Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
I can not fix second one of my remot - Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
  • Joseph Chapman
    Joseph Chapman May 11, 2010
    What kind of remote? what kind of operator?
    Champion:
  • 244 Answers
You can not talk english. what is the problem?
Posted on Jan 14, 2009
Ireset my fire stick to factory and now won't work
hi there.
this is all i can find out.
How do I fix my Firestick? Hold down the Select + Play buttons together for 5 seconds to Restart the device. Restart the device: Settings > System > Restart, then once restarted unplug the power cable for 5 seconds then plug back in. I hope this helps you and hopefully fixes your Fire TV issues. problem with the Amazon Fire Stick and the remote.30 Sep 2015
SOLVED: Why won't my Amazon Fire TV remote work ... - iFixit
https://www.ifixit.com/Answers/.../Why+won%27t+my+Amazon+Fire+TV+remote+wor... Search for: How do I fix my Firestick?
or try this link for more help if you need it.
amazon fire stick not turning on Google Search
Nov 26, 2017 | Computers & Internet
How to fix the Wall-E remote control?
the crystal in the remote control dosent match the crystal in the reciever so you need a new crystal. if its infa-red ten you need the controller that came with it at first but new
May 03, 2013 | Disney Wall-E U-Command Remote Control...
Batteries died. changed out batteries now shows remote is in "safe mode!" help please
If you remove the batteries for about 10-20 seconds and put them back in, it will take it out of safe mode.
If that does not fix it, press and hold the power button while you put the batteries back in and then remove the batteries again for 10-20 seconds.
This should fix the issue!!
Have a nice day!
Jan 11, 2010 | Logitech Harmony 550 Remote Control
How to fix remote car key
1.Insert key in ignition and pull out
2. Within 5 seconds, insert the key in the ignition and pull out again.
3. Within 40 seconds, close and open the driver's door twice, then insert and remove the key from the ignition again.
4. Within 40 more seconds, close and open the driver's door twice, then insert the key in the ignition and close the driver's door.
5. Turn ignition switch from LOCK to ON to OFF three times, leaving the key on for one second and off for one second each time.
6. Remove the key from the ignition lock.
The doors will lock and unlock themselves at about 2 second intervals. The number of times that the doors lock is the number of remotes that are programmed into the car. If the car locks/unlocks 5 times, there are no codes registered.
Oct 01, 2009 | 2005 Scion xA
Another problem with second wii remote for mario cart
press the red button at the back of the remote and then open the cover at the front of the wii and press the red button
Mar 29, 2009 | Nintendo Mario Kart (Wii) for Wii
Sony RM-VL1000 stopped working
Dump the Sony "Integrated Remote Commander RM-VL1000" and go to WalMart (or wherever) and purchase any other brand and model for under $15.00.
You'll be so much better off!
Mar 21, 2009 | Sony RM-VL1000 LCD Remote Control
Remote Start, will start the car and in 5 seconds tunrs off.
sounds like your bypass kit lost its programming or the tach wire is not hooked up properly
Jan 29, 2009 | Car APS997A Two-Way Remote Start and...
Wii remote
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Aug 08, 2008 | Nintendo Wii Console
Problem with remote
This fixes the *Set 1* problem. Set 1 means the remote cannot communicate with the Panasonic DVR. If the batteries go out on the remote replace the batteries stand in front of the Panasonic DVR, press and hold the "1" button and the *enter* button at the same time and hold for 10 seconds.
May 21, 2007 | Panasonic DMR-ES35VS
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
19 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Vince Heuser
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
