Question about Supersonic 5.1 CHANNL HOMETHEATR DVD System
Only have sound on my front speakers with my HT - AS8 home theater system
I have checked all connections multiple times, and even swapped speakers connections to ensure that all the speakers are fully functioning. I only hear out of the front 2 speakers, nothing out of the 2 rear, center or sub. I'm pretty sure it is a programming issue, but for the life of me can't seem to figure this out. I'm not a novice at this, but am quickly running out of ideas. Please help.
  • Jason Johnson Oct 07, 2006
    i have taken a look even further, but your description is a slightly better situation than i am in. I don't even have suround while watching a DVD. Even then, i only have the front 2 speakers working. i will continue to check my TV settings though.
    President:
  • 3,130 Answers
This is a very common complaint that new users complain about. On your system or modt folks system, they say that the DVD will work fine on the surround but the TV set and or the radio will not. The biggest problem I have found regarding this is that the TV set is not connected through the correct audio plugs and/or the suround selector switch was set to the wrong surround setting. Look on your owners manual for the correct settings when using a TV set or set the setting to differant mode while having the TV set on.
Posted on Oct 07, 2006
Onkyo HT R520 Home Theatre reveiver/amplifier problem
If you have isolated the problem to the receiver/amplifier, it will be necessary to find out why that output is dead
Oct 04, 2012 | Onkyo Audio Players & Recorders
My SONY Home Theater Model HT-6600DP unit was working fine and then about tow years after...present, my sub woofer is sounding distorted. Why is this happening? Please help me as I often watch my home...
Is it so even at lower volumes?
Are you sure it's the sub distorting and not the front or center speakers?
If you designate them incorrectly as Large (which tells the receiver they CAN effectively produce bass frequencies) they will probably distort in the presence of low frequencies.
See Page 17, 19
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-HT-6600DP-Home-Theater-Systems-manual/id/390ag319/t/2/
Mar 13, 2011 | Sony HT-6600DP System
Soundproblems on my Home Theater System
http://downloadcenter.samsung.com/content/UM/200702/20070207171859140_XQ100TXQ100_GB.pdf
Suggest you go back and check all connections with speakers that wires are connected with input properly I have given you web address for manual usually find wires are not bared back enough for connection test each one individually with a tester to make sure there are no broken wires.
Mar 05, 2010 | Samsung HT-XQ100 Theater System
Cannot connect my HT-320 home theater to my TV. I
can not get tv sound through speakers---can only get sound from dvd
Dec 28, 2009 | Samsung HT-Z310T Theater System
System is samsung HT-TWZ415. all speakers work, not the sub
Check all of your connections, and make sure all cords are firmly connected.
Make sure if the subwoofer has a power switch, it is on, and if not, that it is likely to be faulty.
Jul 16, 2009 | Samsung HT-AS720ST Theater System
How do i hook this up Samsung HT-WX70 Theater System with Wireless Speakers
1. Connect the front left, front right, center, and sub woofer speakers to the back of the home theater system.
2.
With the home theater system off, insert the TX card into the TX Card connection (WIRELESS) on the back of the home theater.
Important:
Make sure to insert the TX card with the slanted portion of the card facing left.
3. C
onnect the rear left and the rear right speakers to the back of the SWA-3000.
4.
Plug the power cord of the SWA-3000 into an electrical wall outlet, and then switch the power switch on the back of the SWA-3000 to [ON]
Hope this helps!
Jun 27, 2009 | Samsung HT-WX70 Theater System
HOME THEATER SAMSUNG HT-Q100
Your systemn is designed and built to perform 2.1 sound. If you want 5.1 sound you can do 2 things, connect another pair of speakers to the same speakerterminal as your front speakers, however this produces 5.1 stereo sound and not 5.1 surround sound.
You can buy a new system that has the proper connections.
This set will not have the proper decoding software to produce 5.1 surroundsound. sorry.
Jan 16, 2009 | Samsung HT-Q100 System
SAMSUNG HT-TX72 - NO SOUND
check connections to bass module amp. and ensure that it is powered on and turned up . no blown fuses or loosely connected cables. to and from amp. especially those to stellite speakers.
Mar 08, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Swa3000
  1. With the home theater system off, press and hold the REMAIN button on the home theater's remote control for 5 seconds.
    Note: You can release the REMAIN button when the POWER LED blinks blue/Red depending on model.
  2. With the SWA-3000 turned on, use a ball point pen to press the RESET button on the back of the SWA-3000. The POWER LED in the front of the home theater blinks two times.
Feb 14, 2007 | Samsung HT-Q70 Home Theater System System
121 people viewed this question
Top Supersonic Audio Players & Recorders Experts
Martin Buenrostro
Martin Buenrostro
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Supersonic Audio Player and Recorder Expert? Answer questions, earn points and help others
