Question about Tascam Audio Players & Recorders
Tape deck won't play
Tape deck rewinds and fastforwards but wont play.
  • bdmrules Nov 08, 2008
    I have the same Tascam 122 MKII tape deack. All my other functions... rew/ffwd/stop /pause all work fine. When I put a tape in and press play or record and play the tape drive won't spin the tape. Can this be fixed by a novice repair person like myself or does it have to be taken to a pro? Also if it's a belt bad, which one would it be?
    Thanks, Ed
    bdmrules@yahoo.com
  • adkinsart Mar 18, 2009
    tascam 122 single casstte won't play fast forward works rewind works,
    but play dosen't work it seems others have this problem what is the solution?
My machine not working problem is play, fd,rw, is not working all three led of rec,pause,play led is blinking
Posted on Dec 08, 2008
Harmon kardon dc520
Dual cassette deck are often poorly built and full of problem with age. They are typically not worth repair. Get a good deck like the Tascam 122 Mk II as these can be repairs.
I have consulted with clients that have dual decks and the cost to repair will get you a Tascam 122 Mk II in restored condition and it works much much better. I should know as I have been repairing decks for 40 years so far.
Sep 20, 2016 | Audio Players & Recorders
Denon tape deck ddr m30 will not play cassette, but fast forwards and rewinds fine, it just wont play!
There may be a separate motor for the play function and either it or a drive belt has failed.
Jun 17, 2016 | Denon Audio Players & Recorders
Tascam 302 Tape Deck - When I press play it rewind/fastfoward
There is either a cam belt that is lose or the flywheel assist can not move the head base due to hardened grease. It needs to be serviced.
May 16, 2013 | Tascam 302 PRO DUAL CASSETTE DECK Single...
I have a Sherwood DS1150 tape Deck. Problem Cant open Cassette Door, tape is inside . Will not rewind or fast forward. Wont play. Any advise
Very likely the tape is wound around the capstan.
You may have to get at it by taking the unit's case off.
If I am right you might have to destroy the cassette unless you are very careful. Or, at least, have to cut the tape so as to unwind it from the capstan.
You could also try to open the door just enough to lift it up and off ... as if you were going to clean the tape heads.
Mar 12, 2012 | Audio Players & Recorders
Cassette deck won't play, fast fprward, rewind. Automatically shuts off
The tape deck must be in need of a belt kit replacement. Difficult to get and even more difficult to replace.
Sep 26, 2011 | Audio Players & Recorders
My camcorder will not play, it will rewind and fastforward but it wont plan, can you help me? it will also record but it won't play what has been recorded
sound like the play back head may be dirty,,,
try a cleaning tape first if that dont sort it out its a trip to the repair shop with it
Oct 26, 2009 | JVC 580136 Camcorder
Sony WE605S won't play in back direction any more
if the square belt kinda serpentines in and around a couple pulleys (or did originally) then it did not get put back on correctly. try to think of another way it could be threaded through the pulleys.
Jan 24, 2009 | Sony DECK, MECH WITH AUTO REVERSE Single...
RS-dc10 DCC replacement head
You should contact Panasonic, or Matsuchita. They can most likely give you their authorised parts dealer. You may find the head to be a little expensive.
You will have to have an experienced tech install the head for you. He will have to do a tape path alignment with the frequency response calibration.
Jerry G.
Oct 02, 2008 | Technics RS-TR373 Single Cassette Deck
Blinking arrow and numbers, won't eject, play, rewind, fastforward
your camcorder must be broken. a specialist should work on that. go to your nearest technician to help you with. they have a tools for that. hope that helps!
CHARCOIS
Aug 08, 2008 | Sony Handycam DCR-TRV19 Mini DV Digital...
Rewinding a tape
Theres a rewind ,fastforward clutch inside the tape mechanism thats worn, the brake for the supply reel in not releasing completely, or theres hair -dirt- or gunk under the supply reel, or the drive belt needs to be replaced. Now If this wasent part of a tv set combo I would say take it apart and have a peak at some of the things I mentioned. BUT theres extremly HI VOLTAGE inside this puppy and if you dont know the saftey issues related to this , I would highly recommend getting a pro to assist you in this repair. Good Luck
Jun 27, 2006 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
393 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
