Question about Gateway (M520HD80G) Hard Drive
Will not boot up
HELP!!!! Keep getting an error message stating no hard drive detected. Was working fine one minute and when I went to log on later it gave me this message. Tried to recovery disc and again it states no hard drive detected.
  • Anonymous Nov 10, 2008
    2003 Desktop Gateway was working fine then the screen went black, a msg said something about windows32 file may be corrupt insert operating disk and hit "r' to repair. I did this and it didn't work. Now the error msg keeps saying "hard drive not detected" I'm not sure if I got a virus or if the hard drive has gone out?
  • honman Nov 29, 2008
    I have the same exact problem. What is the HD cable?
  • 749 Answers
Try reconnecting the Cable then turn it on
if it still can't detect your HD,
replace cable with new one
just make sure that your HD wasn't making weird sounds internally lately (ticking)
Posted on Nov 05, 2008
Hard drive corrupted. Needs to refresh. If does, then I get the same error message again
Keep taking it out and re-inserting back in with it turned on (a bit dangerous, be careful.) Sooner or later you'll get a message asking you if you'd like to format your hard drive to fix the problem... accept and it'll re-format your hard-drive, you log in details would still be there but all other stuff will get erased. It worked for me, hope it works for you. Take care.
May 14, 2010 | Sony Playstation 3 (PS3) Console
I reciently installed a bigger HD and now I get the"blue screen from hell"!! How can I get it to boot on the new HD?,Ray
did you format the hard drive first?
typically you need to format the hard drive using the NTFS file system before you install your operating system.
does your bios recognize the hard drive?
make sure your bios detects the hard drive.
can you boot your computer in Safe Mode? If so, do that and use your error log to find the specific cause of the blue screen,
lastly post the blue screen error message on here to get a better answer.
Nov 26, 2009 | HP EliteBook 6930p Notebook
PXE-E61: media test failure check cable
The PXE-X61 error means that the laptop cannot detect the hard drive. This can be caused by a faulty disk controller, or a faulty disk drive.
1st. Reseat the hard drive and see if the laptop boots up.
2nd. Go into the BIOS configuration and see if the BIOS detects the hard drive.
3rd. If the BIOS can't detect the hard disk, the remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer detects this drive as an external disk drive and you can see the contents of the hard drive, then the hard drive is OK and the fault is in the laptop.
4th. If the hard drive cannot be detected then the hard drive is faulty, you need to replace the faulty hard drive in your laptop and install Windows to get an operating laptop again.
May 18, 2009 | HP Pavilion dv1000 Notebook
I have a seagate momentus 5400.3 160gb drive installed in a Thinkpad t60 laptop. It was working fine until after I had put it in hibernation, and subsequently tried to get back in (approximately 2 hours...
Configuring the BIOS
After completing the drive installation, restart your computer. Your computer
may automatically detect your new drive. If your computer does not
automatically detect your new drive, follow the steps below.
1. Restart your computer. While the computer restarts, run the system
setup program (sometimes called BIOS or CMOS setup). This is usually
done by pressing a special key, such as DELETE, ESC, or F1 during
the startup process.
2. Within the system setup program, instruct the system to auto detect
your new drive.
3. Save the settings and exit the setup program.
When your computer restarts, it should recognize your new drive.
That should work ya long haired hippie. give me a shout this weekend, M.Y. (puff puff pass *****!)
Feb 21, 2009 | Seagate Momentus 5400.3 Hard Drive
Cd/dvd problem on toshiba m45-S165 laptop
Is you new hard drive lager than you old on and was the disk drive a factory replacement cause with those disks if you even change just that they will not work
Dec 09, 2008 | Toshiba Satellite A45-S250 Notebook
Does it give you a command prompt,example c:/?If so type chkdsc and this will scan the hardrive for boot errors.Let me know.
Feb 20, 2008 | Acer Veriton 5100 PC Desktop
"A disk read error has occurred. Press Ctrl+Alt+Del to restart."
try this. load defaults on bios. retry boot from xp cd. on windows setup. choose recovery console. on dos mode. choose OS (XP). Run CHKDSK /R.
Feb 16, 2008 | HP Pavilion dv1000 Notebook
Hard drive controller
Certain diags only test the diagnostic tracks. That is what's passing more than likely. You should boot the laptop in safe mode (F8) and click start, run, type in cmd, hit enter and type scandisk. This will do a complete scan on the drive. If there are any errors replace the drive.
Jul 30, 2007 | Compaq Armada 1700 Notebook
Hard drive controller problem
S.M.A.R.T (system monitoring)is the warning software that detects when a hard drive is about to fail, so i would back up any important docs to a disc or usb drive immediately and replace the hard drive. The hard drive controller itself will not be the problem, it's the controller saying that the problem is the drive, the controller is only a driver and not a peice of hardware, pressing F1 will ignore any faults and continue to boot, but especially if it doesnt always boot it's definately your hard drive.
Jul 26, 2007 | Compaq Armada 1700 Notebook
Gateway (M520HD80G) Hard Drive Logo
192 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
