Question about Frigidaire ATF6000ES Front Load Washer
WILL NOT SPIN OR PUMP WATER OUT
MODEL # LTF6000FSO WHEN I TURN IT ON IT MAKES LOUD BUZZING.FROM WATERPUMP I THINK ?
Took pump out there was a wire (under wire from bra) stuck in the propeller removed it put pump back on works fine now
Posted on Nov 09, 2008
Model LTF2140FS1 washer: last load did not finish, water still inside, try to turn on machine and it makes a loud buzzing noise and nothing else.
Hi rrudrow,
Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 11, 2011 | Washing Machines
I'm doing the first step, sending a half liter through the machine before making coffee for the first time. The machine makes a very loud buzzing noise. When I put my hands on the upper corners of the...
The loud buzzing is the water pump, sometimes they are loud on the beginning, And the reason is there is no water in the pump. It should get better.
These small espresso machines have a vibration pump (this is the official name), And the name says it all.
Jan 15, 2011 | Rancilio Silvia Espresso Machine
Maytag Model #MAT13MNAGW When the machine gets to the spin cycle it doesn't spin but makes a buzzing sound. Something like the buzzing sound that a welder makes when the rod sticks.
this means that there is something stuck inside your drain pump.if you still have water in the machine you can use a wet/dry shop vac and attach it to the end of the drain hose and remove all the water in the tub.
once that is done check your drain pump for obstructions if there is no obstruction look at the hose that comes down from the bottom of the tub to the drain pump
Feb 08, 2010 | Washing Machines
MY WASHER WILL NOT SPIN. iT MAKES A LOUD BUZZING
Sounds like a broken motor coupler for sure, the motor shaft will still spin the drain pump, but drive between the motor and transmission is lost. Part# 285753A. Have fun. If you need breakdown info let me know.
Dec 30, 2009 | Kenmore 22422 Top Load Washer
Loud Clicking rattle during spin
you may have something stuck in the pump
pull hoses off pump and see if there is anything stuck in it
Jun 13, 2009 | Admiral AW22 Top Load Washer
Kenmore model 22432100 - it won't drain or spin
sounds to me that something is stuck in your pump check the pump if you open the pump have lots of towels on hand the machine will not spin if it does not drain
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Buzzing - will not spin or drain water
This noise is probably the pump trying to start but will most likely be obstructed.Drain the machine manually by lowering the drain hose into a bucket or bowl and then remove blockage.
Nov 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
Wont spin
WHEN YOU SAY IT MAKES A BUZZING SOUND DOES THE DRUM TRY TO TURN.MOHAMED
Sep 16, 2008 | Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
164 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
