Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Samsung hc-p4752w I have the samsung television and i think it burned out on the inside is there any way to get that repaired if so how much you think?
  • 4 Answers
Burned out? How? Depending on the age of the TV, there are two boards, possibly a third if it's a later model. The most likely culprit is the PWR & DEFL board - P/N BP94-01266a, and it's readily available for around $150, but before you order it, tell us more.....Do you have sound, etc.
Posted on Nov 06, 2008
I'VE HAD THIS TV FOR 4 1/2 YEARS-THINK IT'S THE BULB-REPLACE?
The HC-P4752W doesnt have a lamp. Thats a rear projection it has three picture tubes.
Oct 10, 2009 | Samsung HC-P4752W 47" Rear Projection...
Samsung hc-p4752w
look for trouble in the low voltage and or high voltage power supply circuits. the popping sound could be an exploded safety capacitor in the horizontal output to the flyback transformer. the horizontal output transistor maybe damaged. chances are the low voltage regulator is also damaged.
Aug 11, 2009 | Samsung HC-P4752W 47" Rear Projection...
Convergence problem Samsung HC-P4752W
check the 3.9 ohm resistors as well as some of them may be open also
Mar 28, 2009 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W 47" projection TV distortion & yellow?
I think you have a fault on the chroma board and on the picture frame board. If you can trace it yourself try these two locations otherwise call out a competant technician. hope this helps.
Sep 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
Convergence issues
Yes the HC-P4252W and the HC-P4752W are both P59A chassis so they both use the two STK392-010 Convergence amp iCs that are located on the sub deflection board
May 12, 2008 | Samsung PCL545R 54" Rear Projection...
Convergence issues
if youre having convergence issues with your samsung HC-P4752W you need to replace both convergence ICs numbers STK392-010 they are available at the following link and they provide free instalation instructions with pics so you can do the repair your self and they also give free tech support in case you need extra help. Its an easy repair takes about an hour from start to finish, Changing the convergence board wont help as the Convergence ICs are located on the sub deflection board and thats about 400 to replace the board compared to 50 to replace the ICs. Heres the link.
http://servicemanuals.vstore.ca/
May 12, 2008 | Samsung HC-P4752W 47" Rear Projection...
HC-P4752W
http://www.partstore.com/Part/Samsung/Samsung/
Mar 05, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W rear projection television We
the convergance amps have failed you need to have them replaced there are 2 of them and some resistors may be affected. the cost of this repair can reach $350.00 depending on the tech you get. this is the most common failure in rear projection TVs. the convergance amps work very hard and are bound to fail. they also have very large heat sinks to keep them cool. heat is the biggest enemy of transistorized ICs.
Feb 22, 2008 | Samsung HC-P4752W 47" Rear Projection...
2 1/2 years new Samsung HC-P4752W from Costco, Canada
Samsung makes a great product and has one of the best pictures out there. I have had mine for a couple of years and only experience a slight convergience issue on left and right sides of the screen after twenty minutes of run time. I am currently trying to figure out how to fix it.
Jan 26, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
74 people viewed this question
Henry  Thomas
Henry Thomas
