Canon pixma ip 1000 service error 6800
After initialization, the indicator light flashes from green to orange alternately and continously. The status monitor indicates that service error 6800 occurred. Turning it on and off did not work and cant enter to maintenance mode. Thanks in advance, i believe in you guys!
  • 1 more comment
  • kje-ol-t Dec 07, 2008
    Error 6800. Flashes alternately between green and orange light. Nothing happens! No printing is possible. The ink-carrier "wagon" is immovable.
  • Anonymous Apr 02, 2009
  • hm2010 Apr 02, 2009
rizla
  • 1463 Answers
SOURCE: Drivers for :Canon Pixma IP 1000
here you can find the drivers for canon drivers hope this is the one you need .
riz.
Posted on Feb 13, 2008
judesoul
  • 127 Answers
SOURCE: canon ip 3000 photoprinter not working
things to check.
1. check for any paper that may have jam inside the printer.
2. check for open covers, back, top covers and close them properly.
4. check your power adapter if its giving correct voltage to the printer.
3. Try to move the ink cartridge to the left gently and return back to the right most part.
please let us know if this works.
Posted on Feb 07, 2009
wayneard
  • 1901 Answers
SOURCE: I dont have CD to installe my PIXMA ip 1000
OK, found it.
Here is a link to the support page:
Canon iP1000 Support
Enter your operating system and language and click Submit.
The driver and other available software will be listed and can be downloaded to your computer.
If you have trouble comment back and I'll help further.
Thanks for using Fixya!
Posted on Feb 23, 2009
  • 412 Answers
SOURCE: Canon Pixma MP830 error 5100
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 09, 2009
suxia
  • 143 Answers
SOURCE: PIXMA IP 1000
For XP 32bit also for software and other operation system downloads see support.
If helpfull rate.
Posted on Aug 05, 2009
Green and orange light flashing and on the screen was Service Error 6800
Service error 6800 means that a problem occurred in reading from or writing to the EEPROM. To fix this you need to replace the logic board. For replacement you can try http://www.partsalliance.com or http://www.ppsnj.com
Dec 02, 2010 | Canon PIXMA iP3300 InkJet Photo Printer
Waste tank to be cleared pixma ip 1000
Reset waste ink tank counter CANON PIXMA iP 1000
- Turn off the printer, and disconnect the printer cable
- Press and hold the POWER button, turn on the printer
- The Indicator (LED) should be green
- Press and release the RESUME button, the Indicator (LED) should be orange
- Press and release the RESUME button again, the Indicator (LED) should be green
- Release both button
Oct 03, 2010 | Canon iP100 Portable Printer
Canon IP 3000 - ink absorber full
<Service mode operation procedures>
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the
Power button. (DO NOT release the buttons. The LED lights in green to indicate that a function
is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the
Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release
both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed,
the LED lights alternately in orange and green, starting with orange.)
4) When the LED lights in green, press the Resume/Cancel button the specified number of time(s)
according to the function listed in the table below. (Each time the Resume/Cancel button is
pressed, the LED lights alternately in orange and green, starting with orange.)
Times LED Function Remarks
0 times Green Power off When the print head is not installed, the carriage
returns and locks in the home position.
1 time Orange Service test print See APPENDIX 1, SERVICE TEST PRINT.
2 times Green EEPROM information print See APPENDIX 2, EEPROM INFORMATION
PRINT.
3 times Orange EEPROM initialization
4 times Green Waste ink counter resetting
Jul 02, 2010 | Canon PIXMA iP1300 Printer
I have a Canon Pixma IP 4000 and keep getting the error message that the ink absorber is nearly full. Print quality is not good even after cleaning. What should I do?
Resetting Ink-Waste Overflow Counter Canon Pixma iP3000, iP4000, iP5000 Printers
1. With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold the Power button. (DO NOT release the buttons. The LED light should be green to indicate that a function is selectable.).
2. While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.).
3. While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
4. When the LED light is green, press the Resume/Cancel button 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
5. Press the Power button. The LED lights in green, and the reset is performed. (When the operation completes, the printer returns to the menu selection mode automatically.).
6. Press the power button to exit service mode.
Note: if you accidentally press the Resume/Cancel button more than 4 times in step 4 then just press the Resume/Cancel button at least 10 times and the printer will be returned to step 4 automatically
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 09, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Waste inki absober is full. The indicator orange
You can remove the top of the printer to remove and clean the pad or reset the printer and continue without cleaning.
These are the instructions which worked for me on my Canon pixma ip470 and has work on many other Canon models:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Feb 15, 2010 | Canon PIXMA iP90 Mobile Printer
Hi, i geting problem in inkjet printer connon
These are the instructions which worked for me on my Canon pixma ip470 bought August 08:
Jan 08, 2010 | Canon Pixma iP4500 InkJet Printer
Canon Pixma iP1600 Printer problem
this is the service error download canon chip resetter utility, then reset your printer , download IP resetter utility
Nov 14, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
944 people viewed this question
jasbo
jasbo
