Question about LG Dryers
Re: dryer DLEV833W The heat in the dryer doesn't get very hot, whatever the setting. It only seems to get warm and takes ages to dry anything. I noticed the 'damp dry' light is always on, it won't turn off - does this have something to do with it?
    Problem Solver:
  • 4 Answers
If the dryer doesn't get very hot ,you need to check the vent if its clean or not ,turn the dryer on and ch ek the vent from outsid ,But with LG dryer the vent should be clean and not to long
Posted on Nov 05, 2008
I have a Bosch Exccel condenser dryer WLT6305GB/01 FD 8309 200147 it seems to get warm not hot, isn't drying properly, stupidly replaced the heating element and thermostat unit before checking if it...
could be the condenser unit..........they get blocked up with lint..........i take then outside and flush with a hosepipe............
cheers
Jul 27, 2017 | Dryers
Roper rgx4635eq3 warm heat, not drying
You most likely have a defective heating element or thermostat.
May 30, 2012 | Roper Dryers
Clothes not drying
Clothes not drying? Thats it? Does the dryer turn on at all? Does it tumble the clothes but doesn't get warm? If it turns on and tumbles but takes a long time to dry, then your heating element is not working. There is a thermal fuse right before the heating element that will open up if the vent becomes clogged and its gets too hot. The thermal fuse is not resettable and will have to be replaced. If the thermal fuse is o.k. then your heating element could be burned out. These two items almost require an electrical meter to read continuity to check them. Make sure the dryer is unplugged before checking these items.
Dec 21, 2011 | Zanussi TC7114W Electric Dryer
I have an LG model DLE2532W dryer that is taking forever to dry our clothes. I have checked the continuity on the coil and it seems to be fine. I have also replaced the cycling thermostat. The heating unit...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 04, 2011 | LG DLE2532W Electric Dryer
My Maytag Quite Plus clothes dryer gets warm but not as hot as it use to. It seems to take a very long time to dry clothes. Vent is clear. The moisture gage seems to flicker lately.
most dryers have two heating elemts and when one goes out this increases the drying time and could cause a elec. short and trip a braker can be replaced.. There is also a saftey switch that goes bad and will not let the heating elemt work properly ?
Mar 25, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer warm but not hot, long dry times
some times there are multiple heating elements in there and if one is out it does not get as hot. another simpler place to start would be to make sure your line is clear of debries all the way from dryer to out doors. this is a good idea any way since lint build up can cause the occasional house fire.
Jan 23, 2009 | Dryers
Dryer takes too long to dry my clothes
My dryer has been taking longer and longer to dry my clothes. Sometimes it takes multiple cycles before the clothes become dry. They seem to be getting warm, but are not drying as quickly as they use to.
Jul 08, 2008 | Whirlpool ET8CHEXSQ Dryer
Clothes dryer not getting hot enough to dry in a good time frame
I have the same issue with my DLG3788W dryer. It seem to have only one setting for heat, rather than multiple heat settings. What can I do or do I have to call someone to repair this.
Oct 03, 2007 | LG DLE0332 Gas Dryer
Problem with my Kenmore 62622 Electric Dryer
It could be the elements inside dryer, one or more could be bad, the different settings causes the dryer to do different things, so whatever your setting on ultra dry may not be operating at full force. Hope this helps.
Sep 06, 2007 | Kenmore 62622 Electric Dryer
Dryers Logo
290 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
