Question about Brother IntelliFax-2820 Laser Fax
Cannot delete old quick dial numbers
I have tried to put in new quick dial numbers using the instructions, but when I check the new number the old number is still there. I have tried deletingth eold number but it doesnt work. How do I change quick dial numbers.
    Problem Solver:
  • 9 Answers
Quick dial numbers cannot be deleted.you just have to make sure you print first the auto dial list for you to know where it is located.go to that location,enter zeros and then menu/set to save the number as a zero
Posted on Nov 19, 2008
Need to program new phone numbers
The manual is available here: www.uniden.com/pdf/CEZ260om.pdf. If you search google for "uniden cez260 corded phone manual" it is the first result.
You can find the instructions in the fourth column of text under "Storing a Name and Number in Memory"
Here is the text from that section, but I can't promise the copied text is accurate. Check the pdf at that address if anything doesn't work.
1. Press STORE. LOCATION? shows in the display.
2. Press the desired memory location (0 to 9 or quick call buttons A, B, or C.) NOTE: Press LEFT or RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C to select a location.
3. Press STORE again to con? rm the memory location. NOTE: Use Delete to erase existing memories or to correct errors.
4. Use the number keys to enter the telephone number (up to 32 digits) and then press STORE to save. (The unit will not dial a phone number in this mode.) The cursor automatically moves to the text line for name entry.
5. Use the number keys to enter the name of the person associated with the telephone number you just entered. More than one letter is stored in each of the number keys. Press the keys multiple times to scroll through the letters for that key. For example, to enter "B," press "2" twice. Press LEFT two times to create a space. NOTE: The ? ashing cursor automatically moves to the next position or you may press LEFT or RIGHT to move the cursor to the next position.
6. Press STORE to save the name.
7. To enter another name and number in a di erent memory location, return to step 1 and repeat this process.
Storing a Pause in Memory
The REDIAL/PAUSE button has dual functionality and becomes a pause button when pressed in sequence after the STORE button. It is valid only when storing a number into memory locations. Use the REDIAL/PAUSE button to insert a pause when a delay is needed in an automatic dialing sequence (for example, when you must dial a 9 to get an outside line or when you enter codes to access your long distance company).
NOTE: A pause is 3 seconds in length and you can store more than one if a longer pause is needed. Changing a Stored Number Repeat the storage sequence under Storing A Name and Number in Memory, and press DELETE to delete the old number before entering the new number.
Erasing a Stored Name & Number
1. Press STORE.
2. Press the memory location (0 to 9 or quick call buttons A, B, or C) to be erased.
3. Press DELETE.
Copying Caller ID Memories to User Memory
1. Press LEFT or RIGHT to view the caller number and name you want to copy.
2. PressSTORE.
3. Press the memory location (0 to 9 or quick call buttons A, B, or C). The number ? ashes if there is a number already stored in that memory location.
4. Press STORE to enter Edit mode, and then pressSTORE again to edit the name. NOTE: Select a di erent memory location by using LEFT and RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C.
5. Press STORE to con? rm and save. Wait three seconds to exit.
NOTE: If the name you want to enter is longer than 12 characters, only the ? rst 12 characters will be copied into memory.
Storing a Redial Number to Memory
1. Press STORE.
2. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If a number is already stored in the memory location, it will appear on the display. Use LEFT and RIGHT to select a di erent location.
3. PressSTORE again to con? rm.
4. Press REDIAL/PAUSE, and then press STORE again.
5. Enter the name, if necessary, and then press STORE to con? rm.
Copying a Redial Number to Memory
1. Press REDIAL/PAUSE while on-hook. Redial number will display along with PICKUP PHONE.
2. Press STORE.
3. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If there is a number already stored in the memory location, it will appear on the display. Use the RIGHT or LEFT buttons to select a di erent location.
4. Press STORE twice.
5. Enter name, if necessary, and then press STORE again to con? rm and save.
Dialing Numbers Stored in Memory
1. Press DIAL.
2. Press a memory location button or use LEFT or RIGHT to scroll through stored memory locations to ? nd the desired number. The number in that memory location displays.
3. Press SPEAKER or pick up the handset to dial the displayed number.
OR
1. Lift the handset or press SPEAKER.
3. Press DIAL again to dial the stored number.
Jun 11, 2015 | Uniden CEZ260 Corded Phone
I need instruction manual to program speed dial
I was unable to locate a user manual for that particular device, however the basic instructions for programming speed dial functions are normally very similar between most phones.
Generally there are ONE TOUCH Speed Dial buttons labelled something like M1, M2, and M3 on the dial pad somewhere.
There should also be another button labelled PROG or STORE on the keypad as well.
Normally to program a number into a ONE TOUCH speed dial memory location you carry out the following procedure:
Lift the handset.
Then press the PROG (or STORE) button.
