Question about Blaupunkt Car Audio & Video
Lights on blaupunkt automotive stereo faceplate not working. probably blown out lights. model is cambridge cd 125. any chance of replacing them myself? where do i get the parts.
    Problem Solver:
  • 6 Answers
Very trickey to replace bulbs as they are very small....any good electroinics outlet would have them in stock p.s the need to be soldered in
Posted on Nov 05, 2008
Got power to cd but no display
One idea that comes to mind is,if I remmeber correctly, that model has a removeable faceplate, try this, remove the faceplate,take some denatured alcohol on a Q-tip,clean the electric contacts on the back of the faceplate and also on the front of the deck where they mate together repeatedly for about 4 to 6 times letting them dry between each time that you swab them clean, then replace the faceplate onto the deck being sure that you are seatting the faceplate completely and properly.
This has worked for me sometimes and sometimes not, its worth a try.
Good Luck !
May 02, 2010 | Sony XPLOD CDX-GT200 CD Player
Replaced battery in my 03 ford focus now my car stereo will not power on. any procedure to reactivate my car stereo to turn. been reading horror stories about this setup. ugh!!
Not sure if this will help you , but many aftermarket have a reset switch behind the faceplate. would be a small hole about big enough to poke the tip of a ball point pen into.
Also , remove the faceplate and replace it making sure it is clicked in securly.
May 09, 2009 | 2003 Ford Focus
My stereo gets power put when I put my faceplate on it does not light up but i can eject a cd if I push the eject botton
what may have happened is the contacts on the faceplate or the main unit may be broken or not making contact check to see if any contacts are pushed in far or bent or missing if so replace or fix them it should work what probably happened is the contact for the display lights might have been damaged and be fixing that issue then you should gain the screen back.
Sep 05, 2008 | Kenwood Audio Players & Recorders
No power at all to blaulplunkt rpd 555 faceplate model
If the face was disconnected and that was the only problem, you should be able to just reattach the face. If not, contact blauplunkt customer service and they should be able to tell you how to bypass any lock code it may have.
Jul 21, 2008 | Blaupunkt RPD-555 CD Player
CD Player
I'm currently having the same problem. Take the face plate off. Use a pin to reset the stereo. It'll probably stop working again, but at least you'll be able to get your cd out and take it somewhere to have the stereo fixed or replace. (STAY AWAY FROM JVC!)
May 20, 2007 | JVC KD-G200 CD Player
The display light suddenly went out. I can see the different fuctions like the time, station, and everything else still working when I shine a flashlight on it but it does not light up. Is there a light...
take your cd player to an electronic shop and ask for the thin film connection the screen with the main system, that should do it, you see after some time the film goes bad and eventually doen';t work
Mar 06, 2007 | Blaupunkt Tokyo RDM169
Fade button - does this system have one?
You can download an owner's manual for your CD player from this link: http://www.blaupunkt.com/us/downloads_1.asp
Mar 05, 2007 | Blaupunkt Orlando CM127
Car Audio & Video Logo
93 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
