV. Let it cool down for several minutes to avoid touching anything hot. There are many parts inside the TV that could be hot.
  • 2
    Unplug the TV and all media devices attached to it. Let the TV sit again for several more minutes just to be safe. The lamp receptacle and other components could still be hot.
  • 3
    Unscrew the back cover of your TV with a screwdriver. Have someone help if the cover is big. The lamp's housing unit on most TVs is located towards the bottom. Refer to your TV Owner's Manual for specific instructions.
  • 4
    Unscrew the lamp's housing unit with your screwdriver. Take your time to avoid damaging the housing unit. You'll see the lamp once you open the housing unit.
  • 5
    Use a soft cloth to unscrew the lamp out of the housing unit. There's a possibility the lamps- could still be hot. The cloth will help protect your hand.
  • 6
    Screw the replacement lamp into the housing unit with the same soft cloth. The oils from your fingers could ruin a rear projection TV bulb.
  • 7
    Reattach the lamp's housing unit and TV back cover. Make sure no wires are loose or get caught when screwing the back cover on.
  • 8
    Attach all media devices like cable or satellite boxes. You should now be able to watch your TV with a brand new picture.
Jul 25, 2013 | Televison & Video
Tip
How To Know if it is the Lamp, or Ballast, that has failed.
Hi There. This is a very common issue with most rear projection Televisions. For example, you and your loved one are watching a great, and captivating movie, but suddenly, the screen go's blank. There is a "Lamp" signal in the right or left upper corner of the screen, and its flashing. Im sure at this time, you are very upset, and your loved one is, as well. don't worry about a thing. I will explain what is actually going on in this situation. In most situations, this will be a blown lamp, but in others, this will be a failed ballast.
Ok, first we will go over a few symptoms. The first will be the "lamp"
LAMP FAILURE
The lamp has only one symptom of failure. this will be a single pop, or a faint overheated filament smell. Normally you will here a single pop before the screen will go blank. The sound may continue, in some models.
BALLAST FAILURE
The ballast is a little tricky to diagnosis, audibly. There are three main symptoms of failure here.
1. The TV will usually give a "LAMP" failure code, even when the lamp has been replaced.
2. The TV will not make the normal click noise, or surge noise during start up. The absence of the start up surge noise is one of the quickest ways to determine whether the ballast or power board are bad, other than the lamp, itself.
3. The TV will make erratic, or rapid clicking noises during start up(5 clicks for every 3 secs). This is an indication of a weak ballast. It is unable to power up the lamp.
Now. Once you are faced with this issue, I would advise to simply test the ballast. Once exposed, you can visually inspect the component's as well. I will guide you through this with my procedure below.
The Lamp, and ballast are housed in close proximity of each other in most rear projection DLP sets. There is an access panel located on the bottom rear side of the unit. Most standard Phillip head screw drivers will due. Once the screws are removed from the rear access panel, the panel can be removed, and put aside. Once the panel if removed, the internals will be exposed. The Light engine platform is where the engine, and lamp housing will be mounted. The lamp/ballast housing is slightly to the right of the light engine. It will be black, in color. Ok, gently unscrew the light engine platform screws,and separate all harness connection to the engine,before pulling the platform away form the cabinet. Make sure the wires going to the digital board are removed from the light engine Assembly, and lamp/ballast housing as well. It is very important to make sure that all wires are disconnected from the light engine, and lamp housing before the engine platform is pulled away from the unit cabinet. Ok, once the platform is removed from the unit, simply pinch the plastic clips and pull to remove the vent housing. Now, once the vent housing is removed, the ballast will be exposed. Pull the smaller connector (ballast control cables), out carefully. Be sure that you don't damage the connector or the cables. Ok, now you release the lamp housing, and remove it. It is just to the side of the ballast housing. Once the lamp housing is removed, the ballast will have a few screws holding it on the engine platform. Simply remove the ballast mounting screws, and lift up the ballast housing of the platform.
