Question about Kitchen Ranges
GE Range Model GRCR3825ZWW-1 DOOR error code on range display
Can't find a manual for this GE range. And sites don't except the above model number. DOOR error displays when oven temp is selected and oven will not turn on. If oven does turn on, will turn off when DOOR error appears. Not sure what is causing as intermittent. If I turn the temp control off and close the oven door very hard, the oven will turn on...but would prefer to find out what to fix or replace.
  • 2 more comments
  • aceent Nov 29, 2008
    I have the same problem. Help !
  • stovepipe2 Dec 11, 2008
    Same issue just in time for baking season....it makes a clicking noise too. Just off warranty!
  • bakeorbroil Apr 02, 2009
    Had problem with oven temp, fluxcuating high/low. Diagnosed as the Control Unit in my Model JKP27W0P2 oven. CU no longer available, but found shop that rebuilds the part. On installation of the repaired CU I now get an error message "door" and a flashing "lock" on the LED display panel. Oven will not come on. May have disturbed wiring to the door lock during original troubleshooting, but don't think so. Any ideas on cause of the door error message?
  • Anonymous Apr 10, 2009
    Same problem as the others have written. Very frustrating when trying to bake or roast, as heat shuts off completely. Even slamming the door and the self clean catch don't fix the problem anymore.
    Repairman thinks it's the timer switch, which is very costly and not a sure thing.
    Convection has now stopped working too...maybe it's time for a new appliance, and not a GE!
The door latched Micro-switch is not working or is dirty.
Remove the back panel, in the middle of the back there will be a metal arm that moves in and out when self cleaning latch is closed and opened. This arm pushes two or more Micro-Switches in the back, they are dirty or not working and need replacing.
Posted on Jan 12, 2010
Our GE JSP69WT1WW will not work after a self cleaning cycle.
On turning on he oven, in a few seconds a door signal appears on the control panel. Same with the broil operation. I am able to start self cleaning again.
I am wondering if there is a sensor for the door ot if the door gasket may be damaged?
Posted on Apr 26, 2009
I am trying to determine when my gas range was manufactured - 362-7585590 is the model number. And who manufactured it. Thank you.
The 362 code indicates that the range was made by GE. The manual for the range is available here: http://www.searspartsdirect.com/partsdirect/user-manuals/3627585590-kenmore-parts-gas+range-manual?manualIndex=0 . To download the manual go to http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0801065.pdf . You need the serial number of the range to determine the date of manufacture.
These sites may help: http://products.geappliances.com/appliance/gea-support-search-content?contentId=16195 and http://www.appliance411.com/service/date-code.php . The first site lists how GE adds the date code in the serial number. The second site will give you the manufacture date after you fill in all of the details.
I hope this helps.
(Some code lists indicate that the 362 prefix indicates a Roper appliance built with GE parts.)
Apr 07, 2017 | Kitchen Ranges
Getting a PF7 code with beeping on my stove. Reset breaker, didn't fix it. Any help would be appreciated.
GE oven error code "F7" and how to fix it ' AskGene.com
www.askgene.com/.../oven...codes/ge-oven-error-code-f7-and-how-to-fi...
Jun 23, 2007 - The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic ... We have a GE Spectra Oven - GAS - we keep getting F7 errorcodes and the oven will not heat. ... In my case it was the keypad.
Why is my GE Range model number JBP80SM2SS making ...
www.shopyourway.com > Manage My Life > Questions
Apr 6, 2010 - Get shopping advice from experts, friends and the community! I was boiling water on back burner of ceramic stove top GE range Model ... When anyappliance picks up an error code or starts beeping the problem that caused it ...
Jan 08, 2016 | GE Profile 30" Self-Cleaning Slide-In...
My microwave/convection oven (a GE unit model JES1290SK) started beeping every few seconds and displaying F6 on the control panel. I unplugged it and waited several minutes and when plugged in it displays...
The technical sheets in my files do not list F6 on the error code chart for GE microwaves.
Generally, these are the error codes possible on GE microwaves:
F1 open thermal sensor (convection models)
F2 shorted thermal sensor (convection models)
F3 key panel shorted for more than 60 seconds
F4 open humidity sensor
F5 shorted humidity sensor
There should be a "mini-manual" (technical sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Jan 15, 2011 | GE JES1290 Convection/Microwave Oven
Oven will not work.
This is what GE recommends for your oven:
“F—and a number or On models with a door latch, • The latch may have been moved, even if only slightly,
letter” flash in the display if a function error code appears from the locked position. Make sure the latch is moved
during the self-cleaning cycle, to the right as far as it will go.
check the oven door latch.
You have a function error code. • Touch the Clear/Off pad. Allow the oven to cool for
one hour. Put the oven back into operation.
If the function code repeats. • Disconnect all power to the range for 5 minutes
and then reconnect power. If the function error
code repeats, call for service.
May 18, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Fridgidaire Electrolux Professional Series Oven, not preheating
The model number listed in your problem is a refrigerator.  Go to:
http://www.frigidaire.com/manuals.aspx
and enter the model number of your range/oven unit to find the user manual.
On my GE range I only have to press and hold the LOCK button for several seconds (until it beeps) to unlock it.
May 28, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Vintage General Electric Range
Lazidaisies,
you asked where can I find a service manual for a vintage stove? General Electric, 24"wide, push-button, electric; 1950s.
Placard on inside of oven door is "erased", except for embossed numbers: On the Left = 1 1245W2M2 10 7 On the Right = NM28552
You should go to GE and call them on the phone. They will have th resources to give you this Manuel!
bless you,
huuum
Please rate me before you sign off
Sep 12, 2008 | Kitchen Ranges
F5E1 error
Whirlpool-KitchenAid-Roper Appliances: Oven Fault Codes:
>>Exception Note:<<
Chart below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appear, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
May 11, 2008 | Whirlpool RF378 Electric Kitchen Range
Error code
All the information I could find on GE ranges indicate that an F-7 error indicates a problem with either the Electronic Range Control (ERC) keypad having a stuck key, or the ERC itself being defective. You can unplug the ribbon cable on the ERC and wait at least 32 seconds before plugging it back in to see if the problem clears. If the problem persists you will have to replace the ERC. Make sure you UNPLUG the range and/or turn off the main breaker to it BEFORE servicing. Remove the back panel of the range to access the ERC. If you cannot get the fault to clear and wish to replace the ERC, post back with comments as to your model number (usually located on the frame of oven door opening or lower drawer opening) and I will research to find a part number for you. Keep in mind, most ERCs do not come with the overlay (plastic piece with the number and keypad displays). I would advise you to replace both if you decide to repair the range. i hope this info helps you.
Nov 06, 2007 | Kitchen Ranges
F2 Error code displays with audible beep.
The F2 typically means an overtemperature conditions:
1. over 650 degrees F unlatched or 915 degrees F latched.
2. cooling fan stalled while over above 650 degrees F or an oper thermal switch in the yellow leads.
Check for:
1.Welded relay contacts
2.Cooling fan stalled or blocked air flow to rear of unit.
3.High resitance in over sensor leads/connectors, especially at sensor in rear.
Nov 03, 2007 | GE JTP20 Electric Single Oven
Kitchen Ranges Logo
2,654 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
