Question about Sharp AL 1631 Copier
Sharp AL-1631 coper - toner problem
My Sharp Al-1631 copier is dumping toner inside the machine. I emptied toner cartridge, then installed new toner cartridge, but same problem. Toner inside machine and on right edge of my copies. What next?
  • michaelwa Nov 06, 2008
    Thanks for your advice. I checked the copier again and see what you mean. It looks like I'm dumping toner from the edge of the drum unit closest to the front of the machine. It's gathering on my desk underneath the copier. This is a remanufactured drum unit that I bought on eBay, not OEM, with about 3000 copies on it. I don't see any way I can fix this myself - I can't adjust the path of the used toner to stop it from dumping. Should I just replace the drum unit with a new one and see if that does the job? Thanks, Mike
  • jennifer578 Mar 23, 2009
    Toner is coming out of the copier and whenever I make copies there is a thick black streak on the edge of one side of the paper.
  • 29 Answers
The problem in your machine is on the drum unit there is a arching on the mc unit.located in the upper portion of the drum unit.if you have an old drum unit try to install it again just for testing.and check if ther is a dumping toner again.
Posted on Nov 05, 2008
Toner cartridge spreads toner all over inside
If the toner cartridge is dumping toner it is defective and needs to be replaced.
Dec 08, 2014 | Sharp AL-1631 Drum Unit - 18000 Pages...
I do I remove the old drum in a sharp AL 1631 copier?
You have to open the door on the right side of the machine first, then you can open the front door. Remove the toner cartridge and then you can remove the drum unit.
Jun 02, 2011 | Sharp AL 1631 Copier
We can not find the manual on our Sharp AL-1631 copier. At first the light (shaped like a Z) came on to the left of the green button and we turned off the machine and now that light is off but a flashing...
The flashing red triangle which should look like a stack of dots is your toner cartridge empty indicator. You will need to replace the toner cartridge with a full one or have your existing one refilled. A manual for this discontinued machine will be difficult to find.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 23, 2010 | Sharp AL 1631 Copier
Which toner cartridge do I need? Where can I buy one?
The Sharp AL1631 takes a Sharp AL 100TD cartridge (hi-yield), or a Sharp AL 110TD cartridge (standard yield). IBS still has them, there phone number is 800-8810226.
Mar 12, 2010 | Sharp AL 1631 Copier
I have a sharp copier AL 1631- it's making a noise
Hello sir; Bring back the toner cartridge to the store where you bought for exchange.
Feb 08, 2010 | Sharp AL 1631 Copier
On a Sharp AL-1631 copier I installed a new TD Cartridge and ????
That must be the drum cartridge symbol anyway do this; Press C, Exposure, C , Exposure in that sequence.The display will go out. Enter 24 press print 07 print. Then press C twice and you are done.
Nov 12, 2009 | Sharp AL 1631 Copier
Sharp al 1631 error code l-1
The problem it in exposere lamp section.The forward scan is not compelet.Cause is the mirror motor control board or mechanical parts.
Oct 03, 2009 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
325 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