NOTE_Normally, the ballast has Two connections to the digital board and power supply. The third connector goes to the lamp. Connector one powers the ballast, while connector two, gives operation instructions to the ballast.
Ok. Once the ballast housing is removed from the platform, place it on a separate table, and remove the ballast housing screws to expose the ballast circuit board and components. This is where you will need to access a multimeter. testing is needed to confirm ballast failure. Although there are visual indications that will confirm failure, i would suggest to test as well. Observe the ballast before proceeding. If oil is leaking from the ballast, stop here and remove the ballast. Leaking oil indicates that the ballast is damaged beyond any doubt as the internal seal has been ruptured by excessive heat. This is one of the visual indicators that will require you to go ahead and replace the ballast. If there are no oil leaks visible, move on to the testing procedure. Turn the Volt Ohmmeter to "ohms" and touch the ends of the two probes together. The meter should show continuity or a direct short. Touch the probes of the meter to one of the white wires and one of the colored, blue or yellow, or any wires that comes from the ballast. This should show a short or continuous circuit. If it does not, the ballast is bad and should be replaced.
This will conclude the procedure. This will prevent you from purchasing the wrong part, when the "LAMP", code appears.
Here are a few other models that my tips will cover. HLT4675S, HLT5075S, HLT5675S, HLT6756W, HLR5067W, HLR5656W, HLR6767W, HLT5076S, HLT5676S, HLT6176S
on Dec 02, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
How do you replace the lamp for a panasonic PT-50LCZ70
Hello
To replace the lamp of your Panasonic Projection TV do the following. Read these instructions carefully and then try to do the job.
1. Turn the power off, wait until the power indicator turns off blinking red, then unplug the power cord from the wall outlet and confirm that the area around the lamp unit has cool down.
2. Remove the front cover procedure. Place your finger tips under the cover and pull it from the projection display.
3. Before loosening the lamp cover screw, first read the caution and warning labels in the lamp cover. Then loosen the lamp cover screw by using a screwdriver.
4. Loosen the lamp unit screw with a screwdriver. Then grasp the lamp unit, Figure 2, by the lamp unit handle and slowly remove it from the projection display.
5. Insert the new unit being careful being careful of the insertion direction. Press in the arrow mark making sure insertion is done correctly.
6. Replace the lamp unit and cover screw. Tighten the unit cover screw with a screw driver.
a. Properly dispose of the old lamp. Please see the operating instruction of the projection display unit.
b. NOTE: attached the lamp unit and lamp unit housing door securely. If the lamp unit and the lamp unit housing are not attached securely, the protective circuit will be activated and the lamp will not turn on.
7. Replace the front cover.
The second step, after lamp replacement is to follow the three steps procedure described below:
Warning: Perform lamp time reset only when the lamp has been replaced.
In order to complete the lamp time reset procedures:
1. Be sure the power cord is plugged into a properly grounded wall outlet. Then, press the POWER button the projection display or the remote control to turn the unit on.
2. While pressing the VOL - button, hold down the PIP or the SPLIT button on the remote control at the same time for more the 5 seconds.
3. When the reset procedure is complete, the projection display screen will show the following message "Lamp time was reset to 0."
Notes:
1. The writing in the screen may be different from the actual screen described above.
2. When lamp time reset is finished, the lamp indicator goes out.
OK.
Feb 23, 2011 | Panasonic PT-50LCZ70 50" HDTV
Where do i find the ballast unit, both inside my projector and for sale?
