Question about Jabra FreeSpeak Bluetooth Headset - V500 / V525 Headset
Not getting tone to enter voice dialing - Jabra FreeSpeak Bluetooth Headset - V500 / V525 Headset
Wasn't compatible for voice dialing so I returned it to the store......
Posted on Nov 08, 2008
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
Inoperative fax and telephone line
try connecting line 2 to a simple phone and chk for dial tone.
Sep 22, 2008 | Canon FAXPHONE L80 Laser
How to retrieve messages when not at home? Model 26976GE 1A
This section explains the remote access process for use with any touchtone
1. Dial the phone number for the answering machine.
2. After the answering system answers, press any numbered key on the
touch-tone pad to bypass the outgoing announcement, or wait until
the announcement finishes.
3. Enter the security code after you hear the tone.
4. Follow the voice menu to use the answering machine's remote functions.
The remote feature enables you to perform the following functions:
To Press this button
Review message 1
Play back messages 2
Stop message play back 2
Erase message 0
(during message playback)
Skip message 3
Turn off/on answerer 4
Review voice menu options 7
No valid dialing tones for 15 seconds will hang up the telephone line.
You can get the manual on the link below if you need page 31.
Good luck
Dec 04, 2010 | GE Spacemaker 26976 Cordless Phone
How can I access my voice mail?
Usually you press and hold #1 and it will call your voice mail or dial your own phone number and press # or * during your voice mail msg
Jul 04, 2009 | Motorola Mobility W510 Mobile Phone
First, try this:
Menu>Settings>Audio>Keytones(Change tone).
You may have to personalize each setting (Messaging, Voice calls, keytones, etc.) within your Audio to adjust your preference.
Hope this helps! Thanks.
Mar 26, 2009 | LG CG225 Cellular Phone
No dial tone on receiver only on voice
make shure handset cord is Not pluged in to the Headset jack on the bottom, needs to be in the handset jack (look at the icons)
Jan 29, 2009 | NorStar Meridian M7310 Phone
RCA Model 25204 2 line speakerphone corded with call waiting caller ID
As bsmither said, how voice mail is accessed is very dependent on your phone company and how they've set things up. They would be the best place to ask about any problems you're having there.
As for programming the voice mail buttons on the 25204, I was confused by that one as well until I finally figured it out. Specializations aside, they're just speed dial buttons, and are programmed in exactly the same way as the ones along the right side of the phone. RCA could have documented that detail better than they did.
In my case, with Vonage, I just programmed the buttons with the numbers for the lines that they're associated with. When they dial and I'm connected to the voice mail system, I'm prompted for my VM password, which I then enter manually.
Jan 30, 2008 | RCA 25414RE3 Corded Phone
Remote Message Retrieval
Accessing the Answering System from another location.
from any touch tone phone by entering your 3 digit security code after you hear the outgoing message.
1. Dial the phone no. to which the answering system is connected to .
2. Enter the security code after you hear the tone.
3. Follow the voice menu to use the answering systems remote functions.
Review messages press 1
plack back messages press2
Stop message playback press 2 again
Erase message press 0 during playback
Skip message press 3
Turn off/on answer press 4
Review voice menu options press 7
Nov 27, 2007 | GE 27851 Cordless Phone
Voice mail
Do your Dial tone sound different. Your phone listens to the dial tone. if you have a new voice mail your dial tone changes.and your phone does the flashy thing accordingly. Contact your phone company.
Aug 18, 2007 | Motorola Mobility 5.8 GHz Digital Cordless...
Radio Communications Logo
53 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
