Question about Maytag Dishwashers
My Maytag Jetclean Dishwasher Model # MDB4010AWB Serial # 16163916uk is stoping midcycle, it doesnt make any noise or anything just stops. Water left sitting in bottom and have to open door then close to start again , stops again after a few minutes
    President:
  • Maytag Master
  • 2,651 Answers
Possibly a bad door switch losing contact, only after opening nad closing is it making contact again. part number for door swtiches and holder 99002254 retails for a about $25
Posted on Nov 05, 2008
My maytag jetclean dishwasher quiet pack makes a grinding noise and the sprayer doesnt spin
Take apart the sump filter area and check to see if anything is stuck in the impellers for the wash motor.
Jan 01, 2015 | Maytag Dishwashers
Dishwasher Stuck Mid Cycle
Jiggle the water level float sensor .It is stuck .
May 14, 2012 | Maytag Dishwashers
My Maytag dishwasher does not drain water after the wash cycle is over
Hi olabrk,
If you have a disposal make sure it is clear. You can put some icecubes in it to clean the blades and run some water through to make sure the drain is clear. If the dishwasher will still not pump out all the water check the drain line from the dishwasher to the sink drain for obstructions. If the drain is you will have to check the pump for obstructions. Sometimes glass, popcorn, toothpicks etc.... can get in the pump and prevent it from pumping out. If the pump is clear, then you will need a new pump. Good luck to you.
Mike Anderson
Oct 30, 2008 | Maytag 24 in. MDB7650AWS Built-in...
Dishwasher seems to b stuck on drain cycle
Model and serial number ???Helps alot
Jun 11, 2008 | Dishwashers
Plumber fixed the sink, now dishwasher is broken
sounds like the water is off, too coincedantal to brek after the plumber is there, the hot water under the sink is where the water supply to d/w is. obviously youre hot water at sink is working, there shloud be a sperate on/off valve for the d/w somewhere nearby
Mar 07, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Maytag mdb8600awq dishwasher drains good 20 seconds and stops
Dont know if you still have this problem, what I did was this - press the start button and keep going until you reach the number '2'. Leave it at '2' and in a couple of seconds it will start draining the rest of the water. Worked for me.
Feb 19, 2008 | Maytag 24 in. MDB8600AWS Jetclean II...
Mdb 6600aww
i need your serial num its important
Oct 19, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Maytag jet clean model#dwc7400aaw
Check to see in you have enough water in tank. The dishwasher fills then recirculates this water under pressure. If you have water in tank, listen to see if motor is running or not. If it is, you may have clogged jet holes in the wash arms.
Jul 31, 2007 | Maytag MDB9600A Jetclean II Built-in...
Dishwashers Logo
171 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
