Question about Whirlpool LGQ9858P Gas Dryer
Whirlpool Dryer LGQ9508PW0 flame comes on and shuts off after 30 seconds.
  • Whirlpool Master
  • 2,651 Answers
This might actually be normal, whats the complaint??? to long to dry clothes maybe 2-3 cycles??? would be a common complaint. in which id check to make sure vent is not clogged anywhere, especially where exiting the home if he venting is ok id replace the coils atop the gas valve, possible and common for that matter that after running for 20-30 min they do not reopen and dont allow flem to reignite... part number 279834 retails for about $20 easy enough repair.... reason for flame to go on and turn off after only 30 secs is that in an empty dryer 30 secs of heat may be enough to satisfy the thermostat, that's alot of heat for an empty dryer, it would remain on for longer with a load of wet clothes absorbing the heat
Posted on Nov 05, 2008
Why won't my gas dryer heat?
If your flame comes on for a few seconds & goes away,replace your solenoids. ($3.00)
If your flame doesn't come on at all, it could be the fuse(unsure of cost) Check the neg/pos lead with an OHM meter(multi meter), to see if there is continuity.
Let us know if this helps!
Jul 30, 2014 | Whirlpool LGB6300 Gas Dryer
I have a gas dryer, model MDG7657AWW that will not stay heated. Every time I put it on, the flame comes on for about 21 seconds & then shuts off. I replaced the igniter, hi limit thermostat, cycling t
On a gas dryer the heat normally only comes on for 30 seconds or until the drum temp reaches 160f at which time the flame is shut down by the cycling thermostat. The drum temp then starts to drop. When the drum temp reaches 105f then another blast of heat is issued for 30 more seconds.That is how they work. Put it all back together and trow a load in there.
Oct 28, 2011 | Dryers
The dryer heats up for a short time then cools down after about 1 minute. How do i repair? This is a Whirlpool LGQ9508PW0
From what you are saying you need to replace the gas valve coils.You need to remove the front to access them.They are on top of the gas valve.
Jul 24, 2010 | Whirlpool LGQ9858P Gas Dryer
Dryer won't dry
Well lets talk about it a minute. The ignitor is ok because it does glow. The flame sensor is ok because the ignitor is working. The only other thing in the circuit is the solenoids. So what goes wrong? Those coils get hot and quit with age.7ecd66c.jpg Replace them and the dryer will come back to life.5dc4e80.jpg
Jun 28, 2010 | Whirlpool WGD5500S Dryer
Model 110.74852400. How do i get to the coils to
Just changed the coils on the same dryer 110.74852400 but problem not fixed...flame burns for 30 seconds and shuts off...relights in about a minute, than burns 30 seconds, shuts off...any advice??
Oct 03, 2009 | Kenmore 73952 Gas Dryer
Whirlpool model GGQ8858EQ1 gas dryer starts, gets flame and begins heating. then after a short while flame shuts off and i hear a chattering noise somewhere near the bottom of dryer. It lasts for about...
The problem is your gas valve solenoids (coils). There are usually two of them mounted on the burner assembly. One is the MAIN coil, the other is the SECONDARY coil. It is recommended that you replace BOTH of them at the same time. Replacements can be purchased on line at Just type in the model number you provided and look under the "Burner Assembly" section for items 13 and 14. I hope this helps you.
May 05, 2009 | Whirlpool Dryers
Gas valve opens whith a weak flame
you must clean the flame tube and flame orifice with a pipecleaner
Jan 11, 2018 | Whirlpool LGB6000KQ Gas Dryer
GGW9868KL0 SENSEON GAS DRYER Flame comes on but clothes not dry
since you know your stuff and our exhaust is clear correct,,,change your gas vavle coils ..if weak they will shut unit down in a couple of mintues..
Dec 20, 2008 | Whirlpool LGV4634JQ Gas Dryer
Whirlpool LGQ9858P Gas Dryer Logo
455 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
