Optional updates i downloaded optional updates now my computer shuts down every few seconds i have windows vista hp a1700n computer
  • thumbtac03 Nov 05, 2008
    i have done that already has not change it...........ran my virus protection.........ran the system mechanic and found no other than factory restore what could be next.............
  • 44 Answers
Restore your computer to the time it worked fine with system restore. To run system restore, click start and begin to type "restore" (without quotes) in the search box. system restore should come up in the search results.Click on the link to run restore.
Posted on Nov 05, 2008
  • Sam Hagin
    Sam Hagin Nov 05, 2008
    Backup your data and do a factory recovery
My hp laptop dosn't move in configuring 3 of 3 - 0%complete,and then it just switch of and on,and comes back to configuring 3 of 3 k 0% complete
Vista Update Stage 3 Stall……
You see Installing Updates Stage 3 of 3... 0% in Vista after you start or restart your computer and it never goes past 0%. Rebooting the computer doesn't change it. It still boots to Installing Windows updates 3 of 3 and never goes past that 0% mark. Sometimes Windows will even reboot in some cases. I have found that this often happens after Windows updates. I have no idea why, but this seems to be a fairly common occurrence. The last one I repaired was caused by a Service pack 1 installation.
Here's what I have done to fix the 3 of 3 error.
You will be doing a System Restore from the Vista f8 startup
Since the computer your working on is probably stuck on this screen the first step will be a hard shut down.
Hold the power button down until the computer shuts down.
Restart the computer.
Tap the f8 key about once or twice per second to get the Safe mode screen to come up.
In Windows Vista there is a new choice when the safe mode selection comes up. "Repair Your Computer"
Highlight the "Repair Your Computer" choice.
Windows will act like it is going t boot up.
You will see a System Recovery Options window.
It will ask you to choose your language.
Click Next
Select your user and put in your password. (leave blank if you don't have a password)
You should now have choices and the one you want is "System Restore"
Follow through the prompts with the Vista System Restore program.
Remember you should pick a restore point that is 1 or 2 points back.
Once you have completed the system restore process you will be asked to restart your computer. Go ahead and restart the computer. It should start correctly at this point. If you don't have a restore point available you may not be able to repair this error. I have not tried to repair one of these without a restore point yet.
Aug 12, 2010 | HP Computers & Internet
I was running the program "windon Defender" on it and walked away. When I returned the computer was off and wasn't turn back on.
The Windows Defender Application is the Antivirus Software which will be pre-installed with the Windows Operating System(Windows Vista, Windows 7).
The Computer will always Shut down after any Windows Updates or any Operating System Updates are downloaded and installed.
If you are connected to the Internet and running Windows Defender, the Computer will automatically download the Updates for the Windows Defender Application.
Once the Updates are downloaded and installed, the Computer will prompt for a shut down.
The count down will be for 10 seconds.
After 10 seconds, the Computer will install the downloaded Updates and shut down.
This might be the reason for the Computer to shut down while using the Windows Defender.
If the Computer still shuts down randomly, the issue might be due to overheating.
All the Processors in Notebooks are designed to shut down automatically, if there is any overheating issues.
The overheating issue mainly occurs due to the malfunction of the Cooling fan.
If the Computer shuts down frequently, the issue might be due to the above factors.
It would be better to get the Unit examined at the Service Center.
Jun 22, 2010 | Acer (56.04145.901) (5604145901) Power...
HP IQ770 TouchSmart doesn't load up or stay on
Step 1: Disabling Automatically restart option to view error messages
1. You can prevent the computer from restarting by turning off the Automatically Restart option:
2. Click Start .
3. Right-click Computer , and click Properties
4. Click Advanced system settings .
5. Click the Advanced tab and select Settings in the Startup and Recovery section.
6. Remove the check mark next to Automatically restart under System Failure .
7. Click OK to close the Startup and Recovery window and click OK , again, and then close the System Properties window.
8. Restart the computer.
Check if it happens again
If it happens again do a hard drive scan(FULL)
Download the latest BIOS update from
Step 2: Reinstall Microsoft SATA disk driver solution
1. HP Vista computers that use the Microsoft SATA disk driver do not experience automatic restarts. If you updated your Windows XP computer to a Windows Vista capable computer using an HP upgrade solution, this Microsoft SATA disk driver is available to reinstall.