Now just use the number keypad to dial the full telephone number that you want to store in a Speed Dial location.
Once the full telephone number is dialed, then push the M1 button to store that phone number in the M1 One Touch Speed Dial location.
The phone may or may not show some kind of confirmation that the M1 location was just programmed, then just hang up the handset.
Now when you lift the handset and press the M1 button, the phone should automatically dial the phone number you programmed into it.
Now just repeat the same process for the M2 and M3 One Touch Speed Dial buttons with other phone numbers if necessary.
To change one of the Speed Dial numbers, just carry out the normal programming procedure for that location using the new phone number and the old number will simply be overwritten.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Dec 02, 2011 | Southwestern Bell FM-480 Corded Phone
Enter memory data
Here are the commands to run the phones memory dial (speed-dial).  I have included the instructions for deleting and changing numbers as well.  It is listed below.  I hope this helps you out.
Ken
MEMORY DIAL INSTRUCTIONS Store up to ten 20-digit numbers in memory for quick dialing. Storing a Number in Memory 1. Make sure the phone is OFF (not in TALK mode). 2. Press the MEMORY button. 3. Press a number (0-9) to store the dialed number in that memory location. 4. Press the MEMORY button again. 5. Use the handset number keypad to enter the telephone number (up to 20 digits, including pauses) and press the MEMORY button again to save the number. The unit beeps to confirm. 6. To enter another number in a different memory location, return to step 1 and repeat the process.
Storing a Redial Number 1. Repeat steps 1 through 4 in Storing a Number in Memory. 2. Press the REDIAL button. 3. Press the MEMORY button to store the number. You will hear a confirmation tone.
Changing a Stored Number 1. Repeat steps 1 through 6 in Storing a Number in Memory. 2. Press the MEMORY button to store the number. You will hear a confirmation tone. The old number will be overwritten with the new number.
Dialing a Stored Number 1. Make sure the phone is ON by pressing the TALK button. 2. Press the MEMORY button. 3. Press the number (0-9) for the desired memory location. The number dials automatically. Inserting a Pause in the Dialing Sequence Press the PAUSE# button once to insert a delay in the dialing sequence of a stored telephone number. A pause is needed to wait for a dial tone (for example after you dial 9 for an outside line, or to wait for a computer access tone). Each pause counts as 1 digit in the dialing sequence. If you need a longer pause, press the PAUSE# button twice.
Deleting Stored Numbers 1. Press the MEMORY button. 2. Press the desired memory location (0-9). 3. Press the MEMORY button twice to delete the entry. 4. You will hear a confirmation tone.
Jan 08, 2009 | GE 27928GE5 Cordless Phone
My cordless phone is clicking when i dial.
Jeanne fist a background history lesson - there are two dialing modes in existence one is pulse or earlier on was known as decadic dialing. This is where the phone would break the connection a number of times to represent the number dialed. Remember the old dial phones that you would dial a nine and it would spin around back to its original position and would break the line nine times . Very Very slow way to Dial.
now to the 21st century - Tone dialing was invented also know as multi tone frequency dialing MFTD by sending two frequency tones numbers and symbols could be encoded to pass through the phone line quickly.
Solution
press menu / select option
select telephone settings
see picture below from user manual
Jun 18, 2017 | Vtech Cordless 6041 Phone
FL511'S Faxes using Quick Scan
Search thru your menus to make sure GROUP DIALING and CHAIN DIALING are not enabled.
Sep 24, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Need to program access code into phone line for long distance numbers
Does it work when you press speaker/hook and manual dial same fax number you are trying to program
It sounds like you are adding digit needed for outside line when it is in fact a direct/dedicated fax line, that needs it not (or vise versa).
Are you printing a report of rapid/speed dials that you set to ensure the number you put in is correct?
Nov 05, 2007 | Brother IntelliFax-1860C All-In-One InkJet...
Programming a number for memory
Memory
Nov 03, 2007 | Uniden Cordless Phone
Programming instructions for used phone
Program Thomson Consumer Electronics (GE?) 2-9316A Speaker Phone (what we found works)
To program:
1. press speaker or lift handset.
2. press STORE
3. dial the number to be stored
4. press MEMORY DIAL
5. press location (0-9 on keypad or 1 of the 3 emergency quick dial)
6. press speaker or hangup.
To dial emergency numbers:
2. press any of 3 emergency quick dial
To dial stored numbers:
2. press MEMORY DIAL
3. press location (0-9 on keypad)
Does anyone know how to add PAUSE in a stored dial string?
Aug 27, 2007 | GE Corded Speakerphone with 2 Cordless...
Resprogram speed dial numbers problem
You can reprogram them using bitpim.
Jun 10, 2007 | Motorola Mobility RAZR V3
Brother IntelliFax-2820 Laser Fax Logo
124 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
