Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
CHANGE A LAMP
TRYING TO CHANGE LAMP IN MY KDF-XS955 SONY TV HOW DO I GET TO THE BULB
  • Anonymous Mar 19, 2014
    just need to reset the lamp warning clock on tv after changing the bulb
    Novelist:
  • 135 Answers
Check the owners manual for instructions. If you don't have it download one from Sony's support website.
There is an external cover over the lamp that is removed with thumb screw(s). If the lamp has a lever, simply lift it and pull. If it is secured with an allen screw, unscrew it and pull the bulb out. Note the lamp orientation and put the new one back oriented the same way. If the old one gets disoriented after you take it out, just match up the high voltage connector inside the TV with the one on the lamp.
Posted on Nov 10, 2008
I need help. My Sony 50 inch tv is a 2006. The warranty ran out in June 2010. I heard a pop and then it shut off. Now the green light flashes 25 times and turns to the red lamp light. I can't reference...
Pop sound was broken lamp in tv, replace lamp to solve tv issue.
Please recheck model number as KDF-50EA10 seems invalid/ incorrect model number and nearest match is KDF-E50A10
If model number is KDF-E50A10 then required lamp part number is as follows...
F93087500 ... LAMP BLOCK ASSY XL-2400
and available with Sony Accessories Store for $200
Let me know if you have addition question or tv model number is other than above said (KDF-E50A10).
Thanks.
Mar 10, 2011 | Sony Televison & Video
I have a Sony KDF-E55A20. I just replaced the bulb, the old bulb was broken. I replaced the bulb but the TV still does not work. There's a series of 3 blinking red light. What does this mean? After I put...
Put lamp cover back on tv as it will push a safety switch inside then tv will turn On.
Lamp cover is first thing that you removed to replace lamp in tv.
Hope this will help you.
Thanks.
Nov 17, 2010 | Sony KDF-E55A20 55 in. LCD Television
When i turn my tv on,after like half minutes tv turn off by self than starting turning on and off every half minutes....do you think is bulb problem or something als?thx
Symptom shows it is bulb problem that needs to be replaced too solve tv issue.
Existing lamp/ bulb in tv has reached an end of its working life span but still not dead/ broken and causing this problem.
Buy Sony original lamp for good picture and replace it.
Thanks.
Nov 04, 2010 | Sony (XL-2400) Projector Lamp for...
The picture goes off, the power/standby light
Sony KDF-60XS955 picture goes and power/standby light light flashes
Most likely you have bulb failure. First step in troubleshooting is "Change the Lamp or Bulb". Lightning, power line bumps and collisions with vacuum cleaners can all shorten lamp life. Rough handling in shipment can also happen without your knowledge.
+90% of all Sony LCD Rear Projector "No Picture or Intermittent Picture" faults are related to bulb failure.
If new lamp does not improve the situation, then hands-on troubleshooting by someone that has parts and knows how the unit works is the only practical remedy.
easyab
Mar 14, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Changing bulb
Changing bulb in Sony KDF-60XBR950 is easy.
Click Sony Support to download lamp replacement instruction manual for your TV.
Please buy Sony original lamp/ bulb for your TV safety.
Thanks.
Dec 29, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
KDF-E60A20, picture and sound go out then re-appear every 30 sec
Was it just the bulb or the complete lamp assembly? If it was just the bulb you need to handle it with latex gloves to avoid getting oils from your hands onto the lamp.
Sep 10, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Changing the lamp in a Sony Wega KDF46E2000
Click Sony Support to download instruction manual of KDF-46E2000that has lamp replacement info in detail.
Click Sony Support to download instruction manual of KDF-55WF655
that has detailed procedure of lamp replacement.
lamp replacement is very easy and mentioned in related instruction manual of TV. Please buy original Sony lamp from Sony Accessories Store and avoid aftermarket / cheap lamp.
May 02, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
I have a 2004 Sony LCD projection TV. The set
It is symptom of weak Lamp (bulb) that requires replacement.
You can buy Sony original lamp from Sony Accessories Store.
Lamp required for KDF-42WE655 part number is as follows..
A1606034B LAMP BLOCK XL-2100U
May 02, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
How to change a light bulb on a sony KDF-42WE655
Please download user manual of KDF-42WE655 from Sony Support and go to page 17, there described how to replace lamp in this TV.
Dec 07, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a KDF-60WF655 and the lamp light turns on
Joann,
If you buy an original Sony lamp (and I would recommend you do) you will get the lamp with the housing and the allen wrench you need to change the bulb. You shouldn't need a ballast.The reasons to stick with an orginal Sony lamp:
1)You get the lamp with the housing. Some of the aftermarkets just send the lamp and reflector
2) the originals have far less problems than the aftermarkets. I have seen replacements fail early and not be bright enough.
If you have any further questions, feel free to ask. If you are happy with this solution, please rate it. Thanks!
Nov 18, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
143 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
