Question about Sony Playstation 3 (PS3) Console
Cannot connect to internet servers for cod2 pc
Switched internet providers from rcn to verizon and had installed a new modem router. The tech could not get any servers to list from the server menu. My saved servers work fine and I can play the servers I have saved. The tech thinks its something to do with a port. On his cd rom disc that was loaded into the modem there was no cod2 listed but there were about 20 other modern games available HELP
bill bowen
bowenw1@verizon.net
Update your cod 2 with patches ( see xfire.com)
ad update your punkbuster
Posted on Nov 21, 2008
I can't connect to certain things online. When I go to Farm Town it says "Connection to server time out". Then list 3 things to try. I've tried all of them and more! Is this a router problem or a...
welcome to verizon
ok ok ok it is the server and it is not your fault.... call your internet provider...talk to a technician have them PING YOUR COMPUTER.... Have them ping the web site you are trying to talk to....go thru the fire drill with the modem....ask for service... be nice and be firm...pencil and paper write down names be nice
Nov 25, 2010 | Computers & Internet
I just got a new modem from verizon because i switched internet providers and the internet works just fine when connected directly to my computer but when I try to use my lynksys wrt160n router I get no...
Depending from ISP it might be necessary to clone your MAC address. To do this you need to login to router settings page. You might find helpful user manual for your router: http://rapidshare.com/files/427341934/WRT160N_ug_0.pdf Start reading from chapter 3
Oct 26, 2010 | Linksys WRT160N Wireless Router
Installing Westell modum to time warner high speed
Please view my How-To on how to program your Linksys WRT54G router. You can view it at this link:
http://www.fixya.com/support/r3995607-setting_up_or_resetting_linksys_wrt54g
Good Luck,
NOLA Tech
Jan 22, 2010 | Linksys Wireless-G WRT54G Router
Cannot connect to my Sony laptop with Windows vista
Hmm..the best way I can think of here is to get both Techs on the same line so that they can discuss what the problem really is. I've tried this before and I have to admit. Things worked out very well, It seems a device built in my laptop was not running properly, so I had to install it again, it's called the NIC or Network Interface Card and it's the device that allows your laptop to communicate with the modem.
Regarding the lights in your modem. The DSL light should always be Steady Green, that means that your modem is in Sync with the network. If it's blinking, check all connections, make sure every physical connection is connected properly, if the dsl light is still blinking, that's a network problem already and you should call Verizon so that they can send a tech to fix it.
Sometimes it's difficult to isolate the problem for an internet connection, but to make it clearer for you and anyone else with the same issue. The modem is the central part of the connection. It's a verizon problem if the problem is the connection of the modem to the central office, and you can check it with the DSL light and Internet light.
It can either be a Verizon Problem or a Modem to PC problem, if the problem is between the modem to the pc. Possible Scenarios here are: The modem is defective, the NIC is defective, the Ethernet Cable is defective.
The first is a verizon problem only if the modem is still covered by warranty, if the modem is qualified for a DSP or a Device Service Plan, then that's good, you don't need to buy a new modem anymore. The second and third issue is a physical problem with the devices already and you'll need to have your pc fixed.
Try and isolate the issue, and if you can, let me know and I'll let you know what you can do to fix your problem.
Apr 29, 2009 | Westell Wirespeed ProLine 6100 Router...
New internet provider and now can not use remote viewing
If you have changed Internet Providers (which I assume you have considering you refer to changing from DSL to Cable modem), your "location" on the Internet has also changed.
Try going through the setup process with your Slingbox again as if it were the first time you had installed it.
Mar 18, 2009 | ParkerVision SignalMAX WR1500 / SignalMAX...
Verizon GT704WG DSL Modem wants me to install software
If my memory serves me, I didn't install the software for my Actiontec modem/router combo. I call Verizon and told them I refused to install the software and they helped step me through getting rid of this garbage. You should never have to install software to get a modem or router to work as any software the comes with it, is simply used to provide easier configuration.
Since I couldn't find anything about bypassing this software, I would suggest contacting Verizon directly. Their technical support should be able to assist you.
Mar 09, 2009 | Actiontec GT704WG Wireless Router...
UNABLE TO CONNECT TO THE INTERNET THROUGH COMCAST
To setup your router
first check..
Connect Cable modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. If it can go online,
to setup connectionwith router ..
Step 1:
Connect the Cable modem to the router’s WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we’ll connect the computer to port number 3.
Step 3:
Make sure the power adapter is plugged to an available power outlet.
Step 4:
check if you are able to go online wired..
if not your router has to be configured first,
you can also try power cycling your network set up,
Press and hold the reset button in your router for 30 sec with a pen or a paper clip with the power cable connected, then disconnect power for your router wait for 30 sec and then reconnect in back, restart your pc waith for all the lights to become stable in your router, then check if you r able to go online..
All the best...
Jul 07, 2008 | NetGear MR814 Wireless Router
No Internet light, but an Ethernet light that blinks?
for westell 6100 modem usb driver installation follow the steps for windows xp
-close all programs
-unplug usb cable from the pc
-insert installation cd from verizon
-plug usb cable back to pc
-wizard will pop up found new hardware
-click next then follow instructions
-select usb connection on the installation
Dec 14, 2007 | Westell Wirespeed LiteLine 6100...
Connecting my westell 6100 modem to my router
i there ;
the solution for ur problem is :
> As ur isp is verizon so they must have provided wu wuth a username and password ...
> Open the routers page 192.168.1.1 ...
> Instead of automatic configration click on pppoe ...
> type in username and password for more help contact technical support at 1866-283-6613 . i hope this will help Linksys Tech support
Dec 09, 2007 | Linksys Wireless-G WRT54G Router
Sony Playstation 3 (PS3) Console Logo
170 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