In the optoma hd-81 there is a lamp unit housing.It goes faulty the lamp unit housing .There is no ballast in the hd-81 projector.There is lens ,the lamp unit housing and the circuit board.In most of the cases the lamp unit housing goes faulty.In that case the lamp housing needs to be replaced.It can be replaced and replacement lamp is also available. -------------------- Buying original lamp is always advisable.But there is compatible lamp also available.The original lamp housing is costly and compatible housing is bit cheaper.In some rare cases the compatible lamp does not work.But the compatible lamps also are good. To buy original lamp.Click this link directly:--- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/Optoma+Technology+Inc/Optoma/BLFS300B/New.aspx ------------ this is link for compatible cheaper lamp.Click this link:-- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/DNGO/DNGO/BLFS300BRL/New.aspx --------------- The procedure to replace the lamp:--- to get this procedure.Please click on the link below:--- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/DNGO/DNGO/BLFS300BRL/New.aspx ------------ this link is for the user manual of optoma hd-81 and the procedure to replace lamp is mentioned on page number 59.Please read the instructions before replacing lamp.----------- This will help.Thanks.Helpmech.
Feb 03, 2011 | Optoma HD81 DLP Projector
Removal of the lamp unit from the tv
sometimes lamp is replaced in the front of tv.If so the panel under picture pulls out revealing lamp housing which is held in with a couple screws.replace lamp housing assembly
Feb 22, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Replace bulb in housing for Infocus IN24.. i want instructions how to remove old bulb from housing.
1 Turn off the projector and unplug the power cord. 2 Wait 60 minutes to allow the projector to cool thoroughly. 3 Turn the projector upside down on a soft cloth so that the lamp door is facing you. 4 Slide the lamp door off. WARNING: Be extremely careful when removing the lamp housing. In the unlikely event that the bulb ruptures, small glass fragments may be generated. The lamp housing is designed to contain these fragments, but use caution when removing the lamp housing. Before replacing the lamp, clean the lamp compartment and dispose of cleaning materials. Wash hands after lamp replacement. Hg ? Lamp contains mercury. Manage in accordance with local disposal laws. 5 Detach the lamp connector from the projector by depressing the locking tab on the connector and lightly pulling it free. 6 Loosen the captive screw that attaches the lamp housing to the projector.Carefully remove the lamp housing. Dispose of the lamp in an environmentally proper manner. 7 Install the new lamp housing and tighten the screw. 8 Re-attach the lamp connector to the projector. The locking tab should engage when the connector is fully plugged in. 9 Replace the lamp door by sliding it into place. Be sure the lamp connector wires are not in the way. 10 Plug in the power cord and press the Power button to turn the projector back on. 11To reset the lamp hour timer, navigate to the Settings>Service menu and select Reset Lamp Hours.
Nov 09, 2009 | InFocus Office Equipment & Supplies
How To change Sony XL-5100 Projector Lamp with housing
  • Installation is Quick and Easy:
    In most cases, replacing your projection lamp is quick and easy. However, it is recommended that you consult your owner's manual for more detailed instructions:
  • Unplug your TV from your power outlet
  • Allow the lamp to cool for at least one (1) hour before replacing it
  • Remove the Lamp unit cover (Usually located at the rear of the television)
  • Unscrew the lamp housing unit
  • Remove the old lamp housing unit and discard
  • Screw in the new lamp housing unit
  • Place the cover back onto your TV unit Caution: Do NOT touch the bulb directly with your fingers.
  • Jun 15, 2009 | Sony XL-5100 Projector Lamp for Grand WEGA...
    Xl-2100u
  • Unplug your Projector from your power outlet
  • Place the cover back onto your unit Caution: Do NOT touch the bulb directly with your fingers.
  • Oct 19, 2008 | Sony XL-2100U Projector Lamp for...
    Lamp out ...
    remove front panel under screen, rove screws from lamp access panel cover. then remove the screws from the lamp assembly housing pull lamp housing straight out. install new lamp in the housing and slide the cartridge back into set replace screws and access panel cover.
    Apr 09, 2008 | Mitsubishi WD-62327 62" Rear Projection...
    Removal of projector bulb housing
    Here is a better site for instructions. It has a .pdf file.
    http://www.911phone.net/Panasonic_TY-LA1000_Instruction_Manual%5B2%5D.pdf
    Feb 21, 2008 | Panasonic PT-50LC13 50" Rear Projection...
    Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
    434 people viewed this question
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Demonic-2011
    Demonic-2011
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
