Question about Toshiba Satellite A105-S4164 Notebook
Icons and pages are too large and fuzzy
I ran DriverScanner. Now, all the icons are too large (can't be fixed with display properties), the pages are too large and the fonts are fuzzy.
  • dldaniels Nov 05, 2008
    Tried your suggestions, but they didn't work. Any others?????
    Thanks!
    Scholar:
  • 59 Answers
Hi dldaniels first thing is you need to go to display settings click on the advance button and make sure the DPI is set to 96 this is default setting.
Now if the DPI is 96 you may have acidentaly changed the accessiblity setting,
click on the start button and go to accessories then choose accessiblity and then click on the wizard..from here you can change it back.
Now the other thing you can check once you have done that is to check that your using clear type fonts, on the display properties of the desktop by right click on blank space and going to properties, then choose the appearance tab click on effects...then make sure it using clear type.
hope that helps
Posted on Nov 05, 2008
Some of my desktop icons have grown to be very big. I want small icons.
in windows 7 right click on the desktop and select Personalize. Then click display on the left. Choose small, medium or large.
in windows xp;
Shrinking Icons in Windows XP
  • 1 Right-click on the desktopicon1.png. A drop-down menu will appear on which you will click on "Properties."
  • 2 In the "Display Properties" box, click on the "Settings" tab.
  • 3 Slide the scale in the "Screen Resolution" box to the right to shrink the icons (and everything else that appears on the screen).
  • 4 Click on "Apply" and then click on "OK."
  • 5 Click on "Start" and then right-click on an empty space until a box that says "Properties" appears. Click on "Properties."
  • 6 In the "Taskbar and Start Menuicon1.png Properties" menu, click on "Customize."
  • 7 In the box that says "Select an icon size for programs," click on "Small Icons."
  • 8 Click on "Apply" and then click on "OK" to adjust the size.
Shrinking Icons in Windows Vista
  • 9 Right-click on the desktop. When the drop-down menu appears, run the mouse-pointer over "View" and click on "Classic Icons." This will shrink the icons if they are set to either "Large Icons" or "Medium Icons."
  • 10 Right-click on the desktop again and click on "Personalize."
  • 11 On the "Personalize appearance and sounds" screen, click on "Taskbar and Start Menu" on the left side bar.
  • 12 In the "Taskbar and Start Menu Properties" menu, click on the "Start Menu" tab.
  • 13 Click on "Customize."
  • 14 Find the box that says "Use large icons." If it is checked, uncheck it and click on "OK." This will shrink the Start Menu and Taskbar icons.
Read more: http://www.ehow.com/how_4855250_make-windows-icons-smaller.html#ixzz2ifeSGGtj
Sep 08, 2013 | Computers & Internet
Fuzzy Display
try to reset the device into factory defaults, you should be able to perform that from the menu. then set the native resolution and perform the auto adjustment.
Apr 27, 2008 | ViewSonic N2000 20 in. LCD HDTV
How to change the size of desktop icons
Right click on the Desktop to bring up Display Properties - Click on Appearance tab - then click on Effects button - and then tick Use large icons box - click OK - Click Ok in Display Properties to make the change.
Jun 19, 2012 | Acer Aspire 5742Z6682 Notebook
Icons and fonts are too large
hi,
  • To change font;
  • Right click on free space on the desktop.
  • Select properties then under display properties select Appearance.
  • At the bottom is font size option.Select normal.Save.
  • Icons:
  • Repeat font change procedure selecting settings under display properties.
  • Move to screen resolution and re-set it.[eg to 1024by768 pixels].Save.
Sep 16, 2011 | Microsoft Computers & Internet
How to change icon size on laprop
Try to go to this link, on how you change icon size.
http://www.techtalkz.com/windows-7/516049-how-change-font-size-icon-size-windows-7-a.html
AnEspera
Apr 18, 2011 | Computers & Internet
My display resolutin is too small, thatswy my screen shows very small as compared to monitor size....!! what can i do? the H size and V size is correct..!!
You probably know about adjusting the monitor display size by right clicking on a blank area of the desktop, choosing properties, settings and moving the slider towards the left. 800x600 will make everything very large. (XP instructions)
You can also get there via the control panel, display, settings.
While on that page, you can click appearance and change icon size.
Aug 22, 2010 | Computers & Internet
I logged on the other day and every thing on my screen seems magnified everthing looks much bigger than it usually is how do i get it back to normal
Try to check the display properties.
On the desktop right click and select properties (do not point the mouse at the icon)
On the settings tab adjust your resolution to the highest level. Change the color quality to highest 32 bit. Click apply and press OK
That should do it.
However there are instances that display settings are OK, but when you open any applications the page is very large...
Do this to adjust the page: Press and hold "Control" key. While holding the control key press the "+" sign to adjust the page to a larger size; press "-" sign to reduce the page.
Hope this help you...
Much appreciated if you rate this help.. thanks
May 20, 2010 | Office Equipment & Supplies
Fuzzy text
Try adjusting the Font Smoothing effect in the display properties. Windows XP http://support.microsoft.com/kb/306527
Nov 28, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
Dell touchpad icon missing
'Inactive icons' in the System Tray next to the time display do not display using the defaults in XP. To change this, right click over the Taskbar and choose Properties. Once you are in the Primary property page unselect "hide inactive icons." This may require you to log off or even reboot to affect this change.
Still, to get to the property pages for your Touch pad you want to enter Control Panel and then Mouse. Inside the Mouse property pages for control panel you'll see a property tab for the glide pad. Make your desired setting and then reboot. As you may already know, the scrolling function of the glide pad is accessed by drawing a finger down the far right hand side of the glide pad surface.
Hope this has helped and fixed ya.
Worldvet
May 20, 2008 | Computers & Internet
Toshiba Satellite A105-S4164 Notebook Logo
200 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
