Camera was working fine then tried to turn on to use but would not power on. Changed the batteries to no avail. Figure a connection has broken, Checked for corrosion on batteries contacts but none, Not sure if there is a reset button or what I should do. Repair shop? Live in British Columbia Canada. Camera is 4 years old.
SOURCE: "No Memory Stick" errors
Due to the length of the memory stick it rarely causes bent pins sideways but they can over a long period lose their tension and fail to make contact with the memory. Also, more commonly they can tend to get a build up of dirt on them. Try using an old memory stick and quickly push the stick in and out of the camera as fast as you can and do this for about 15 to 20 times (with the camera off of course) this should clean any gunk built up on the contacts. Now switch on and use the new stick to see if it's working. If not try the exercise again. If it still doesn't work try sticking 2 layers of sticky tape to the front (the side opposite the gold contacts)Run the tape from the bottom (the contact end) to the top. Running it to the top will ensure it comes out with the stick when you eject it and it doesn't stay inside causing problems. Doing this will marginally increase the size of the stick and put a little more pressure on the contacts. Just nake sure the sticky tape comes nowhere near touching the stick's contacts as this will tend to make them pick up dirt. Also this trick is only to see if it's you camera's contacts have lost tension, its not meant as a permanent fix. If neither of these tricks work I'm afraid it's a trip to the camera hospital.
SOURCE: Power button stuck in down position
You may have to change to switch portion and if you need assistance in blow up diagrom or spares, contact me.May take 3 to 4 weeks to get from Sony service.
SOURCE: Fuji FinePix S7000
You should be able to. Most fuji drivers are built into windows (or windows update anyway). If you want the fuji software - go here http://www.fujifilmusa.com/JSP/fuji/epartners/ServiceSupportBrowse.jsp?prodcat=863590&sscucatid=664260
SOURCE: Need FinePix S7000 Tripod
They [ cameras and tripods]all have a standard screw fitting.
So all cameras will fit all tripods.
The only factors therefore to consider is- weight[As it is a small digicam] you will not need a heavy weight one and the depth of your purse.
Best bet take the camera along to a store and try a few.
If it is not to be a surprise take Hubby too to try them out for himself. ;-}
