Question about Maytag Neptune MDE5500AY Electric Dryer
Moisture in my dryer
I have moisture in the dryer and yet it seems to get hot and the vents seem to be working and are clean. I don't find it plugged anywhere
What could the problem be
  • jackieroth Nov 07, 2008
    Maintenance guy found something wrong with the drum. The vents were open . Thanks for the help
  • mjmcvey Nov 30, 2008
    but did it get the clothes dry with heat? just very SLOWLY? our is not allowing moisture to escape quickly ... is the vent to the outside the only vent to check?
    President:
  • Maytag Master
  • 2,651 Answers
Moisture in tha dryer is definatly an issue with not being able to vent out the moist ais from drying the clothes, did you check where the vent exits the home?, the only way moisture collects in a dryer is by not properly venting it out...
Posted on Nov 05, 2008
Whirlpool Cabrio Dryer moisture sensor not working
The moisture sensor may be contaminated with softener residue. The residue can be removed with window cleaner ONLY.
Feb 01, 2018 | Dryers
CLOTHES WONT DRY. IT GETS REALLY HOT INSIDE. THEY SEEM WETTER AFTER IT RUNS FOR AWHILE. TAKES PROLLY 3 HRS TO DRY.
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
May 22, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
Dryer unevenly drys clothes
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
Jun 21, 2010 | Bosch Nexxt 500 Dryer
My whirlpool AWZ510E washer dryer - the dryer doesn't seem to be working - it goes through the cycle but the clothes are still as wet as before. I am using the same cycle as I always have which used to...
there are 3 reasons for a dryer not doing the job yet running through the motions. 1st, the heat is not being produced and only cool room temp air is circulating. this can be a burned-out electric element or an over-heat sensor, or in0line safety fuse. ( if gas, can be ignitor or gas valve coils).. It could be that the washer is not ringing (spinning) dry the clothes verywell and there is too much moisture stiil in clothes which would double the dry time from 50-60 minutes to 2 hours. 3rd, could be clogged vent line and the hot moist air cannot leave the dryer so the clothes get hot by the moisture stays.
Apr 28, 2010 | Whirlpool Washing Machines
Dryer blows some warm air but cloths are not drying...lots of moisture inside the dryer...there seems to be limited air movement
If you are heating somewhat and have lots of moisture the issue is with the venting.
For one reason or another the unit is unable to exhaust the moisture from the clothes. Check the following.
- Make sure there is air coming into the room the dryer is in (not in a closet with the door closed etc)
- Check the vent pipe behind the dryer. You are looking for kinks or restrictions. You may have to take it off and clean it out.
- check the venting between the wall behind the dryer and the outside, if this is plugged you can try using a long brush and vacuum from both sides or even a leaf blower if you have one, blow from inside to out so you do not make too big of mess, if you cannot get it clean you may have to hire someone to come professionally clean it.
Apr 22, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Over heats , and has lots of moisture vapor coming out of the bottom.it dries and everything ,but its like it's leaking water
The most likely cause is your home vent is clogged and the dryer has little or no air flow. The water is exiting the dryer with the air since there is little air flow which causes the "water leak". Clean your home vent all the way through and your dryer will probably also need a good cleaning. This should take care of the problem. Please rate this post.
Dec 14, 2009 | Dryers
Maytag MDE8600AYW takes way too long drying clthes
either your house vent is plugged, or the vent in the dryer by the blower is plugged. when the vent is plugged, even partially, the moisture is not leaving the dryer. It will take a long time to dry, and the top of the dryer will get hot when the vent is plugged. Clean the house vent and check down below the lint trap by the blower, then it will dry fine again.
Oct 09, 2009 | Maytag MDE8600AY Electric Dryer
DRYER TAKES LONGER TO DRY
you could have restricted airflow from the lint screen not being cleaned, a bad blower wheel, or a bad thermostat. take the vent hose off the back and check to see if the air flows out the dryer with good force, if so your vent is probably clogged or not open in the wall. the vent hose may also be picned off from puching the dryer back to far.
Sep 17, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool gas dryer is not hot .burner ignights but it is not hot enough
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
if this helps please give me a fix ya vote
Jul 14, 2008 | Whirlpool Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
115 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
