Question about Plumbing
Please Help me
I took the cover off my intertherm thermostat because I was painting that wall and I did not want to get paint on it. I also removed the dial, which you use to adjust the temperature. I tried to put the dial back in but it does not seem to be in their very tight. My heater is not stuck in the on position at 90degrees! Please help me. How do I get the dial to go back in and click into the off position?
Thanks soooo much!
Emily
    Scholar:
  • 35 Answers
You can try this.... Turn off the power to your furnace. Carefully remove the cover and the dial. Put the dail back on making sure it is level. Make sure the switch is in the off position. Replace the cover and turn the power back on.....Let's start from there.....Joe
Posted on Dec 16, 2008
I have a 2017 Holden Captive LTZ 7 and I am trying to find the paint code sticker. Wher can I find it. I have looke around the door pillars but no paint colour codes. Please advise Thank you
Hi David They normaly have the paint code on one of the stickers or plates. Try under the bonnet on rear fire wall are there any black or silver plates. Also check under the rear floor cover at the rear tailgate.Or in your sevice manual they normaly have a sticker with your vin number etc.paint code should also be there. Good luck.
Aug 26, 2017 | Holden Cars & Trucks
Can you use ultra white paint as a primer on a wall before painting it?
Not recommended, especially if the ultra white paint is anything but "flat." Primer is designed specifically to adhere to other paints. Look into KILZ primer (if it is available where you are), as I have found it to provide excellent coverage for color changes.
May 08, 2015 | Tools & Hardware - Others
How do I calculate the amount of paint needed for walls in a 12 foot by 16 foot room with 8 foot ceilings?
Ceiling paint estimator
Use the following formula to estimate the amount of ceiling paint you need. Double the result if the ceiling requires two coats.
1. Multiply the length of the ceiling times its width to find its area.
14 × 20 = 280 square feet
2. Divide that number by 350 (the estimated square feet covered per gallon) to figure out how many gallons of paint you need.
280 ÷ 350 = .8
For this example, you want to buy 1 gallon of ceiling paint for a single coat.
Wall paint estimator
Use the following formula to estimate the amount of wall paint you need. Double the result if the walls require two coats.
Feb 18, 2015 | Tools & Hardware - Others
Can someone help me with interior painting tip for
I need more info...please explain with more detail. I have 30 years experience as a house painter.
Nov 07, 2014 | Tools & Hardware - Others
Oil from a reed diffuser spilled all down my bathroom wall on Benjamin Moore paint how can I remove the oil thT stained the painted wall
I would wipe it down with a degreaser like Simple Green, or paint thinner
The paint is ruin after cleaning it you will need to paint. You can prime the area with a oil base white primer in an spray can
Jul 23, 2014 | Tools & Hardware - Others
Is recycled paint good for walls
generally speaking if the lids have been left on tight and you strain the paint with a stocking it will be ok but it might not smell to pleasant for a few days.try dropping in some perfume to kill the smell or a tea spoon of bleach will do suffice.
Jun 25, 2014 | Tools & Hardware - Others
What can i do to fix peeling paint on a wall?
scrape, sand, Prime with an acrylic primer ,skim texture and top coat
or call a professional
Paint scratches off easily on drywall
You can find good colours for painting your wall and good durable paints and follow it with the help of interior designers. They provide plenty of samples and designs for your requirement and guide you. They use many fabric paintings, hand painted wall papers, laminated multi coloured wall papers with different textures. For further ideas and assistance you can contact them at http://www.interiordesign.net/. Homepage Interior Design
Feb 18, 2014 | Dutch Boy Int Drywall Pva Primer By Dutch
I'm painting my bedroom tomorrow and want to cover my furniture. Where do i get that plastic stuff?
Do you mean tarps? You can get them at any place you would buy paint supplies like Home Depot or your local tool shop.
Jan 28, 2013 | Tools & Hardware - Others
I have the hds780rs0605 I need to know if I can use latex paint for my walls and how to with out it clogging up
Let me start by saying these types of paint sprayers are not usually recommended for painting large things like room walls because you're going to spend a lot of time refilling the paint cup. The cup only holds 20 ounces of paint and that won't go very far on your walls. If all your paint isn't mixed and properly thinned at the same time your walls could end up with a checker board look. You would usually be way further ahead to rent an airless paint sprayer.
If you have to use it; first run your paint through a paint strainer, avaliable at any paint or box store (The Home Deopt, Lowes, etc). Even new paint has impurities that will clog paint guns. It's highly recommended you mix in a paint conditioner like Flotrol but not absolutely necessary. Next, you're going to have to experiment with the consistency of the paint to get a good even flow out of the gun. The thinner you have to make the paint to get a good flow, the lighter and more coats you're going to have to apply. It's also recommended to run a paint soaked roller over the wall right after you spray it to even out the paint and remove any overlap marks.
Aug 05, 2012 | Air Tools & Compressors
Plumbing Logo
67 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
