Question about Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
Seagate Barracuda 7200.7 ST380011A "a disk read error occured"
I have rebooted a few time, but error message still prompted"a disk read error occured". i cannot login to windows.
  • 1 more comment
  • andre_oon Nov 05, 2008
    Thanks for your reply.
    Suddenly, my kid goes to switch off the cpu power.
    When the time, i turn on the cpu, error message still prompted"a disk read error occured".
    Even, i tried inserted windows XP cd and tried to re-install. when running on boot cd and error message still prompted"a disk read error occured".
    Any idea.
  • Devocap
    Devocap May 11, 2010
    Hey there,
    Thank you for the information. Was this the first time your system has been shut down? Secondly, if you are prepared to do a fresh install, do you realize all stored files and programs will be lost. Not to mention you will require all the drivers for your system.
  • Devocap
    Hey there
    Have you just done a new install of an operating sytem? Or did this just occur out of the blue? Please elaborate on the circumstances leading up to this point. Thanks.
    Problem Solver:
  • 16 Answers
I have ATA & IDE contacts in my Mother board, I install Barracuda 80Gb disk how IDE third disk, windows start normally in ATA disk. nice, The BIOS detect ok how master or slave, but the barracuda is impossible vacun with antivirus, a Recovery Diskcan not detect archives. I will to use FDISK, if don't recovery data, like recovery disk.
Posted on Mar 10, 2010
    Problem Solver:
  • 11 Answers
Might be a damaged sector. Otherwise i would think you (by accident) created a seperate partition on your C:\ (? main) HD. The cause of damage can be many things, certain types of certain brands or more sensitive in how fast these sectors get damaged. But you can at least try to repair them with the disk repair utility in Win XP, called ChkDsk ("check disk"). However, what may end up happening is that ChkDsk will mark the sector as bad (instead of attempting to recover any information) and your hard drive will no longer 'hover' over top of that area of the drive, making it impossible to recover any data on the sector. Maybe try to google for (free) BETTER third party software for this first. So what caused it is hard to discover after it happened, but you can try to repair it.
Posted on Nov 24, 2008
How to upgrade ST380011A 80GB seagate hard disk to 500GB
First you check your Hard Disk connectivity type SATA or IDE. Then purchase same type of connectivity Hard Disk as your wish. Seagate Desktop internal Hard Disk Available in market (160 GB, 250 GB, 320 GB, 500 GB, 750 GB, 1 TB, 1.5 TB, 2 TB, 3 TB).
Nov 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
What is the Internal Interface of Barracuda 7200.7 ST380011A
READ THE MANUAL AT SEAGATE.
or look at the chips there, see those I/O chips
see the p/n on them. look them up and read the data sheets.
see the pata pins, see them , enter the PCB with copper traces
they land on the I/O chip, and is clearly labeled on all mine.
great question, I worked as and ATE test system programmer and we do this all the time. There are many tests. not just i/o.
Oct 10, 2011 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Not reading correct gb
What is it reading?
Note that 74.5 times 1024 times 1024 times 1024 divided by 1000 divided by 1000 divided by 1000 is 80.
So, if you use base-ten arithmetic, you have an 80Gb disk,
but if you use base-two arithmetic, you have a 74.5GB disk.
Nov 17, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Why hdd shows mbr error
Because either it was corrupted by a bad reboot or (more probably when considering the age of the disk) the disk is dying. Fix the MBR if possible or boot from a Linux Live-CD, recover all your files and replace the disk.
Jun 21, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Disk read error
kindly chek the drive connection make sure the cable is properly connected if possible then change the power connector of the hard disk.and boot the system in safe mode and go to command prompt and type chkdsk /r /f and restart the system.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 22, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Barracuda hard disk 80gb
the first boot sector of the hard drive is corrupt so fdisk wont work
please use software to repair the boot sectors zero and 63.
usually the softwares are superfdisk which is free on net.
also if you fail use seagate disk manager bootable version. it will be very quick and handy in long term too to format seagate hard drives
Sep 17, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Replacement PCB
http://cgi.ebay.es/Barracuda-7200-7-ST380011A-FW-3-06-P-N-9W2003-314_W0QQitemZ200251188516QQihZ010QQcategoryZ64462QQtcZphotoQQcmdZViewItem
or
http://cgi.ebay.es/Barracuda-7200-7-ST380011A-FW-3-06-P-N-9W2003-354_W0QQitemZ200228867743QQihZ010QQcategoryZ64462QQtcZphotoQQcmdZViewItem
Jun 12, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Hard disk I/O error cannot formate harddisk shows no fixed disks how to solve
Please try to check with your cmos system if it was detected, if not means your harddrive was absolutely damage.
Please rate me solved!
Best regards,
Philip
Nov 16, 2007 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
1,504 people viewed this question
Top Seagate Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Computer Links
Steve
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
