Question about Magellan Meridian GPS Receiver
Blank screen I have a handheld unit that was working fine, untill my son got a hold of it. now every time I push the power button, I get a flash of black across the screen then nothing. I have changed batteries, and also tryed pushing the nav and power buttons together still nothing. three attemts to contact magellan have failed.
  • 4 Answers
Same problem that the older IFiner (Lowrance) had, it is an internal problem with the GPS, needs to go in for repairs, BUT first see if it is cheaper to just purchase another GPS
Posted on Jan 13, 2009
Dell xps touch sreen just blinking blue light but blank screen
Sounds like it went to sleep due to low battery power. May be time for a new battery if it isn't holding charge well.
Plug it into the wall and push the power button once. It may come back on. If not...
Hold the power button down until the machine shuts off completely. If that doesn't work, remove the battery.
Feb 04, 2015 | Dell Computers & Internet
The touch screen ain't working
Try to calibarte it:
Calibrating the Leapster2 is easy:
1) Ensure that a game cartridge is not inserted in the Leapster2
2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER2 menu appears. Remember that you need to hold the "Hint" button down the whole time while you are pressing the power button, and releasing it.
3) The LEAPSTER2 menu will show the options Base Info, Cart1 Info, Cart2 Info, Cart3 Info, and Touch Calib. If you do not see this menu after powering on the Leapster2, turn the Leapster2 off and repeat steps 1 & 2 until you see the menu.
4) When the LEAPSTER2 menu screen appears, press the A button on your handheld.
5) Using the stylus pen, touch each of the crosshairs that appear
6) Restart unit
Source:
http://leapfrog.custhelp.com/cgi-bin/leapfrog.cfg/php/enduser/std_adp.php?p_faqid=1736&p_created=1221582020&p_sid=DqRj3Kxk&p_accessibility=0&p_redirect=&p_lva=1725&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NCw0JnBfcHJvZHM9MjkxMyZwX2NhdHM9JnBfcHY9MS4yOTEzJnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9Y2FsaWJyYXRl&p_li=&p_topview=1
Dec 26, 2010 | Leapster 2 Handheld Game
I can not type in names to activate this toy. I touch the screen and nothing happens.
I think you need to calibrate this toys:
6) Restart unit
Dec 24, 2010 | Leapster 2 Handheld Game
I have a quantum model 3212 serial #3000...fcc id #kj8intrmt...ok im trying to program my garage door to my truck..help please
1. In the vehicle press and hold the two outside buttons until the indicator light begins to flash (after 20 seconds). Release both buttons. Note: Some vehicles may require the ignition switch to be turned to the second (or "accessory") position during the programming process.
2. Hold the end of your handheld transmitter between 1 and 3 inches away from the Homelink surface (located on your visor or overhead console) keeping the indicator light in view.
3. Using both hands, simultaneously push the handheld transmitter button and the desired HomeLink button. DO NOT release the buttons until step 4 has been completed.
4. Hold down both buttons until the indicator light on the HomeLink Wireless Control System flashes, first slowly then rapidly. When the indicator light flashes rapidly, both buttons may be released. (The rapidly flashing light indicates successful programming of the new frequency signal.)
To train your garage door opener.
1. Locate the smart/learn button on the garage door opener motor head unit.
2. Press and immediately release the smart/learn button.
Firmly press and release the programmed HomeLink button. Press and release the HomeLink button a second time to complete the training process. (Some garage door openers may require you to do this procedure a third time to complete the training.)
Feb 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
Don't have owners manual. I how do I setup the
garage door opener that may be different. But, I believe there are 2 ways to do it. Try pushing the button on the back of your garage door opener by the LED. The light will begin flashing for 30 seconds. During this time, it is accepting new signals. So you have to quickly get in your car and push and hold the button you want to work your door. If the opener accepts the signal, it will flash its floodlight. Then just push the homelink button again to see if it raises/lowers the door.
The second way I don't remember quite so well, but I believe you hold the corresponding button on the homelink until THAT starts flashing, then point your remote at it and push that button. The homelink will flash 3 times quickly if it accepts it. I don't think I've ever gotten this method to work, which is why I'm unsure of the procedure.
I've had new and used cars with and without manuals and the first procedure has always worked. It may take a couple of tries, though
Oct 22, 2009 | 2000 Chevrolet Impala
Leapfrog Leapster
I've tried the Home and A button several places... and it seems to work for others but not me :( I was about to give up then I found another way to reset the screen - Hope it works for you!
1. Unit must be OFF and NO cartridge
2. Hold down the HINT (?) button while turning the unit on
3. When Leapster menu screen appears, press the A button
4. Touch each of the cross hairs that appear with the stylus
5. Restart unit
Dec 01, 2008 | LeapFrog LeapSter L-Max Console
Changing the time pioneer DEN2000MP
The solution that worked for me is:
1) turn off the radio.
2) Push and hold the power button down (the dial). DON'T release the button.
3) The unit will display the time on the lcd screen with the numbers flashing, (only hr or min).
4) use the up/dwn, right/left buttons to set the clock.
5) turn off the unit by pushing the power button (again, the dial).
That is it. the clock should be set.
Hope that helps,
Nov 11, 2008 | Pioneer DEH-2000 CD Changer
Aircondition not working
E1 indicates  Filter needs replacing/Cleaning , this code flashes after 720 hours of operation time.
Disconnect the power plug
Clean or replace filter
HOLD DOWN (dont let go) Of  the ON/OFF button and plug the unit back up and continue to hold the ON/OFF button until you hear a beep
After the beep unplug your A/C
Then plug it back up to and turn it on for normal operation
IF THIS FAILS TO REMOVE THE CODE
UNPLUG A/C  THEN HOLD DOWN THE MODE BUTTON AND PLUG IT UP STILL HOLDING THE MODE BUTTON UNTIL YOU HEAR A BEEP.
UNPLUG UNIT  AND THEN PLUG IT BACK UP AND ONE OF THESE 2 STEPS WILL FIX YOUR PROBLEM   UNLESS THERE IS A MAJOR PROBLEM IN THE CONTROL BOARDS
Oct 13, 2007 | Sharp AFS60FX Air Conditioner
Password forgotten
To do a hard reset:
Press the Power button to turn the Axim unit On.
Press and hold the Power button down while using the Axim stylus to
press the Reset button at the same time.
Release the Power button and the Reset button.
TheTo clear all data in the memory screen appears.
Press the Contacts button on the Axim to delete all of the data in the
memory of the Axim handheld.
5
Press the Mailbutton on the Axim to cancel the operation without
losing data.
Sep 14, 2005 | Philips Nino 210
GPS Logo
110 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Steve
Steve
Are you a Magellan GPS Expert? Answer questions, earn points and help others
