Dimension300desktop/windows xp/ no sound/no volume controls
Cannot seem no matter what I try, I cannot get my speakers/volume controls to work again. It says...cannot detect sound mixer divice...this device is working properly(legacy) no software detected for this device...ect.,ect.,ect....going nuts! PLZ help!
  • 6 more comments
  • brnsuup Nov 05, 2008
    I have a dimension 3000 from dell. I keep getting a run around within my system about audio mixer device,no software can be found,hardware cannot install because of no software,cannot install software without the hardware,yadda yadda,yadda.HELP!
  • okreceipt Nov 16, 2008
    I have the same problem w/ my Dell Dimension and yes did recently have to reinstall XP -- I swear the speakers worked before the hard drive crashed due to virus. Now reinstalled and virus free -- but also sound free. Help!
    Thought maybe I was missing the device driver -- but it's there --
    Location 65535 (Internal High Definition Audio Bus)
    But I get this error message: This device cannot start. (Code 10)
    Click Troubleshoot to start the troubleshooter for this device.
    Thanks in advance
  • cherp431 Nov 24, 2008
    I loose speaker sounds & volume icon goes missing
    not system sounds
  • Anonymous Dec 13, 2008
    The speakers were working well until I stood up to put the volume up; as soon as I touched the volume I got a static discharge and that speaker stopped working. The left one works fine but the one with the volume shut down completely! Did I burn a circuit inside? How can I fix it? I can't figure out how to open the speaker to take a look inside!
  • lindaxfische Jan 01, 2009
    i cannot make my volume rise.
    Can you help?
    lind
  • Anonymous May 25, 2009
    the same problem no volume can some help thanks jery
  • Devocap
    Devocap May 11, 2010
    Hey there brnsuup,
    Have you recently done an operating system re-install? If so which one? And do you have all the drivers required for your system? Also the exact model number would be helpful. Dimension 300 does not show on the dell list.
  • 77 Answers
MAY BE THE SOUND DRIVERS MISSING
TRY INSTALLATION FRESH
Posted on Apr 07, 2009
I have an HP Laptop with Windows 7 and I have correctly set up my Logitech LS21 speakers, but the volume control does not enhance the sound coming from my laptop. The speakers work fine, but the sound is...
There are 2 volume controls on the audio output in windows 7. one is the system volume the other is the device volume. make sure that they are both at full and then control the sound volume on your speakers.
Jan 20, 2013 | Logitech LS-21 2.1 Speakers
Volume stuck on mute for wireless speakers
After pairing it, have you tried to go to your sound settings in Control Panel and selecting the bluetooth device as your standard sound device?
Oct 25, 2012 | Computers & Internet
My speaker volume is very low no matter what i play. All volume controls are up as high as they will go
Have you checked your system audio volume?
If you are using Windows XP go to Start menu -> Accessories -> Entertainment -> Volume Control
Make sure that the volume is set to the highest value.
Mar 04, 2011 | Polk Audio AMR50 Computer Speakers
The speakers wont work no sound
This article contains tips for resolving sound related issues in Windows XP.
No Sound From all speakers
  • Check that the speakers are powered on.
  • Check that the speakers are connected to the correct ports on the PC. This is particularly important If the customer has both integrated sound and a sound card.
  • If the speakers have a volume control button - ensure that this is turned up.
  • Check that the Windows Audio service is running. If this is not running then many of the subsequent troubleshooting steps will not work. Go to Start->Run and type services.msc. Double cliick on Windows Audio. Select Start if possible and check that the Startup Type is Automatic. Click OK.
  • If the speakers are digital speakers then try forcing the sound card to use digital. Go to Start->Control Panel->Sound and Audio Devices.. On the Volume tab, click the Advanced button in the Device Volume section. In the Volume Control window, below the Play Control Volume slider, click Advanced. If this does not show select Advanced Controls from the Options menu. Select Digital Output Only
  • If possible try an external audio source like a Walkman, CD, or MP3 player (connect the speakers to the headphone jack)
  • Check that the volume control in Windows isn't muted or turned too low. See the screen shots below. Go to Start->Control Panel and double click on Sounds and Audio Devices.
Aug 10, 2010 | Logitech V20 Computer Speakers
My speakers isnt working anymore i dont know why tha lights are going on everything seems 2 be fine before when i touched tha 3.5mm jack it made a strange sound that how i know it was working but now it...
Aug 06, 2010 | Harman Kardon SoundSticks II Computer...
No matter what, I can't get any sound...
Click on the sound properties in control panel. see if the volume on the properties is up. or is NOT muted. Plug headphones into all the speaker jacks (should be the green plugs) and test each one. If that doesn't work, uninstall the driver and select reinstall.
Apr 28, 2009 | E-Mu 1616M Sound Card
Speakrs don't work on new HP Pavilion desktop.
If you're using Windows XP, go to the Control Panel, then double-click on Sound, then go to the Audio tab and make sure the playback device is set to your Realtek output.
If you're using Windows Vista, go to Control Panel and click on Hardware and Sound, then click on Sound. Make sure your Realtek device is selected with a green check mark. If it isn't, just click on it and then click the Set as Default button down below. Vista sound configuration is kinda quirky, and it does do some kind of detection when you plug a cable into an audio jack, so you might leave this screen up while you plug your speakers into the green audio jack in the sound card and see if it pops anything weird up.
Apr 17, 2009 | Computers & Internet
My speaker sound
If you are using Windows XP, click >Start>Control Panel>Sound, Speech and audio devices> again >Sound, Speech and audio devices> then check the "Device Volume" control. Also check the controls under "Advanced" button.
Feb 15, 2009 | Polk Audio AMR50 Computer Speakers
Speakers are plugged in correctly, lights on but still no sound
Check your output jack again and make sure its on the green jack
and also check your speaker wires, if okay then check this;
For Windows XP;
  1. Go to Control Panel
  2. Sounds and Audio Devices
  3. On the Volume tab under "Device volume" check that sound is NOT muted
  4. Adjust volume control
  5. Check "Speaker Setup" under "Speaker settings" under the "Advanced" button
For Vista:
  1. Control Panel
  2. Sounds
  3. Select Speakers then properties
  4. Make sure device is enabled
  5. Test sound
  6. Adjust volume controls
Under Device Manager make sure that under your sound card that you dont have a yellow exclamation. Yellow exclamation indicates you need to install the correct driver.
Jan 18, 2009 | E-Machines T6420 PC Desktop
Low volume
> Open Control Panel
> Sound Properties
> Speaker Properties
> Enhancements
Loudness Equalization : on
Equalizer: Choose one (Jazz seems to be loudest setting but sounds of hallway effect so I use powerful for clarity.)
This has more than doubled the level of volume on my acer 5570.
- verc
Jul 16, 2006 | HP Compaq nc6320 Notebook
258 people viewed this question
 Grubhead
Grubhead