2. To reinstall the Microsoft SATA disk driver, follow the instructions below.
3. Click Start on the taskbar.
4. Click All Programs , PC Help & Support , and then select Recovery Manager to open the Recovery Manager window.
5. If prompted, click Continue .
6. Click Next to continue.
7. The next window asks if you want to perform a program recovery. Select No , and then click Next .
8. The next window asks if you want to perform a driver recovery. Select Yes , and then click Next .
9. Click Next again to continue.
10. Select Standard Dual Channel PCI IDE Controller from the list of drivers, and then click Next . The reinstallation process takes a few seconds.
11.Click Finish to restart your computer.
Feb 02, 2010 | HP TouchSmart IQ770 PC Desktop
Shutdown takes 3-5 minutes. Hp pavilion dx7-1245dx vista 64-bit now takes anywhere between 3-5 minutes to fully shut down or restart. I have all updates from windows and hp and have checked numerous sites...
hi there is a few things u can do which might help
if you use internet alot /goto tools top right hand corner /internet options/ /go to deleat/then click deleat
this will take a while this deleats rubish
which takes up hard drive space
next /go to start-all programs-accsessires-system tools/ disk clean up
these are just a few things you can do might help a little
Sep 03, 2009 | Computers & Internet
When i power down my notebook, windows is not shutting down completely which causes a long power up. it came pre-installed. when i turn my computer back on, a screen appears stating windows did not...
First, run a scan disk/check disk option. You usually get prompted for this upon a reboot.
Second, if that doesn't work, windows is smart enough to create a few restore points when new drivers/updates are installed. Open up an explorer window (like my computer or my documents, not internet explorer) and press F1 for the help display. Search for system restore. It's very user friendly, so it should be pretty easy to find it
Jun 11, 2009 | Microsoft Windows Vista Ultimate Edition
Presario desktop windows vista, shuts down unexpectedly
Windows Vista will not install on old computers. If this is your case try installing Windows XP, If this does not work you might want to try Linux (Ubuntu). which will run on almost any old computer with full capabilities.
It is free and you can download it from
Feb 26, 2009 | Computers & Internet
Setting up dual monitors with NVIDIA 7300 GS Graphics Adapter
your computer don't recognize your nvidia graphic card in PCI Express slot.
you are runing now with computer's integrated graphic card?
if so then you won't have dualview option. in this case it looks for me like you've installed in the wrong way your graphic card.
your NV GeForce 7300 GS has 2 video output?
if yes then you should have the option for 2 monitors on nVIDIA control panel (i have check my nVIDIA GeForce 7600gt and in my case this option is present but is enabled only if i connect the second monitor, so try do so)
you have installed the latest nVIDIA drivers from the official website?
check if your video card is corect installed start/run type in " devmgmt.msc ". it will open device manager and under the display adapter tab you should see what video card you use now.
Feb 23, 2009 | HP Pavilion a1700n PC Desktop
When i want to update an update that needs to be updated
Do you know what the update is that fails? I guess the easiest way to see it is instead of using auto update, use Custom Update and see what needs to be installed.
I have also seen were some people have suggested this is caused by spy-ware on your system. Perhaps a in-depth scan would eliminate that possibility.
Personally I would not worry much about HP updates. The only time I would think of doing such updates is if I were having a problem with my system and an update directly addressed the issue. In fact I would go as far as to remove the HP updater.
Now Windows Updates are a different matter and should be done as they often cover security issues.
The HP Update program (bloatware, in my opinion) doesn't work with Vista very well, even though the system would have been bought with Vista pre-installed.Vista.
If you want to get rid of the HP Updates program, go to the Start menu and into the 'Control Panel'. Select "Programs & Features". The program is called 'HP Update'. You can Uninstall that program there if you like. You can manually check for updated hardware drivers by going to the HP site's Drivers and Downloads area, and entering your Desktop Model Number.
The HP Updates program also seems to have problems with various software/hardware firewalls, particularly when running Windows Vista, preventing it to search for and download optional driver updates for your HP computer.
HP says that hpsudelpacks.exe is a virus which affects mostly the automatic downloading of hp updates. go to their website and download the realtek audio driver manually to see if you can actually download updates to begin with. You should update any spyware or virus program if you have to and then shut down my computer and restart in safe mode. When in safe mode , run windows defender found here , then run avg virus program found here , then restart your computer, click on hp update in my start button area, and you should able to download another update.
Nov 06, 2008 | HP Pavilion Media Center a1330n - AMD...
My Rca Lyra Mp3 keeps shutting down by itself and what must i download to make it compadible with windows vista
Try updating the player's firmware, you can download it from the RCA Website (
If your computer doesn't recognize the player, you'll have to turn it off and keep "PLAY" pressed for 10 seconds while connecting it to the USB port, then update the firmware.
Aug 15, 2007 | RCA Lyra RD1021 MP3 Player
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
