Question about Microsoft Excel for PC
Can't reopen circular reference file in excel
How to open an excel file that contain a circular reference. When I open it, it show a warning excel security. There's an option disable and enable...What should I do?? Need ur help A.S.A.P...Thanx b4
  • Microsoft Expert
  • 401 Answers
Apply following item repair office 2007 excel file
Item must be useful
Posted on Jun 16, 2013
  • 849 Answers
  1. Click the Microsoft Office Button , click Excel Options, and then click the Formulas category.
  2. In the Calculation options section, select the Enable iterative calculation check box.
  3. To set the maximum number of times that Excel will recalculate, type the number of iterations in the Maximum Iterations box. The higher the number of iterations, the more time that Excel needs to calculate a worksheet.
  4. To set the maximum amount of change you will accept between calculation results, type the amount in the Maximum Change box. The smaller the number, the more accurate the result and the more time that Excel needs to calculate a worksheet.
Posted on Nov 05, 2008
  • akmal104
    akmal104 Mar 14, 2014
    This is only possible if we can open the file else this function will be disable.
Please help me to solve the circular reference in 2013 excel file which stop opening the file. Thank you
first start excel and click on formula tab -->Calculation options -->Manual
excel1-yi4l5i2224qkwob0czw2k0fe-5-0.pngNow open file, if asks for update formulae, say no.
Now select entire sheet, select formulas tab--> Error Checking -->Trace Error.
excel2-yi4l5i2224qkwob0czw2k0fe-5-2.png It will locate all error containing cells, now rectify the error save it reopen in excel to see if problem is solved.
Apr 12, 2017 | Microsoft Excel for PC
Unable to open EXCELL 2007 workbook containing a circular reference problem.
open Excel
Click the 'Microsoft Office' button and click 'Excel Options'. Click the 'Formulas' button. From 'Calculation options' section, un-select the 'Automatically' option. then use file->open->yourfile.xlsx. It should now open. Find the circular reference and fix it. Then save the file.
Mar 18, 2013 | Microsoft Office Excel 2007 Full Version...
What is a workbook?
A workbook is a spreadsheet file. By default, each workbook in Excel contains three pages or worksheet
The term spreadsheet is often used to refer to a workbook, when in actual fact, spreadsheet refers to the computer program, such as Excel.
So, strictly speaking, when you open the Excel spreadsheet program it loads an empty workbook file consisting of three blank worksheets for you to use.
Jun 25, 2011 | Microsoft Office Excel 2007 Full Version...
My Excel 2007 status bar shows the words "Calculate" even though my calculation is set to automatic. From my experience with the prior version of Excel, this indicates a circular reference error....
A couple of possible causes:
Setting Workbook.ForceFullCalculation to True will cause this.
The Iteration Option is turned on and the workbook contains circular references. Turn off Iteration (Tools-->Options-->Calculation) and press F9-- it may show "Circular Reference."
Jun 20, 2011 | Microsoft Office Professional 2007 Full...
Dear Expert I am using Windows Vista TM Home Premium at my Notebook Pc( HP Pavilion dv-5) with Microsoft office 2007 since last 01 year. My excel files are not opening and I am receiving following message...
maybe you relocated the file itself, check first if the file you are opening is still in its original location on your hard drive, if not, manually open it by double clicking, do not open it inside microsoft excel.
Jun 02, 2010 | Microsoft Excel 2003 (06503995)
AutoCAD LT 2008 (xref circular references)
The "circular reference" indicates that the xref you are pulling in is also xrefing the drawing file you are in which creates this circular reference to each other. The error message is only a warning and does not prevent you from working and saving changes. To get rid of the error message, close the primary drawing file and then open the reference drawing and DETACH the xref that is linked to your primary drawing. Save the changes and then open the primary drawing file again to see if the error was resolved.
Mar 16, 2009 | Autodesk AUTOCAD LT 2008 SLM 10 SEATS...
Circular reference working how to open excel file
Clicking cancel will invalidate the formulae, circular references refer to the dependant and precedent cells using each other.
Track/ Audit depending on your Excel version to show which formulae is incorrect - or options view, tick show formaulae and remove them.
Nov 20, 2008 | Microsoft Excel for PC
Circular reference errer in excal file in office 2007 Problem. when i open excal seet and whant to change and save. then pc show problem? ple help me shamsherpatel
Hi shamsherpate
In order to remove this error message you need to locate and remove the incorrect references:
On the Formulas tab, in the Formula Auditing group, click the arrow on the Error Checking in-group button, point to Circular References, and then click the first cell listed in the submenu.
Tip You can move between cells in a circular reference by double-clicking the tracer arrows.
Review the formula in the cell. If you cannot determine whether the cell is the cause of the circular reference, click the next cell in the Circular References submenu.
Note The status bar displays the word "Circular References" followed by a reference to one of the cells contained in the circular reference.
Continue to review and correct the circular reference until the status bar no longer displays the word "Circular References."
Jun 06, 2008 | Microsoft Excel for PC
Excel files do not opening autometically
reainstall it or repair your office from add remove menu in control panel or update online office updater microsoft ok cheak to see if u have sum download the latest flash and adobe shockwave and java ok
Jan 24, 2008 | Computers & Internet
Open Questions:
See all Microsoft Excel for PC Questions
Microsoft Excel for PC Logo
3,256 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
