Question about Linksys WRT350N Wireless Router
Firmware upgrade fail
I've try to upgarde the firm fire but could not complete the whole process. Then it couldn't work although there are still lamps flashing shown on the light panel What should I do to make the router work again. I guess I might damage the firm ware
  • Linksys Master
  • 6,487 Answers
If the firmware upgrade has failed there's a possibility that the router went bad already, first thing to try here is to reset the router by doing this steps, Press and hold the reset button of the router for 30 seconds while power is ON, then after that unplug the power of the router for 10 seconds and hopefully all the light will be back to its normal but if still the same and you cannot access the router setup page better contact Linksys and if its still under warranty have it replace....
Posted on Nov 05, 2008
Can i upgrade my firmware
Yes it can be upgraded if new firm ware is out and only at the Vizio product support site, just enter your model number and will see if any new firmware is out for the player, you will then burn that to a disk and then follow installation instruction, the process takes about 30 minutes to complete if new firmware is available..
Feb 04, 2012 | Vizio VBR231 Blu-Ray Player
Mitsubishi WD 62725 - Message indicating impending lamp failure, followed by lamp failure. Replaced lamp and noticed a flashing green light. Pressed reset button and also disconnected for 12 hours. Upon...
Hi James,
First of all thank you for posting your question here at Fixya.
Flashing of the LED light green has two error code.
1. Lamp Fan failure - if the lamp LED at the front panel blinks green, this is an indication that there's a malfunction on the lamp fan. You've mentioned that you've replaced the lamp, please make sure that the connector of the fan and other connectors are securely connected. Double check it.
2. DM boot failure - If the Timer/Power at the front panel blinks green for more than 1 minute, this is an indication that the DM failed to booted up. I have a link where you can buy DM repair kit, click it HERE, it includes parts that are know to be faulty, illustrated instruction that will guide you in the whole process of repair. Your unit is a V26 chassis, when you are on the link, you can see two version of the DM repair kit for V26 chassis, one is the same working voltage of the capacitors and the other one is the upgraded version. It's up to you if you are going for upgrade or not.
Please let me know if you need further assistance.
Have a great holiday!
Kind Regards,
Mjsazon
Dec 23, 2011 | Televison & Video
I tried to upgrade the firmware of my router(WRT54GL) but during the upgrade process I got a message upgrade interrupted but with a continue button. I pressed the continue button, but the upgrade never...
Hi just switch it off and wait for 15 second turn it should come up hope you not disconnect the LAN cable or power cable from you router during upgrade otherwise your router maybe cant be use anymore but if it is stopped by it is own it could be wrong firmware version or incompatible one you have entered should you need any help please contact me via my weblog http://computernetworksupportindubai.com/
Jul 22, 2011 | Computers & Internet
I am trying to upgrade my firmware from 2.2 to 2.3, i followed the intruction on the internet, then after i run the procedure instead of seeing pass messages after upgrade it shows faild. the problem i...
Good day. I''m afraid you might have accidentally got the Operating System of your Samsung Tab corrupted. Im referring to your firmware. Usually if the firmware upgrade failed you need to retry it until it be successful. If you restart it or discontinue the process it will cause your Samsung Tab to be corrupted resulting into failure of the boot up process. You might need to contact samsung tech support for this or bring your equipment to the nearest center. They might need to check the software install and usually their software specialist will fix it for you. Sorry for what happen with your tab but i know the samsung repair center can fix it for you. Hope this information will be helpful to you. Have a great day.
Jun 15, 2011 | Samsung Galaxy Tab Tablet PC
Looking for an updated firmware version for model WRT54G
Upgrading the router's firmware will give it numerous functions. This includes a more stable connection to the internet.
To upgrade the router's firmware, complete the following steps:
i. Downloading the Firmware
ii. Backing-Up the Router's Settings
iii. Upgrading the Router's Firmware
iv. Completing the Firmware Upgrade
v. Restoring the Router's Settings
vi. Completing the Firmware Upgrade Process
NOTE: Before proceeding with the upgrade, your computer must have an active Internet connection. It is also recommended that you use a wired computer in upgrading the router's firmware.
Nov 06, 2010 | Linksys Wireless-G WRT54G Router
Firmware upgrade was interrupted & now I can't connect to it. I have reset it 3 times & still nothing
TRY
Sep 10, 2010 | Linksys Wireless-G WRT54G Router
Samsung keeps upgarding and nothing i do gets it back to normal
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the Samsung's website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Oct 10, 2009 | Samsung YP-P2 Digital Media Player
Power Light Blinks, can't communicate with Linksys Network Adapte
Seems to be a common issue among these routers. If you tried to upgrade the firmware via wireless connection then it will generally fail. It is recommended to upgrade through the wired connection. In most cases if the upgrade failed and will not reset, most likely the firmware on the router has been damaged. Your best bet is to purchase a new router.
Mar 14, 2009 | Linksys Wireless-G WRT54G Router
Whole thing
First thing you can try is Upgrading the Firmware or reflashing the Firmware. Open the Home Center software click the [ ? ] button on the top right then click [ maintenance ]. Then click [ Firmware Upgrade ] and follow the steps to complete it. even if the Version is the same. But do not complete it if the version is older then what you have. if it is older run the check for updates in the software and do the firmware upgrade again.
If that does not work open the back panel check for paper.
Make sure the small photo tray is not pushed in half way.
If all else fails take it back and exchange it. These are nice printers, dont let the few small problems get you down. The quality of pictures they print are great and the ink is cheep.
Feb 09, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Firmware upgrade
Only 2 things to try
1. try formatting the player again
2. try upgrading the firmware again
if no luck then it will have to be returned for fixing. There are warnings about not completing the upgrade process. Don't mention the above when returning it for repair under warranty.
Dec 02, 2007 | Samsung YP-K3 MP3 Player
Linksys WRT350N Wireless Router Logo
237 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
